EVAP system CEL P0456
Discussion in 'Technical Chat' started by hladun, May 23, 2012.
  1. May 23, 2012 at 8:23 AM
    hladun
    hladun [OP] Well-Known Member
    Alberta
    Tacoma
    I've been getting the P0456 code on my 08 Tacoma.
    This is very useful;
    My question is during "Operation C: EVAP pressure Measurement" the pump discharges into the cannister filter. The filter is connected to the tank filler neck below the gas cap so it's connected back to the tank. So how can it draw a vacuum when it's pumping in a loop?
    Thanks.
  2. May 31, 2012 at 8:45 AM
    hladun
    Alberta
    Tacoma
    Surprised that no one could answer my question. Fortunately I was able to make a fix that has cleared the code. Put hose clamps on cannister filter hoses.
  3. May 31, 2012 at 1:01 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    I believe that, normally, the EVAP system carries a vacuum.
    But when the vehicle is first started, a small pump pressurizes the system and checks for a leak (holds the pressure). If a sensor detects a leak-down, it throws the code. If it can't hold a small pressure, then it can't hold the vacuum either.
    At least this is how our 2002 Dodge does it. I had to replace a split vacuum hose when it threw an EVAP code.
  4. Jun 2, 2012 at 6:12 PM
    hladun
    Alberta
    Tacoma
    I had a careful look at the filler today and, sure enough, just under the lip on the right side of the filler there's an opening for the vent line. So the vent system does vent to atmosphere.
    Tan4x4 if you read the link in my first post it explains how the system works and not how you have described.
  5. Jun 2, 2012 at 6:19 PM
    98tacoma27
    Ben
    Not Beech Creek
    It's not in a loop. The system is closed.
  6. Sep 3, 2012 at 1:26 PM
    FRYBOTH
    FRYBOTH Well-Known Member
    Christian
    Seattle
    08 Tacoma Base 4x4 2.7L Inline 4
    I got this code as well. My own mechanic skills and tools are rather limited. What is it that you did to fix it? I also have a family member with expert skill when it come to this sort of thing. So whatever you can tell me I can pass along and he can help me do it. Thanks!
  7. Sep 4, 2012 at 9:17 AM
    hladun
    Alberta
    Tacoma
    In the end I replaced the charcoal cannister assembly and the code has gone away. When I took the old one apart it appeared that the very tiny vacuum pump was ceased. Reread my other comments and look at the link to understand how the system works. Basically it wakes up in the middle of the night and draws a vacuum to see there are no leaks.
  8. May 22, 2013 at 5:28 AM
    ScissorMeTimbers
    ScissorMeTimbers Crème fraîche.
    Colorado Springs
    18 Cement V6 DC TRD Off-Road.
    Been getting this code on and off for awhile, now it finally seems that its here to stay. Before I take it to get checked out (hopefully under my extended warranty) I want to try this hose clamp fix. Where are these cannister filter hoses you speak of? Pics? Thanks!
  9. May 22, 2013 at 6:35 AM
    hladun
    Alberta
    Tacoma
    While doing a search I came across some old posts by me when I was hunting the P0456 problem. I want to update it so if anyone else is looking they get the right answer. What it did turn out to be was that the diaphragm in the refuelling valve was ruptured. It is a used truck so maybe overfilling the tank by the PO or an accident caused the rupture. Unfortunately the solution was the very expensive charcoal cannister assembly.
    fast5speed likes this.
  10. Oct 13, 2018 at 6:01 AM
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    I just got the P0456 code. I cleared it and opened and closed my gas cap. I’ll post back what happens next.
  11. Oct 15, 2018 at 3:05 PM
    JLink
    Josh
    Ocean, NJ
    So far so good. I had just gotten gas the day before the light came on. Hopefully the cap was loose or maybe it was over filled.
    I’ll post back it if happens again.
  12. Dec 28, 2019 at 1:45 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Any updates on this?
  13. Jan 15, 2020 at 8:01 AM
    CowboyTaco
    CowboyTaco $20 is $20
    North Georgia
    11 TRD Sport
    I seem to get this code on particularly cold days (by comparison) in the south. I typically only get the "Pending Error Code" message on my Ultragauge. Only once has it turned into a full blown CEL.
  14. Oct 31, 2020 at 6:38 AM
    Claudiomartinof
    Claudiomartinof Well-Known Member
    2019 TRD OFF ROAD 6MT
    Hi! I just got this code.
    I started my truck having an almost empty gas tank. I was planning on refueling today because I came home late yesterday.
    would it be that? That I am almost on empty tank?
    Any help is greatly appreciated
  15. Oct 31, 2020 at 7:24 AM
    hladun
    Alberta
    Tacoma
    A little vacuum pump in the charcoal canister assembly tries to draw a vacuum on the fuel tank to make sure there are no leaks. If the gas cap isn't closed or if the tank is nearly empty (lots of air to pump out) or the pump is getting old then you can get this error. Fill your tank and reset the code and see what happens.
  16. Oct 31, 2020 at 7:59 AM
    BassAckwards
    Making sure the gas cap is tight is where I'd start
  17. Oct 31, 2020 at 10:03 AM
    Claudiomartinof
    Hi man! Thank you very much.. this is the first time it happens to me and I have a keyed gas cap that I've been using for about 4 years now.. I had the low fuel warning this morning.. I went to gas station, filled and inspected gas cap and it looked ok.. tightened gas cap until it clicked (like I always do) and gone...
    Thanks for the help!
  18. Oct 31, 2020 at 10:04 AM
    Claudiomartinof
    Problem solved! Thanks!!!
  19. Nov 1, 2020 at 9:21 AM
    CowboyTaco
    North Georgia
    11 TRD Sport
    This could be your problem. Keyed gas caps aren't (typically) air tight like non-keyed versions.
