EVAP P0456 - Small Leak Detected - Smoke Test
Discussion in '2nd Gen. Tacomas (2005-2015)' started by vanhalo, Sep 9, 2024.
  1. Sep 9, 2024 at 7:01 AM
    vanhalo
    vanhalo [OP] Well-Known Member
    Did a smoke test with the Canister Pump Vent Valve closed and opened via scan tool. Fuel cap is about a year old. Smokes comes out of the atmospheric vent on the LDP (Leak Detection Pump)whether closed or open. You can barely see it. Smoke also comes out around the gas cap whether the vent is closed or open. However when I close the vent it definately minimizes the amount of smoke coming out around the gas cap.
    replace Charcoal canister and leak detection pump? I will link the videos later.
  2. Sep 9, 2024 at 8:24 AM
    Jeffs68
    Jeffs68 Well-Known Member
    2015 PreRunner TRD Sport DC
    Stock
    A little bit of smoke is normal on the atmospheric vent. I'd start with an OEM fuel cap and recheck. Also check all the lines and hoses, the truck is older and most likely has OEM hoses.
    vanhalo[OP] likes this.
  3. Sep 9, 2024 at 8:29 AM
    mikkydee
    mikkydee My Taco 2007 DCLB 4x4 Man Truck
    Doyle
    Florida
    2007 Silver DCLB Tacoma, 4X4, 4.0 Liter, 6" lift, 20" rims, 34" tires
    6" lift, 20 " inch rims, 34" tires, billet grill, aftermarket fender flares, custom rear bumper, DVd player with backup camera, all LED lights
    You got some nice tools there. I had to make a home made smoke detector to figure out the problem on my van.
  4. Sep 9, 2024 at 8:45 AM
    vanhalo
    I bought that Xtool D8 scan tool used on EBay. I did the math and to add each of our vehicles to some of the other less expensive bidirectional scanners it would have been about the same price.
    I have a new OEM cap on it now. You think it would go bad in a year? I’m at work i will link the video later. Its a 2007 and im quite certain the hoses are original OEM
    mikkydee[QUOTED] likes this.
  5. Sep 9, 2024 at 9:46 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    You have to unhook the vent hose from the fresh air port on the canister and cap the port to do leak test, closing the vent valve does not seal the system on Toyota leak detection pump systems.
    mikkydee and vanhalo[OP] like this.
  6. Sep 9, 2024 at 9:49 AM
    vanhalo
    thanks. I will rerun the smoke test.
  7. Sep 30, 2024 at 4:18 PM
    vanhalo
    Replaced the gas cap(even though it was only a year old) and the ventilation hose that goes to throttle body. Reset the codes and it has come back. The ventilation hose did have a very small crack on the end. I think it was the gas cap though. It’s been more than a week now.
    Dm93 likes this.
  8. Sep 30, 2024 at 6:30 PM
    TacoTuesday1
    FL
    fwiw locking gas caps have a reputation on here for being mixed luck on sealing properly. Guess I got lucky as the locking cap I got has worked without issue.
    probably a good idea if you’re replacing it to have a lock system whether the cap or installing a lockable door.
    vanhalo[QUOTED][OP] likes this.
  9. Sep 30, 2024 at 9:43 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Toyota does not play well with aftermarket gas caps of any kind especially locking ones, OE only on gas caps. Not sure why but you have maybe a 50/50 shot of an aftermarket one sealing properly.
  10. Oct 1, 2024 at 3:43 AM
    vanhalo
    i used OEM in both cases.
