Evap system & oxygen sensor showing incomplete
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gcamberos82, Aug 22, 2020.
  1. Aug 22, 2020 at 4:44 PM
    gcamberos82
    gcamberos82 [OP] Member
    Gerardo
    Highland, CA
    2007 Toyota Tacoma (Silver; TRD, 2x4)
    Hey Tacoma World,
    Just took my 2007 Toyota Tacoma for my SmogCheck and it did NOT pass because the evaporative system and oxygen sensor was not complete/NOT Ready! Is that running cycle issue or what other problems/solutions can that be? There are no OBDII codes showing currently...but, the SmogCheck place shows otherwise! Any ideas/solutions? Thanks...:thumbsup:
  2. Aug 22, 2020 at 4:45 PM
    Bishop84
    Bishop84 Well-Known Member
    Any recent repairs? Battery disconnect?
    Usually it shows this after blasting codes out and it needs numerous drive cycles to recomplete.
  3. Aug 22, 2020 at 5:52 PM
    gcamberos82
    Gerardo
    Highland, CA
    Not recently, but I did changed the oil, air filter, and spark plugs a few months ago! I think what happened...this AM, I tried turning on my truck and the battery was dead. I had to jumped-start it with my other car. Do you think that’s the main issue/problem? And, what do you suggest me doing to resolve it? The SmotCheck tech told me to turn on the truck (let it sit there while ON), then drive the truck on a consistent speed; +55MPH for about 15-20 minutes. Then, let it sit for another 5-10 mins. Is that about right?
  4. Aug 22, 2020 at 6:19 PM
    Bishop84
    100% the battery dying reset the trip.
    It's usually a few days of regular driving that will set the trips to complete.
    So at the very least, make sure the battery is ok a few days before emissions test.
    Handheld scanners can show if monitors are complete as well, they can be as cheap as 40$
  5. Aug 22, 2020 at 7:09 PM
    gcamberos82
    Gerardo
    Highland, CA
    I see! :( Bummer, that’s what I thought...I guess I will have to drive it around the next couple of days as I normally do; maybe, a few long trips will do! Thanks for the advise, much appreciated! :thumbsup: :bowdown:
    And yes, I saw that! I do have one...but, I don’t think mine has those capabilities to transcribe the full monitors of the emissions. I will look into that! Thanks again! :) :woot: :wave:
  6. Aug 23, 2020 at 3:45 AM
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    gcamberos82[OP] likes this.
  7. Aug 23, 2020 at 6:18 AM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    What should you do? If the battery was dead replace it, provided the alternator is good. :)
  8. Aug 23, 2020 at 6:30 PM
    gcamberos82
    Gerardo
    Highland, CA
    @JustAddMud Thanks! I’ll give that link/drive cycle sample a try! Still gotta drive my truck for a few days...still shows the Evap system and Oxygen sensor monitors as INCOMPLETE.
    JustAddMud likes this.
  9. Aug 25, 2020 at 11:05 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Don't ignore the battery problem. 3ish times of running it dead will kill the battery. A bad battery can also overwork the alternator, killing it. Get your charging system tested, and check your parasitic draw.
