Error P0504
Discussion in '2nd Gen. Tacomas (2005-2015)' started by spinso71, Sep 29, 2014.
  1. Sep 29, 2014 at 2:19 PM
    spinso71
    spinso71 [OP] Active Member
    Shawn
    Baton Rouge
    09 Tacoma 4X4
    Got this Thursday. Pulled my boat down to the coast and stopped for ice. When I got back in the truck the ABS and Slip Indicator stayed on and couldn't move it out of Park. Turned truck off for a couple of minutes and turned back on and the lights went away and resumed my travels. However, I went to Autozone today and had them scan it. The code is still there. Thought it might have had something to do with the trailer lights. The brake reservoir is filled properly and there are no obvious brake issues though I haven't yet looked at the pads. Anyone ever had this problem?
  2. Sep 29, 2014 at 2:29 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
  3. Sep 29, 2014 at 3:18 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Did all this take place after or before you launched your boat?
    I'm going to say that the trailer is where I would look FIRST.
    Especially if you have had no problems since you have NOT had the trailer lighting hooked up.
  4. Sep 29, 2014 at 3:45 PM
    spinso71
    Shawn
    Baton Rouge
    09 Tacoma 4X4
    Rear wheels don't make it near the water. It was before I launched. The dash lights are off but the code is still in the system a few days later and I havent pulled the trailer since that day.
  5. Sep 29, 2014 at 4:15 PM
    Square
    Square Well-Known Member
    Brian
    Mission Viejo, CA
    '14 DCSB SR5 4WD MGM
    Have someone sit in the drivers seat while you go to the back and make sure your brake lights are working correctly.
  6. Sep 29, 2014 at 5:35 PM
    spinso71
    Shawn
    Baton Rouge
    09 Tacoma 4X4
    I disconnected the brake light switch. removed the switch, and then replaced it. It looks like the spring loaded mechanism is working. I put it back in and was wondering how can I tell I have it at the proper depth without being able to see the rubber stop on the brake pedal. I'm guessing that there is a "feel" to it. Brake lights are working as they should.
  7. Sep 29, 2014 at 7:33 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    If the brake lights are working properly you should be set.
  8. Sep 29, 2014 at 7:46 PM
    Square
    Brian
    Mission Viejo, CA
    When Autozone checked the code for you, did they delete the code? If they didn't, you need to have the code erased. If the code comes back, you'll have to dig a little further into what is going on. If the code doesn't come back, then your problem is no longer a problem for the computer.
  9. Sep 30, 2014 at 12:37 AM
    OKJC
    OKJC Well-Known Member
    Justin
    NWArkansas
    '10 SC 4x4 TRD Sport
    I had the same issue. Checked every fuse an they were all fine. Took my brake light switch out, fiddled around with it, put it back in and things worked normally. It has reoccurred so I will do as others have said they had to do and just go buy a new brake light switch.
    Mine initially happened hauling a massive load of firewood. Must be due to the weight some how.
  10. Oct 15, 2014 at 9:59 AM
    hack4875
    hack4875 1 of 377
    Colorado Springs, CO
    2015 TRD PRO Supercharged
    I just got the same code 2 days ago. Stopped into AutoZone on way to work this morning and verified the P0504 code. I haven't towed anything in months. I am planning on doing some diagnostic testing in the garage tonight. I'll report back with what I find.
  11. Oct 15, 2014 at 6:18 PM
    hack4875
    hack4875 1 of 377
    So I tested my brake lights; work just fine. No bulbs out, no brake lights on when not supposed to be.
    I tested my cruise control; works just fine. No issues at all.
    I pulled some fuses that may have been linked to the brake system. No burned fuses.
    I crawled under my dash, disconnected the brake light switch, left it for about 5 minutes, then plugged it back in...light still on on the dash.
    ARGH.
    I guess I will order a new brake light switch, and see if that solves it. If it doesn't, I'm out of ideas for my limited mechanical knowledge.
  12. Oct 15, 2014 at 8:39 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Go to autozone and clear the code and see if it comes back. Or disconnect the negative battery cable for a few minutes and that will also clear the code.
  13. Oct 17, 2014 at 9:31 AM
    hack4875
    hack4875 1 of 377
    Stopped by Autozone and they said they cannot clear codes. They said they will get fined by the EPA or something.
    So I disconnected my battery for a few minutes. Started up truck, CEL light still on. Guess I will wait for the brake light switch in the mail and try that.
  14. Oct 18, 2014 at 6:24 AM
    spinso71
    Shawn
    Baton Rouge
    09 Tacoma 4X4
    Did you pull the old one off. If not then pull it out and disconnect the wires to it, actuate it by hand a few times, reconnect the wires and put it back it. My error went away. Hopefully for good.
  15. Oct 26, 2014 at 3:43 PM
    hack4875
    hack4875 1 of 377
    Well I got the new brake light switch in the mail. Removed the old one, installed new one. MAINT REQD light still on. I disconnected the negative battery for a good 10 minutes, and the MAINT REQD light still on.
    Dang this thing is getting annoying....
  16. Oct 26, 2014 at 3:52 PM
    Nickel
    Nickel Well-Known Member
    Diego
    Rio Rancho New Mexico
    2013 T/X TRD
    does turning tires to black wall out count? How bout added snug top rebel.
    Maintenance required is different, has nothing to do with codes.
    I think you get odometer to main mileage reading, hold down trip reset button, then turn key to on for five seconds.
  17. Oct 26, 2014 at 3:52 PM
    hack4875
    hack4875 1 of 377
    Tried this. No luck for my truck. :confused:
  18. Oct 26, 2014 at 3:53 PM
    hack4875
    hack4875 1 of 377
    Really? I had the codes pulled with the MAINT REQD light and it was this P0504...
  19. Oct 26, 2014 at 3:59 PM
    hack4875
    hack4875 1 of 377
    Nickel, you are the man. That cleared it.
    I have relatives in Albuquerque. Next time in town, I'll hit you up and buy you a beer! Thanks man! :D
  20. Oct 27, 2014 at 4:27 AM
    Nickel
    Diego
    2013 T/X TRD
    Thanks man, sounds good!
