Evaporator core Replacing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoCats, Apr 20, 2018.
  1. Apr 20, 2018 at 9:34 AM
    TacoCats
    TacoCats [OP] Active Member
    07 Tacoma Off Road
    I guess there is no other way around it then to take the whole dash out to replace it?
  2. Apr 20, 2018 at 9:57 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Correct. Dash comes out. It’s not hard to do, just tedious. If you don’t have a zip gun you’re going to want to get one. I’ve done them in less than 7 hours by myself before. With somebody helping it can be done in about half the time.
  3. Apr 21, 2018 at 6:08 AM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    Is it leaking? The expansion valve is accessible from the firewall. It could be leaking.
  4. Apr 21, 2018 at 6:17 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I agree, it can take up to 7 hrs including evaporator swap. It's not that bad of a job. Just insist on being left alone and put your phone on airplane mode. You can still take pics, but you won't get distracted.
    You will find connectors not plugged into anything. Mark those as soon as you find them. They will confuse you when it comes time to reassemble. Most parts will only fit one way, so it's really just a simple, big puzzle.
  5. Apr 21, 2018 at 7:57 AM
    TacoCats
    07 Tacoma Off Road
    I did use a leak detector sniffer, held it up to the drain hose, started beeping like crazy, never did check the expansion valve.
  6. Apr 21, 2018 at 8:02 AM
    Bebop
    Nick
    Got a UV light and some yellow glasses? If dye is in the system the tube will glow green under the light. It will look like predator blood.
  7. Apr 21, 2018 at 11:01 AM
    koditten
    Kirk
    Central Michigan
    I've found more leaks using soap and water.
    Like said above, check fittings 1st. Evaporator leaks are rare.
  8. Apr 21, 2018 at 12:51 PM
    Bebop
    Nick
    Depends on the maker. Toyota does have their evap core leakers out there but not like Dodge.
    koditten[QUOTED] likes this.
  9. Apr 21, 2018 at 4:56 PM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Ya, not a fan of dye.
    5luggin likes this.
  10. Apr 21, 2018 at 9:11 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Here is some help for the expansion valve that is sticking out of the firewall. I think it is one bolt in the center between the two nipples and it will come right out through the firewall.
  11. Apr 22, 2018 at 8:24 AM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    Zip gun ??? Small electric screw/socket driver???
  12. Apr 22, 2018 at 8:37 AM
    koditten
    Kirk
    Central Michigan
    No, it's for quickly installing zip ties.
    CurtB and Bebop like this.
  13. Apr 22, 2018 at 8:54 AM
    Bebop
    Nick
    Yes. Zip gun is slang for an electric impact driver. I use my small 1/4 Matco and 3/8 like they are going out of style. Love those tools.
    Canufixit likes this.
  14. Apr 22, 2018 at 9:00 AM
    Bebop
    Nick
    I have pics on my old phone of the last couple 4runners we did. Let me see if I can find my old phone and post up some pics.
  15. Apr 22, 2018 at 10:55 AM
    Canufixit
    New England
    :thumbsup:
