Entune radio hidden menus and diagnostic screens
Discussion in 'Audio & Video' started by skydealer, Apr 19, 2014.
  1. Apr 19, 2014 at 12:01 PM
    skydealer
    skydealer [OP] Member
    Georgia
    2104 Tacoma Prerunner SR5
    Seems to have the "shopping cart magnet" modification installed.
    This may come in handy if anyone has problems where they want to check out functions or perhaps if they think one of their steering wheel radio control buttons are intermittent.
    With your call off, lights off, foot off brake, car in park:
    Put key in ignition and turn on power, do not start car.
    Wait for radio to come on and past the splash screens.
    There are 2 sections - press either the AUDIO or the APPS button as they both displayed different diagnostic sections and continue to hold down the button. Turn headlights on and off 3 times - you can now release the APPS or AUDIO button (whichever you selected).
    This worked on my 2014 Tacoma Prerunner with the middle of the road Entune package.
    (use at your own risk, for information purposes only, not for human consumption, etc etc etc)
    JasonArizona, JIMMEISTER and SR-71A like this.
  2. Apr 20, 2014 at 3:37 PM
    dm1215al
    dm1215al Well-Known Member
    Dan
    Fl
    2014 TRD Offroad 4x4
    Step tubes,Window tint, HomelinK rear view mirror, changed the entune image screen Rear Differential Breather Relocation Extended AC condensate hose KB Voodoo tailgate cap Redline Tuning QuickLIFT ELITE hood lift system.
    Thanks for this.
    Will the displays disappear after you turn off ignition and turn back on?
  3. Apr 20, 2014 at 5:27 PM
    skydealer
    Georgia
    That's what I had to do to get it to return to normal. I'm hoping to find some secret combo to unlock a few things or the ability to add programs. I read that the Entune programming is mainly java.
    brockefellar and SR-71A like this.
  4. May 7, 2014 at 10:53 AM
    justkilintyme
    justkilintyme New Member
    Jesse
    SE Florida
    '14 PreRunner
    This works on the Prerunner SRS no Nav unit. I don't know what most of the info/screens mean though. Another observation: Holding the power knob for a few seconds will turn the radio off. Turning it back on (again pressing the knob, without turning key off/on) and you can go back into the diagnostics screen(s) using the above method.
    Has anyone else had the radio just re-boot as if the ignition had been turned off then on? This happened to me 3 times today, twice in the morning on the way to work, and once at lunch. Has happened a couple times in the past as well. Any ideas?
    I hope I haven't hijacked this thread.
  5. Jan 10, 2015 at 9:10 AM
    USMC War Machine
    USMC War Machine Active Member
    Chicago, IL
    2013 Double cab-TRD Offroad-Short bed
    TRD Off Road Package
    Just thought I'd add some info to this thread. I have a 2013 dcsb with the JBL Entune w/ navigation. The above method works for me with the only difference being that the audio and the setup buttons bring up diagnostic information. To exit the hidden menu, just hold down the Setup button.
    Also another menu can be found by
    1) press the setup button
    2) press the general settings button
    3) scroll down to volume settings
    4) choose any of the volume change buttons. (I used Navigation Prompt Volume)
    5) touch the screen in the middle far right side just under the back arrow then touch the screen on the button right corner and continue alternating pressing those two areas of the screen. A hidden menu then pops up.
  6. Jan 10, 2015 at 9:15 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Point of doing this isssssssssssssssssssssss what?
  7. Jan 10, 2015 at 9:53 AM
    USMC War Machine
    Chicago, IL
    The first menu allows you to run diagnostics on certain items in your vehicle like check for dead pixels on the lcd, check the microphone functionality, antenna functions + quite a few other things.
    The second hidden menu allows you to reset and re calibrate certain things on your head unit. You can actually do a full factory default reset and troubleshooting if your head unit is having issues. Also get information about software versions and hardware information. Lots of menu options. Better to try it out and explore all the options.
  8. Jan 10, 2015 at 9:56 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Ahhhhhhhhhh
  9. Jan 10, 2015 at 10:21 AM
    eazyrider711
    eazyrider711 Well-Known Member
    Jay
    Northern, CO
    Black DCSB T|X Baja
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/289157-2013-head-unit-radio-reboots.html
  10. Aug 16, 2018 at 8:02 PM
    jkcashin
    jkcashin Well-Known Member
    Jamie
    Ottawa, Ontario, Canada
    2017 TRD OR AC MT
    Anyone ever figure out how to do this for 3rd gen?
  11. Jan 2, 2019 at 10:43 AM
    dilbert
    dilbert AI Member
    PNW
    2019 DCLB TRD Off-Road
    jkcashin[QUOTED] likes this.
  12. Dec 14, 2019 at 4:28 PM
    iCyrius
    iCyrius New Member
    I am trying to reset my radio's bluetooth and followed your steps. After selecting the General button, there is a another button with "Set Factory Defaults & Reset Nav Calibr", after that it asks me "Restoring factory defaults requires a system reset. Continue?"
    Has anyone gone beyond this point. I would like the factory defaults, except I am not sure about the part that it requires a system reset. Does this require having some type of factory installation disc?
    Thank you all for your help!!!!!!
  13. Dec 18, 2019 at 10:42 AM
    PhenixFord
    PhenixFord Well-Known Member
    Randy
    Arkansas
    2019 MGM SR5 4WD DCSB
    Just returns everything to factory settings and erases any "user" stored information. IE: radio presets, MPG Data, Navigation Presets (Home and destinations).
    You will be fine.
  14. Jan 6, 2020 at 8:52 AM
    Hammer40
    Hammer40 Well-Known Member
    SW Washington
    '96 Tacoma (sold). '05 DCSB TRDOR(sold) '17 DCLB TRDOR (Traded)
    tonneau cover.
    jkcashin likes this.
  15. Oct 9, 2020 at 2:55 AM
    Tacoma XSP
    Tacoma XSP Member
    Frank
    Tacoma XSP 4X4
    I am trying to do the same thing...what worked? Thanks.
  16. Dec 6, 2020 at 1:52 PM
    TacOntario23
    TacOntario23 Member
    2014 Tacoma Limited MGM
    I have reset my unit when bluetooth has stopped woking altogether on me. Followed OP's direction holding down APPS and flicking lights on 3 times. Menu comes up and has INIT button highlighted in red at the bottom. Push and hold it and message pops up asking to "Initialize Personal Data?". Select yes and will reset the unit to all factory defaults. Shut the truck off an on again and all was good. Didn't remove my splash screen either
  17. Nov 20, 2021 at 11:57 AM
    triptheninja
    triptheninja Active Member
    South Sound area, WA.
    '12 DCSB TRD OR, Suzuki DR650
    3 Year old Bosch Wiper Blades
    This worked for me to reset my Bluetooth. Thank you guys for the info.
  18. Jul 31, 2024 at 4:31 AM
    broadwaydrummer
    broadwaydrummer New Member
