Essential recovery gear for overland and off-grid camping trips?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Trucks2019, Dec 26, 2023.
  1. Dec 26, 2023 at 5:26 PM
    Trucks2019
    Trucks2019 [OP] Well-Known Member
    I’m looking into getting some recovery gear to head further off-grid for camping trips and realized I ought to consider picking up some essential recovery gear. I’d likely be keeping to forestry roads.
    wondered what you would consider essential, and whether they serve more than one purpose. Currently considering the following:
    GoTreads recovery boards.
    Air compressor.
    Kinetic rope. Do these attach to existing points on the truck?
    This is specific to vehicle recovery.
  2. Dec 26, 2023 at 5:40 PM
    RichochetRabbit
    RichochetRabbit Ping Ping Ping
    I would get one of these (https://www.factor55.com/c-hitch-receiver-shackle-mounts) to put in read hitch to help others help you get out.
    ARB recovery point for the front because it can handle the load of being pulled out of sand/mud better than the "flat level towing points" that come with the truck: https://store.arbusa.com/recovery-point-17-600lb-2823010/
    Post in your regional forum to get an education in recovery so you can tell the amateur who may have more gear than you how to use it safely. Case study in "stupid amateurs:
    https://www.tacomaworld.com/threads/kingman-az-man-died-in-offroad-recovery.774094/
    Folding saw to cut tree limbs off more safely than axes. Shovel (normal shovel, not midget) to remove debris.
    Tire plug kit to at least crudely fill a hole in the tires.
    2x10 or 2x12 segments to place under jacks in soft material. Harbor Freight sells a $300 "Badlands Offroad Jack" if you have remaining cash.
    I have a hand-held CB radio in case I need to call others and it JUST MIGHT reach.
    NOCO GB40 (they make bigger) to jumpstart your own vehicle.
    OZ TRD, soundman98, eurowner and 3 others like this.
  3. Dec 26, 2023 at 9:16 PM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    Soft shackles, tree strap, winch, Geolander M/T, and full ARB lockers. Throw in some chains for icy conditions :D
    AmateurTaco1313 likes this.
  4. Dec 26, 2023 at 9:25 PM
    RichochetRabbit
    Learn to use what you carry. People die when a static-load tow-line is used like a kinetic rope.
  5. Dec 26, 2023 at 9:34 PM
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
    I’ve been on my own since the middle of April. Canada, Alaska, Central America, and now South America. I’m at 78k miles in a year on a new truck. Started this trip around 6800 miles. Here is the number one piece of recovery/safety gear you can have on your truck if you are traveling alone: Common Sense and the ability to listen to a gut feeling. Nothing you can buy will ever come close to being as valuable.
  6. Dec 27, 2023 at 4:05 AM
    AZ_Tumbleweed
    AZ_Tumbleweed Well-Known Member
    Wilmington, NC
    2020 TRD OR DCSB Cement 4x4 AT
    A few tips for those who aren't familiar with recovery as i see this happen way too often
    1. Don't use recovery straps with hooks on it.
    2. Don't attach a recovery strap to a tow ball hitch on either vehicle. The ball can snap and become a deadly projectile. Get something like this which you can use on your or another vehicle if they aren't equipped for recovery
    - https://www.amazon.com/SALMAN-Aluminum-Receiver-Bow-Shackle-Accessories/dp/B0B3972LL1?crid=YG0M32H5CXTA&keywords=shackle+Hitch+Receiver&qid=1703678516&s=automotive&sprefix=shackle+hitch+receiver%2Cautomotive%2C89&sr=1-9
    3. If being recovered, always attach the tow rope to your own vehicle yourself. Don't let an idiot whos never recovered someone before hook it up and damage your truck
    TN1000, baboltin and AmateurTaco1313 like this.
