Entune issues after Apple iOS Upgrade
Discussion in '3rd Gen. Tacomas (2016-2023)' started by iamdrumming, Apr 20, 2022.
  1. Apr 20, 2022 at 7:39 AM
    iamdrumming
    iamdrumming [OP] New Member
    Rob
    2016 Tacoma TRD
    I updated my iPhone yesterday to iOS 15.4.1 and now the Toyota app won't connect to my truck.
    I click on connect, it spins and just goes back to the same screen and nothing happens.
    I've tried:
    • Disconnecting and re-connecting Bluetooth
    • Removing and re-adding my phone to the truck.. (everything else works fine)
    • Removing and re-adding my vehicle to the Toyota App
    • Re-installing the Toyota App
    • Soft and hard resets on the head unit
    I'm assuming this is a Toyota App issue and they will eventually push a fix for it, but was wondering if anyone else is seeing this issue.
    Thanks,
    Rob
  2. Apr 20, 2022 at 7:41 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    My radio just pushed an update this morning...not sure if that is to fix your issue or not but its the first time I've updated the head unit in the truck.
    iamdrumming[OP] likes this.
  3. Apr 20, 2022 at 8:30 AM
    howmuch4onerib
    howmuch4onerib i sure am hungry
    Marc
    Seattle
    '21TRDORDCSBLOLOMFGTLDRIDC
    updated entune this morning as well.
  4. Apr 20, 2022 at 10:25 AM
    iamdrumming
    Rob
    2016 Tacoma TRD
    I tried that, it doesn't look like my Entune needed an update.. I'll double check
  5. Apr 22, 2022 at 6:12 AM
    mastro1
    mastro1 Well-Known Member
    2017 MGM DCSB TRD Sport
    Yup, I'm having the same issue... the app suite wont load.. so iheart, alexa will not work. Did pretty much the same things you did. hopefully they will fix it.
  6. Apr 22, 2022 at 6:46 AM
    Ahomeofbones
    Ahomeofbones Member Well-Known
    2021 TRD OR
    I use Android but have been having issues with freezing the past week. Reset the unit to factory. Nothing. Brought the truck in for an update, didn't fix it. Was told to try a new oem Samsung cord and if that doesn't work they will replace the head unit. I think they botched an update. Let me know what y'all find.
  7. Apr 22, 2022 at 7:03 AM
    TheBeerBladderMonster
    TheBeerBladderMonster Active Member
    2021 4x4 Toyota Tacoma SR Access Cab
    Tonneau Cover and Side Rails
    Got the same thing I think. I was wondering if someone was gonna post about this.
  8. Apr 22, 2022 at 7:36 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Are you guys using the Toyota or Engine app? My head unit is telling me to use the Toyota app. I don't normally use the features, but just yesterday I attempted to use the gas finder thingy and it kept telling me to open the Toyota app on my phone, which I did, it showed my truck, and the head unit kept coming up blank, just telling me to open the app.
  9. Apr 22, 2022 at 10:31 AM
    iamdrumming
    Rob
    2016 Tacoma TRD
    I am using the new Toyota app on an iPhone (the Entune app was discontinued). Seems this happens whenever an iOS update is pushed to the phone. Eventually Toyota will have to fix the app to be compatible with the new iOS. I'm glad I'm not the only one... I've tried everything possible to fix it and conclude the app is messed up.
    Chew likes this.
  10. May 6, 2022 at 9:33 AM
    iamdrumming
    Rob
    2016 Tacoma TRD
    They finally fixed it. Forced to log out and back in to the Toyota app. Tacoma connected to the app suite and all the apps downloaded and working on my head unit, including iHeart Radio which is the one I use.
  11. May 6, 2022 at 6:00 PM
    Trungtaco
    Trungtaco Well-Known Member
    Thomas
    Las Vegas
    2018 Toyota Tacoma TRD Offroad 4X4 DCLB
    Fox 2.5 DSC all around, Dirt King UCA/LCA, Icon RXT Leafs pack option 2, Archive hammer hangers.
    following.
  12. Aug 11, 2022 at 11:41 AM
    ebsoria
    ebsoria Well-Known Member
    Ville of the Rose, NorCal
    '18 D-Cab 4WD TRD Sport
    Arg! I never though to check for update on the truck side. My unit recently started telling me some sort of issue connecting my iPhone to truck and to check owner's manual while plugged in through the USB. If I unplug and plug in a few times it'll correct the issue..... time to check the truck for update!!
