EP35 flasher for LEDs not working
Discussion in '1st Gen. Tacomas (1995-2004)' started by coffeybean, Aug 1, 2020.
  1. Aug 1, 2020 at 5:42 PM
    coffeybean
    coffeybean [OP] Well-Known Member
    Clarkston WA
    2003 Tacoma 2.7L 5 speed
    Tundra Front disk brakes, Recarro bucket seats, the switchback blinker/running light mod, sound insulation and new speakers. 2023 - New Bilstein 4600s, new center bearing and clutch pack.
    Based on the information found in this thread https://www.tacomaworld.com/threads...g-lights-with-switchback-leds-a-how-to.85986/ I have been trying to move to the Switchback bulbs in the front. I have been struggling to get an LED flasher that will work. I bought one from Superbright which did not work with the incandescent bulbs, then a flasher from Napa. Again nothing. I thought the flashers would work with either old style bulbs and/or LEDs. Do I need to have the LED bulbs in for the new flasher to work? These mods should not be this hard! What am I doing wrong?
  2. Aug 2, 2020 at 2:04 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Do you know the draw of your LED bulbs ??
    Are they bright enough for use in the USA?
    Some low output led bulbs do not draw enough for the EP-35 flasher to work.
    Then your bulbs might be installed Polarity wrong or just bad out of the box.
  3. Aug 2, 2020 at 6:06 AM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    You mentioned switchback? May be not your case but some switchback work only if the "white" connector is always hot. What it means the bulb (white and orange LEDs) is powered from "white" leads and the "orange" (blinking) lead is used only to control the functionality of switching between orange and white. In that case obviously the "orange" lead takes hardly any current (it is a signal, not power). That will never work with any flasher which requires a load in order to work.
    1997tacomav6 and Wyoming09 like this.
  4. Aug 2, 2020 at 8:08 AM
    coffeybean
    Clarkston WA
    RysiuM - The blinker portion of an LED bulb worked with the factory relay. I installed one LED bulb and it hyper flashed. When I turned on the flashers all bulbs worked.
    Wyoming09 - Neither relay worked with the incandescent bulbs. There should have been plenty of current draw in this configuration.
  5. Aug 2, 2020 at 10:20 AM
    RysiuM
    Rysiu
    Regarding EP35 it should work with LED and incandescent bulbs http://novitatech.com/?q=aftermarket/products/electronic-flashers/ep35
    Stock flasher worked without hyperflashing with one LED (tail) and one incandescent (front). I used 5W 0.4A LED bulb. Stock flasher hyperflashed when two (front and back) LEDs were used.
  6. Aug 2, 2020 at 4:38 PM
    coffeybean
    Clarkston WA
    So my question is, if the EP-35L from Napa is supposed to work with incandescent bulbs why wont it? One thought is I am installing incorrectly. Not that I am the best mechanic but I do have a few hours under a hood. Two bad units from two different sources? That seems unlikely. The vehicle? Maybe. As far as I know it is very close to stock.
    What if I modified the stock unit? What are the values needed for the resistor to have it happily operate LED bulbs?
  7. Aug 2, 2020 at 7:54 PM
    coffeybean
    Clarkston WA
    Update: I pulled the interior fuse box and double checked my installation. I was installing the part correctly. I later found this thread https://www.yotatech.com/forums/f2/...de-fixing-fast-blinkers-after-led-swap-80626/ and drilled the hole to disable the bulb out circuit but I misread the docs and killed the relay. So much for my wrenching skills. Tomorrow I will get another stock relay and do the mod correctly.
  8. Aug 4, 2020 at 8:08 PM
    coffeybean
    Clarkston WA
    I bought a NAPA EP35 which functionally the same as the OEM part but not the same on the inside. Out comes the dremel and I removed about 75% of the material on their version of the resistor loop. Blinkers and flasher are now at an acceptable rate. Next to pull power to the running lites on the switchbacks.
    Thanks for all the help.
  9. Jan 2, 2025 at 2:24 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    This doesn't work anyways. I hit the right pin, and it still doesn't flash correctly.
  10. Jan 2, 2025 at 2:51 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Led's have little resistence. An incandesnt fixture requires resistence to work. The other way around the led's will hyper flash.
