Ever had your truck oiled for rustproofing purposes?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by goldnrod24, Nov 5, 2018.
  1. Nov 5, 2018 at 7:44 PM
    goldnrod24
    goldnrod24 [OP] Well-Known Member
    Randy
    2014 Regular Cab 4X4
    This came up in another topic. I took my '14 in for the treatment tonight. Full undercarriage as well as inside the hood panel, door panels, rockers, cab corners and tailgate.
    Anyone else using this method to delay the ravages of salt? What's been your experience? Are you having it re-oiled yearly as recommended?
    Randy
    I married my tacoma likes this.
  2. Nov 5, 2018 at 7:53 PM
    goldnrod24
    Randy
  3. Nov 5, 2018 at 8:07 PM
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    I think I get the concept, I think I kinda do something similar... I wipe down with ATF, get surface rust off, clean, repaint. Would be alot easier to just spray it with this stuff. In the end does it leave oily residue? Like after you spray it, next time to go to pull parts or something, is everything like coated with oil and messy or does it dry clean?
  4. Nov 5, 2018 at 8:37 PM
    goldnrod24
    Randy
    jboudreaux1965 likes this.
  5. Nov 5, 2018 at 8:38 PM
    goldnrod24
    Randy
    It doesn't dry clean. There will always be an oily residue, although the product/process is described as "drip free."
  6. Nov 5, 2018 at 8:56 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    Their just covering over rust in the video to prevent more rust. Would I do it... No.
  7. Nov 5, 2018 at 8:57 PM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    What makes cars and trucks rust isn't the snow and the ice, it's the winter salt and chemicals. This crap is very corrosive, so if you do not protect the underside of your car, it's going to literally eat it up. Paint is not enough, it will eat right through it as well.
    An Oil/Wax/Grease mix is the best protection you can have. That's what rustproofing centers use. It does not drip, but there's always some oily or greasy residue that will never dry clean, but isn't a mess if you need to crawl under the vehicle.
    If you want to do it yourself, Fluid Film is an excellent product for this purpose.
    Rustproofing isn't something you do once and never again think about. You have to do it each year if you want to keep maximum protection from rust
    If you have existing minor rust, it will prevent it from spreading while also protecting your car. Of course, if you already have important rust on your vehicle, it's too late to rustproof, as it should have been done before the rust settled in
    goldnrod24[OP] likes this.
  8. Nov 5, 2018 at 9:04 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    But you have to remove the original rust. Coating it after cleaning I could see being good. Also depending how often you tear you truck down, oil residue all over everything....
    Man I swap parts depending on what I'm doing that day, oil over everything adds like an extra hour+ of headache cleaning tools, like 10-20 pairs of extra gloves....
  9. Nov 6, 2018 at 3:28 AM
    Apex1
    Apex1 Well-Known Member
    Central CT
    2011 DCSB TRD
    Or use a rust converter / reformer. Just clean off the loose stuff and spray the existing rust over and converts it to a base layer. It is not a topical coating. It effectively turns the outer coating of rust to a coverage layer that can be painted. Although some just leave it as is. That should stabilize the rust you see now.
    https://www.ncptt.nps.gov/wp-content/uploads/metal-paper-88.pdf
  10. Nov 6, 2018 at 3:34 AM
    gunn_runner
    gunn_runner www.gunnphotoservices.com
    Rocky River, OH
    2013 DCLB TRD
    OME 886 & Dakars. 35" Mickey Thompson Baja Boss
    The better solution is Fluid film.
    vtown likes this.
  11. Nov 6, 2018 at 3:34 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    The only rust proofing I will do is stuff paid for by Toyota.
    I’m not taking on an expense for an issue that is their problem. They can replace my frame when the time comes.
    I sure as hell wod never spray that stuff in my hood.
    Talk about a nightmare to do cleaning under there and do any work you need to do.
    You should keep under your hood detailed 1-2 times per year. You shouldn’t be fluid filming it.
    Same thing for the door jams. That stuff will increase the risk of rust because it will hold contaminants to the paint which will damage it.
    Its not that hard to wipe down your door jams each car wash to keep everything clean. Then you can rub in a sealer every year for added protection.
  12. Nov 6, 2018 at 3:50 AM
    Bomo
    Bomo Well-Known Member
    Vermont
    2017 TRD offroad DCSB Manual
    Waxoyl is what I put on my truck...
    Two winters in New England and only sight of rust is on the Exhaust pipe. That’s becious that don’t spray the exhaust.
    People also use fuid film or used oil.
    https://www.waxoyl-usa.com/
    sioux likes this.
