Error Code P0125
Discussion in 'Technical Chat' started by twistedtuk, Jan 5, 2010.
  1. Jan 5, 2010 at 5:41 PM
    twistedtuk
    twistedtuk [OP] Member
    mike
    Alabama
    1998 Tacoma
    2 Inch Lift on front. 15 inch wheels and tires. Bug Shield, Window Vent Shades, Sunroof Vent Shade.
    Hello,
    I just joined this forum for a little help. I have a 1998 Tacoma. I love this truck. I have had a check engine light on for months. I have received numerous error codes.
    I have replaced the Front 02 sensor, replaced the Air Filter, Fuel Filter, cleaned the MAF Sensor, cleaned the throttle body, and changed the Coolant Temperature Sensor.
    The latest error code was the coolant temp sensor. I replaced the Coolant Temperature Sensor yesterday and reset the light. The light came right back on. I had it checked again and received Error Code P0125 (closed loop fuel control insufficient coolant temperature. I used a meter to check the ohms on the 02 sensor and both front and rear read what my Chilton books say they should. My book also says to check at the engine side of the wire for voltage with the switch on. There is no voltage at the connector to both the 02 sensors. My book suggest checking the fuse but I have not been able to find the correct one. Does anyone have any idea.
  2. Jan 5, 2010 at 5:47 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW!
    That code on the earlier trucks (yours) is most likely pointing to the bank 1 sensor 1 A/F sensor. Check the connections, and make sure they are sound.
  3. Jan 6, 2010 at 4:27 PM
    kevhogaz
    kevhogaz Low Speed, High Drag
    Queen Creek, Arizona
    SR5 PreRunner
    3" lift front & rear, Air Raid Intake System
    What Chris said. I just went over the flow chart for repair, it pretty much directs you right to the A/F sensor. If your showing zero voltage, then I'd have to say it's bad.
  4. Jan 7, 2010 at 4:58 PM
    twistedtuk
    mike
    Alabama
    1998 Tacoma
    Thanks for the information. Don't want to seem dumb, but what is the A/F sensor and where is it?
  5. Jan 7, 2010 at 4:59 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    mass air flow sensor. it's on your air intake.
  6. Jan 7, 2010 at 5:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Its an Air/ Fuel Sensor. Its on the exhaust pipe, closest to the engine.
  7. Jan 7, 2010 at 5:03 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    oh my bad
  8. Jan 7, 2010 at 5:06 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :smack:
  9. Jan 7, 2010 at 5:10 PM
    twistedtuk
    mike
    Alabama
    1998 Tacoma
    Thanks, I do seem dumb. I just figured it out before you guys posted. I disconnected the 02 sensor and checked the voltage coming from the engine side of the wiring and found no voltage. The 02 sensor checked out ok per the Chilton maual. I have replaced this 02 sensor about 6 months ago. I can try putting the original one back in and seeing if it works.
  10. Jan 7, 2010 at 5:18 PM
    twistedtuk
    mike
    Alabama
    1998 Tacoma
    I found the answer just before you guys posted. thanks.
    I disconnected the 02 sensor and checked the voltage at the engine side of the wiring and got no voltage. I checked the 02 sensor and it had the ohm's that the Chilton book said it should have. I could put the original sensor back in to see what it would do.
  11. Jan 7, 2010 at 5:19 PM
    twistedtuk
    mike
    Alabama
    1998 Tacoma
    Sorry for the duplicate post. The first one didn't show up on my screen so I thought I didn't hit the reply button.
  12. Jan 7, 2010 at 5:20 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No worries. :) Keep us posted on this issue.
  13. Jan 10, 2010 at 4:57 PM
    twistedtuk
    mike
    Alabama
    1998 Tacoma
    Ok, update. I just took out my internet purchased 02 sensor that looked nothing like my original.
    I just drove the truck 10 miles and the light didn't come back on. Driving to work tomorrow will be 60 miles round trip starting at 4:30 a.m. I hope this does the trick. If not, I'll let you know.
    Thanks to everyone that responded to my question.
  14. Jan 11, 2010 at 11:04 AM
    ShankOttawa
    ShankOttawa Member
    Ottawa, ON Canada
    99 Xtra Cab 4x4 V6 5spd manual
    KYB MonoMax rear shocks Bilstein 5100 adjustables
    Hey Guys!! Similar problem at my end... I have code P0171 and P0125. I know 0171 is MAF, mine was just cleaned las week and code is back. It must be cooked...
    re: 0125... I'm confused as to whether it's the ECT of O2 sensors... I was going to change my O2 sensors anyway... should I wait and see what that'll do before changing the ECT?
    FYI: I have 99, 3.4L V6, 4x4, 5spd.
    Thanks!
  15. Jan 11, 2010 at 2:00 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    For the P0125 code, replace the bank 1 sensor 1 A/F sensor.
  16. Jan 11, 2010 at 3:56 PM
    kevhogaz
    SR5 PreRunner
    Fix the P0171 first, and see if the P0125 comes back. When you fix these things, always tackle the code that is first on the scan tool as the number 1 code. A lot of times, one code will set another code, and so on.
    straightawaykid likes this.
  17. Jan 11, 2010 at 4:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Great point!
  18. Jan 11, 2010 at 4:19 PM
    kevhogaz
    SR5 PreRunner
    Yup, learned that one the hard way.
  19. Jan 11, 2010 at 4:20 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    lol!
  20. Jan 11, 2010 at 6:29 PM
    twistedtuk
    mike
    Alabama
    1998 Tacoma
    Hey guys,
    After putting in the old 02 sensor and driving about 100 miles, no check engine light. Truck seems to accelerate better than it has in months. I had a bad coolant temperature sensor at first but I thought it was the 02 sensor. The replacement I bought was not the proper one.