  7. Dec 27, 2023 at 5:31 AM
    TCB2020
    TCB2020 Well-Known Member
    2020 Tacoma TRD Sport
    None
    Thanks for the post. I too am a newbie to the finer points of recovery. I am having a Warn semi-hidden bumper and Evo 12S winch installed in a few days, so I'm in need of experienced advice as well. I currently have an ARB recovery strap, a Factor55 Hitch link 2.0, 2 Factor55 3/4" steel shackles, a Smittybuilt tire repair kit, small shovel, hatchet and that's about it as far as gear. I can see getting a snatch block/pulley and a soft shackle or two for now. There is a company somewhat local to me in Pennsylvania that has a recovery class in an offroad park, that's on my "acquire list" as well.
  8. Dec 27, 2023 at 6:12 AM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    #1 - Know how to use ANY gear you purchase. Recoveries require a great deal of force and energy. Things can go from calm to deadly in an instant
    #2 - Common sense, don't do stupid stuff
    #3 - Don't go alone - if you can go with a friend then it will be a lot safer if something happens
    #4 - I disagree greatly with the poster quoted below. CB radio/GMRS/HAM is NOT a emergency communications solution. Unless it's a hobby you are into you should not even entertain the thought. It's much less capable then people would like to think. If you want true backcountry communication get an Inreach or an iPhone 13+ with satellite SOS.
    #5 - Actual gear - A good tow strap, a real set of soft shackles/ or decent bow shackles, tire inflator and patch/plug kit. And unless you are in the sandy desert then traction boards are mostly a fad.
    madcratebuilder and soundman98 like this.
  9. Dec 27, 2023 at 5:28 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    this all really depends on the situation, vehicles, hazards, and people involved.
    stuck in the sand is different from mud, which is different than snow, which is also different than the other 40 types of snow, and all of it is different if any sort of significant incline hazard in any direction is involved. but all of it is really dependent on the vehicles involved. trying to recover a newer sedan, they all have belly pans with limited attachment points.
    i don't want to steer you wrong, but there's times where a gentle nudge with a kinetic rope is plenty fine, but also times where it's a serious slow/stop/repeat doubled-line winch job(heavy thick mud-- you need to stop often to break suction, otherwise you're just trying to pull the recovery vehicle into the mud hole, or kill people with flying hitch balls).
    the biggest thing is to take a deep breath, try to understand the forces involved, and if gentle-tug plan 'a' isn't working, rarely is "plan 'a' BUT MORE VIOLENT!!!!!111!! HIT IT BUBBA!!!!" going to be a better solution.
    if plan 'a' doesn't work, stop, reassess the situation, come up with a plan b--attach/pull a different direction, remove obstacles, or admit to defaulting to plan z and call for help, preferably from a reputable company with insurance if they muck something up.
  10. Dec 27, 2023 at 7:30 PM
    TacoTuesday1
    FL
    iPhone to make for sale ad and recover money
  11. Dec 27, 2023 at 7:50 PM
    RichochetRabbit
    Calm down ... easy ... you clearly missed your last week worth of your medication ... :annoyed:
  12. Dec 27, 2023 at 7:51 PM
    NorthPark
    NorthPark Well-Known Member
    Look around on local 4x4 Facebook groups, there is occasionally a recovery tutorial 'class' meetup that you can attend to get a better idea of what you need.
    Personally I'd skip the recovery boards and a hi lift jack for the time being.
    Get a few hitch pin spares, a hitch receiver or two, two soft shackles, a kinetic rope, a tow rope.
    A jack that will work for you off-road but stay away from a hi lift farm jack for now. I started with a powerbuilt jack from Amazon and still carry it with me off-road, but others get by with a tall bottle jack and a few pieces of 2x4. If you go the bottle jack route or plan to use the stock one, you can use a hi lift base plate/pad with the bottle jack for extra stability.
    A good air up/air down system. I keep preset Coyote auto deflators on hand as well as a cheap mechanical deflator.
    A good way to remove a wheel, or patch it. I keep a 1/2 breaker bar and digital torque adaptor in the truck, but on adventures I'll usually bring a 1/2 dewalt impact and a torque stick for the lugs.
    Always keep a pair of mechanix style gloves in the truck.
    I'd carry both jumper cables and a battery jump pack. At least carry the jump pack.