  13. Nov 6, 2018 at 4:57 AM
    96carboard
    96carboard Well-Known Member
    The type of oil can have an enormous impact on how well it protects your vehicle.
    If you just splash it with motor oil, it will wash off pretty quickly and you're back to square 1.
    Chainsaw bar oil is great stuff, because it is waxy. BUT, if you leave your chainsaw outside all year without running it a bit to re-oil the chain, it WILL rust.
    Ideally, you need to have something on the frame that the oil will soak into.
    A lot of people don't like asphalt undercoating, since they say it dries up, cracks, and lets water/salt in to attack your frame, HOWEVER, a combination of asphalt undercoating and a dose of oil will keep the asphalt nice and soft, and the oil will repel water.
  14. Nov 6, 2018 at 7:25 AM
    cvisinho
    cvisinho Well-Known Member
    Rhode Island
    2005 TRD Sport DCSB new frame edition
    Bilstein 5100's, Eibach springs, Cali Raised Amber fogs,Cali Raised side projecting ditch lights, 17" gunmetal trd pro reps w/ falken wildpeaks, MESO interior lighting, Alpine ilx Android auto head unit, rear view camera, blue sea fuse panel, mbrp cat back, Morimoto retros in Depos, Ranch cap, triple black clazzios, DIY thin lip satoshi with FJ letters, oem roof rack, AJT climate knobs, slim sub behind rear seat, fosgate speakers all around, thule cap rack
    I have always used fluid film with pretty good results here in New England winters.
    I am in the middle of moving and have the FF packed up till i get to the new place. But I did try the new chemical guys Bare Bones undercoating recently for the hell of it.
    Im certain its not as thick/durable but it is pretty nice in a pinch, been about a week and a half and still holding up decent.
  15. Nov 6, 2018 at 10:20 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    The important thing to understand about undercoating your vehicle with a product that doesn’t dry and stays moist, is that it needs to be reapplied at least once a yr due to it will gradually wash off with road spray from the tires. Undercoating a vehicle isn’t a one time deal. Pick your product and get into a routine as usual maintenance, no different then changing your oil. Lower that spare tire and get that area also. I use fluid film on the undercarriage and use corrosion x in the engine compartment. For the engine area I use a little corrosion x on a 1/2 “ brush and brush any areas that are prone to rust or corrosion, including parts made of aluminum. Aluminum oxidation is stopped dead in its tracks where applied and looks new.
    This actually doesn’t take a lot of time, I can do my undercarriage in 20 min. my engine bay in 15 min.
    Also, I just like doing this kind of stuff when I don’t have anything else to do. It’s easy, it perseveres the value of your truck, and when you decide to sell, you will get a better return for your effort than the guy that did nothing.
  16. Nov 6, 2018 at 11:41 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    I heard spraying the undercarriage with wd40 works
    boston23 likes this.
  17. Nov 6, 2018 at 11:59 AM
    smithe3006
    smithe3006 Member
    Pittsburgh
    2015 magnetic gray trd sport
    You’re gambling that they will open a case for models 2011+. Good luck.
  18. Nov 6, 2018 at 12:08 PM
    PackCon
    Connor
    In a way, yes.
    But for 15 model years Toyota has been replacing the frames on its trucks or has done a buy back program.
    Going to be hard for Toyota to evade future liability without changing frame materials, design, manufacturers etc.
    You are taking a gamble by buying a Tacoma when it comes to frame rust. Every model year that has had the opportunity has rusted.
    Show me a fool proof method for rust prevention when I live in a salt state. You can’t perfectly coat the inside of the frame and I bought mine used with rust already there.
    Could I coat my frame? Yeah. Is it going to make any difference when it comes to needing a new frame? No.
  19. Nov 6, 2018 at 12:13 PM
    Apex1
    Central CT
    2011 DCSB TRD
    If history is an indicator, Toyota will do something if 2011+ frames rust in a similar way to previous years. They have built their reputation on making things right for the customer.
    The issue is, what if there are problems with rust but it is not as widespread as the previous generations. Your 2011+ Tacoma may have frame rot similar to previous generations, but you may be in an extreme minority. If that is the case, Toyota may not offer blanket coverage to all owners.
    smithe3006 likes this.
  20. Nov 6, 2018 at 12:26 PM
    smithe3006
    smithe3006 Member
    Pittsburgh
    Idk. For about 15 bucks a year I can spray some FF on everything underneath and it gives me some piece of mind. We will see how well it holds up to Pittsburgh winters. I’ve seen some 2014/15s with some serious rust already so hopefully a case will be made. Even if they did replace the frame however, that doesn’t mean everything that’s rusty underneath will be new.
