Error codes P0420, P0125, P1130
Discussion in '1st Gen. Tacomas (1995-2004)' started by STEVEO13016, Nov 29, 2017.
  1. Nov 29, 2017 at 10:03 AM
    STEVEO13016
    STEVEO13016 [OP] Well-Known Member
    STEVEO
    2000 Tacoma Prerunner V6 2WD
    5100 Billy's set at 0" with 881 coils
    I just checked mine, and I have codes P0420, P0125, and P1130. I ran my truck for about a month with the P0420 code until yesterday, that's when I noticed P0125 and P1130. I bought an O2 sensor (upstream bank 1, w/ California emission) which came out to around 83.00 dollars... any suggestions on what else I should look into after the O2 replacement?
  2. Nov 29, 2017 at 11:01 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    The P0420 and P1130 codes very possibly will be taken care of with the new upstream A/F ratio sensor you ordered. The P0125 will prolly require a little troubleshooting. Two scenarios come to my mind, thermostat not closing and so the coolant never quite gets hot enough or the coolant temp sensor bit the dust. I've wrenched on quite a few Yotas and haven't ever come across that DTC.
  3. Nov 29, 2017 at 11:22 AM
    TaCoJoE650
    TaCoJoE650 Cars are the sculptures of our everyday lives.
    Joey
    Bay Area
    99 tacoma 2WD 2.4L
    Make sure you got/installed Air fuel sensor and not O2 sensor. They are different and usually cost much more than $83.
    For P0125 more than likely thermostat stuck open as mentioned.
  4. Nov 30, 2017 at 6:29 AM
    STEVEO13016
    STEVEO
    Thanks guys for the replay... this is the sensor I bough for the upstream bank 1 code... like you said I think I may is screwed up and got the O2 sensor and not the air fuel sensor...IMG_5316.jpg
  5. Nov 30, 2017 at 7:34 AM
    cruiserguy
    Elijah
    SEKS
    You want the Denso A/F ratio sensor. It's on Amazon for like 90 bucks or so.
  6. Nov 30, 2017 at 7:59 AM
    STEVEO13016
    STEVEO
    Would you happen to have a p/n?
  7. Nov 30, 2017 at 9:58 AM
    STEVEO13016
    STEVEO
  8. Nov 30, 2017 at 9:58 AM
    elnip
    elnip Well-Known Member
    LC,NM
    '98 Tacoma TRD S/C'd / /'16 T4R Trail
    Taco SC'd, fuel mods, Supra TT MAF, TRD Headers, Water Meth Injection, Tundra Brake upgrade Trail w/URD EL Headers. JFR EL Y-pipe, URD Hi Clearance cat back, KDMAX Tune, 4.56's
    Not all MY 2000 are A/F sensors. There are narrow band trucks out there. Depends on the mfg. date and if it is a Cali. or Fed.
  9. Nov 30, 2017 at 10:18 AM
    STEVEO13016
    STEVEO
    I'm in Cali... I just called Toyota dealership and they said that my upstream bank one sensor is in fact in air/fuel sensor
  10. Nov 30, 2017 at 10:23 AM
    elnip
    LC,NM
    :thumbsup: Well done.
  11. Dec 2, 2017 at 10:59 AM
    STEVEO13016
    STEVEO
    Here we go. I swapped out my upstream bank 1 sensor this morning with this: 47577D92-303C-430F-9C7A-B52630609DFF.jpg. When I pulled out the old sensor, this is the part number that was on it: F10EF65D-5892-4ADD-BD25-F91120E9B2AA.jpg. After going online to search this part number, nothing comes up... :notsure:... anyways, not sure how many miles I need to drive on the new sensor so see if the check engine light comes on... anyone know ?
  12. Dec 2, 2017 at 11:37 AM
    cruiserguy
    Elijah
    SEKS
    Without actually looking into it, I'd guess the original part number has been superceded....
    Wait, you bought the 'Denso' part without the Toyota insignia and mark up. So yeah that's the correct part.
    You should know in a couple/few days of driving if the new AF sensor takes care of your issue.
  13. Dec 2, 2017 at 12:24 PM
    STEVEO13016
    STEVEO
    Thanks ... I bought an o2 sensor first without knowing that I needed an air:fuel sensor... I called toyota and they in fact did tell me I needed the air:fuel sensor... we shall see in a couple days... fingers crossed
  14. Dec 2, 2017 at 3:25 PM
    TaCoJoE650
    Joey
    Bay Area
    99 tacoma 2WD 2.4L
    It shouldn't take too long for A/F monitor to run. Either of 3 things will happen.
    It will run test and pass if everything good.
    It will run test and fail and after 2 trips will set MIL (malfunction indicator light).
    Or if there is another problem causing test to never run ( for example - stuck open thermostat causing motor to not get up to proper temp).
    So if you have access to a obd2 scanner or hand held unit just plug it in and check
    O2 monitor readiness. If complete and no MIL it's fixed.
  15. Dec 8, 2017 at 12:47 PM
    STEVEO13016
    STEVEO
    All right guys… I just replaced my air/fuel sensor bank one before the cat… After resetting the check engine light, it came back on after 62 miles… Same code as before P0420… Dammit not sure what to do now...
  16. Dec 8, 2017 at 12:49 PM
    TaCoJoE650
    Joey
    Bay Area
    99 tacoma 2WD 2.4L
    Rear one is the the one that monitors convertor. Front A/F sensor controls engine fuel ratio.
  17. Dec 8, 2017 at 1:04 PM
    STEVEO13016
    STEVEO
    should I replace the rear as well? Heard this code can trigger if there is a vacuum leak as well ?
  18. Jan 20, 2018 at 12:11 AM
    helmet
    helmet helmet
    Tanner
    Anchorage, AK
    02' SR5 Ext Cab 2.7L
    Any news on this one? I have a 97 with the 2.7 thats got the P0420 code. I took both the o2 sensors off and cleaned tham and replaced the gaskets. That hasn't produced any results yet. Id like to try and nail down if it was one or the other before I start buying parts
  19. Jan 20, 2018 at 12:23 AM
    MichaelsTacoma
    MichaelsTacoma Well-Known Member
    Michael
    Sacramento
    00 TRD 4wd e-locker
    donahoe racing coilovers, Camburg upper control arms, rear bilstein 5100, wheelers leaf pack, wheelers super bumps, 33 inch Cooper discovere stt pros
    P0420 is usually a code for the catalytic converter I’ve had it for about 3 years now. I usually clear it and it’ll take a while before coming back. Cats aren’t cheap from what I’ve seen unless it’s not oem