  13. Dec 27, 2023 at 9:04 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    If you are mostly on forestry roads, you don't need much. Recovery gear I consider essential - HiLift (with wheel lift strap), kinetic strap, air compressor, shovel, tire blocks, 4”x6” wood boards, hitch tow hook/shackle, and soft shackles. Not so essential but helpful - traction board, bottle jack, snatch block (with tree strap), winch …
    Trucks2019[OP] likes this.
  14. Dec 27, 2023 at 9:19 PM
    Ihnaer
    Ihnaer Well-Known Member
    Sacramento, Ca
    18 TRD Off-Road
    TRD pro grill TRD rhino liner’d skid plate C4Fab Front Bumper w/ winch and Baja Lights DCDC 2nd battery ARB compressor Switchpros GMRS hidden radio Expedition Essentials dash mount Old Man Emu 2" lift DCDC Trailer charging port LED taillight upgrade Weboost cell amp
    get a tool roll and all the common wrenches for a taco, a voltmeter, spare fuses, wire strippers, some crimps, a roll of electrical tape and some zip ties. that should serve well as a small go-to for any minor/major mechanical/electrical issues.
  15. Dec 27, 2023 at 9:30 PM
    RichochetRabbit
    From a perspective of "recovery from ANYWHERE", regardless of where/if you off-road ...
    NOCO GB40 to jumpstart when no one else is around to help (also has USB plugs for devices). Air compressor (I have a Viair 88P) that clamps on the battery because car-lighter-plug-in ones may overheat pumping even stock 30s to 35 PSI. Tire plug kit because nasty big/little screws and bolts live everywhere. Spare fuses just because fuses may die anywhere. A tool roll like Inhaer suggests for minor wire mishaps.
    Useful even on the freeway at a rest stop.
  16. May 19, 2024 at 8:41 PM
    VTCAL
    VTCAL Well-Known Member
    2021 Sport
    rotated tires changed oil threw out the old air freshener.
    OZ TRD likes this.
  17. May 19, 2024 at 8:43 PM
    ZColorado
    13 DCSB OR 6MT
  18. May 19, 2024 at 8:46 PM
    VTCAL
    2021 Sport
    If a HF winch suits you, Who am I to say nay? I have found the quality pullers to be very helpful in many situations that a bumper mounted winch would fail.
  19. May 19, 2024 at 10:53 PM
    Offroad Taco 2022
    Offroad Taco 2022 Well-Known Member
    Manny
    2022 TRD Offroad
    Don’t forget the rotopax with gas and water. Comes in handy more often than you would think
  20. May 20, 2024 at 5:23 PM
    Max8
    Max8 Thinking Outside The Box until they close the lid
    23 SR5 DCLB stock
    2012 ARE DCU contractor cap pending- Transmission aftercooler kit (Iconic Fabrication & Hayden 698) pending - Bed Stiffeners (Kwikfab LLC) Firestone airbag leaf springs, wye connector and pressure gauge Tailgate security mod (mfgr. by Christian06 on TW) OEM mud flaps OEM tailgate electronic lock Tow-Pro Elite Electric Brake Controller Anytime Backup Camera hardwired 42 ft to camper RCI Alum. Skid plates & cat covers 2WD LO mod (BB Tuning) Fumoto oil drain ECT Always-On Mod (hardness by Funman1steve) 6awg DC DC tow charger wiring, inline 60 amp breakers & battery terminals Kill switch KJTO driver side grab handle Hood hold open gas struts Scangauge III Seat Covers (Seat Covers Unlimited... wearing poorly) locking gas cap
    Back when I lived on an unploughed 2.5 mile road with a 2wd HiLux I carried three 50ft lengths wire rope with shackles and three come alongs. You only get a few feet pull with each puller.
    When a Wyoming BLM road culvert collapsed I was left high centered. No problem, got my gear and looked for a tree to winch off of...
    Nearest tree was over half mile away. Just scrub and rocks. Just me and the coyotes.
    A day and a half later I'd finally built a wedge shaped rock buttress that held up to pulling.
    Travel with a second vehicle in remote areas.
