Estimate of head gasket Replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by yosh1975, Mar 5, 2021.
  1. Mar 5, 2021 at 4:31 AM
    yosh1975
    yosh1975 [OP] Well-Known Member
    northeast ohio
    2005 std 4x4
    Brown milky oil in 2.7 manual 4x4.
    Anyone have head gasket replaced recently? Did you do head too?
    What would be rough number?
    Located in ohio
  2. Mar 5, 2021 at 6:17 AM
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    That price can vary widely depending on shop and region. How many miles on the motor? Has the motor overheated with the head gasket blown? How many miles with the headgasket blown? Might just be worth a lower mile motor swap. Coolant contamination is devastating to bearing surfaces on a long enough timeline. And with a motor swap, you can install a new clutch while you're in there.
    TRDSport10 likes this.
  3. Mar 5, 2021 at 12:20 PM
    yosh1975
    northeast ohio
    2005 std 4x4
    180k ish. No overheating.
    What kinda range on swapping engine?
    Body is beat up bad, only good is frame is only few years. Might sell/ trade just to get out.
    Thanks
  4. Mar 5, 2021 at 12:23 PM
    yosh1975
    northeast ohio
    2005 std 4x4
    Could it be something else that allows coolant into oil? Freeze plugs or ?
  5. Mar 5, 2021 at 12:24 PM
    Muddinfun
    Muddinfun Well-Known Member
    Is the coolant level going down?
  6. Mar 5, 2021 at 1:15 PM
    Rick's 2012
    Rick's 2012 Well-Known Member
    Rick
    Costa Rica
    2012 Double Cab 4x4 Grey with leather
    Stock
    Is the oil milky, or is the oil filler cap milky??
    Sometimes people see the cap milky and assume the oil is as well
    boogie3478 likes this.
  7. Mar 5, 2021 at 2:20 PM
    Tacologist
    Tacologist Well-Known Member
    Bob
    Tenessee
    05 Double Cab Shortbed
    Rear leaf suspension. Home done tailgate re-inforcement.
    3,000 is in the ball park at a stealer. You may do better at a private garage, but have they done one before. Remember it is no longer a Sunday afternoon 3 beer job.
  8. Mar 5, 2021 at 2:25 PM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers and a skewp
    Just out of curiosity, why would/ does the oil filter cap get milky?
  9. Mar 5, 2021 at 2:46 PM
    Bashby
    Bashby Active Member
    Condensation
    AllTacosFloat[QUOTED] likes this.
  10. Mar 5, 2021 at 3:06 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    The cap on my v6 collects condensation. It is at the end of an extension tube, away from the heat of the motor. If yours is similar, that could be all it is. Could be...
  11. Mar 5, 2021 at 4:23 PM
    Rick's 2012
    Rick
    Costa Rica
    Stock
    Condensation. A lot of short trips. Cold outdoor temperatures. etc
  12. Mar 5, 2021 at 4:25 PM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    it is Friday
  13. Mar 5, 2021 at 7:50 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    2.7 liter, 2TR-FE oil filler cap is direct into the valve cover. There is no extended neck.
  14. Mar 5, 2021 at 8:19 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    This is an important question.
    No need to jump straight to a head gasket if you are not loosing coolant.
    Another question is, where did you observe this brown milky oil?
    This would help a lot in the direction of - if there is, and what is the problem.
  15. Mar 5, 2021 at 10:16 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    $2500,if you even have a headgasket problem.
  16. Mar 6, 2021 at 1:49 AM
    yosh1975
    northeast ohio
    2005 std 4x4
    Drained oil 2x in past week, both times brown milky. Oil cap has always had a little milky brown on it but oil when changed or even on dipstick was good.
    Truck sat for about 6 months with no action, had cat back done and clutch solenoid replaced. Now the brown milky oil.
    I ran it with rad cap off, no bubbles. Doesn't appear coolant is dropping, although I haven't run it much due to fear of more damage
  17. Mar 6, 2021 at 5:34 AM
    Bashby
    I’m not familiar with this particular engine, but on other engines there are places other than the head gasket that can let coolant into the oil. Intake gaskets (on V engines mostly), oil coolers...
    ETA: I’ve seen a few 22R engines where the timing chain would rub through the timing cover and into a coolant passage.
  18. Mar 6, 2021 at 5:44 AM
    Bashby
    CDA2F734-F996-4737-B6B3-FAA97101627B.jpgI marked areas where coolant could get into what I believe are oil return passages. It’s possible for that to happen but these MLS head gaskets are pretty bullet proof, IME.
    C5D11F28-25C7-47E2-9599-B38045E435B5.jpgThat’s the intake gasket, no coolant passages there.
  19. Mar 6, 2021 at 6:14 AM
    Bashby
    9ABE6C76-73D5-4DC0-836F-2739498E88F8.jpg C6445BD9-1362-4A9E-A0A9-3FC446DB22E8.jpg
    Here’s a front and rear view of the timing cover. There is a possible source of coolant to oil.
  20. Mar 6, 2021 at 9:17 PM
    TnShooter
    Deogee
    STOCK
    You’d think there would be coolant loss if it were entering the engine.
    You might do a coolant system pressure test and see if it holds pressure?
