Engine turns over but won't start
Discussion in '1st Gen. Tacomas (1995-2004)' started by hawkeyefan, Dec 27, 2013.
  1. Dec 27, 2013 at 10:40 AM
    hawkeyefan
    hawkeyefan [OP] Member
    Ben
    Fort Riley, Kansas
    1995 Toyota Tacoma
    Recently my 95 Tacoma will not start. I have replaced the fuel filter, fuel pump, and starter. The engine will crank but won't run. When i turn the key it just continously cranks, and sometimes sounds like it wants to go but won't. I have bled the fuel lines, and ensured i have spark on my plugs. I really am stumped and wondering if anyone else has had this problem or can point me in the right direction.
    Jrome729 likes this.
  2. Dec 27, 2013 at 10:54 AM
    Large
    Large Red
    Do you have an alarm? When you turn the key forward do you hear the fuel pump come on?
  3. Dec 27, 2013 at 10:59 AM
    josh843
    josh843 Well-Known Member
    Josh
    moncks corner, sc
    2001 reg cab prerunner
    which motor?
    make sure fuel filter is flowing right way and tight banjo bolts good
    check battery/cables/voltage
    also what large said
    check plugs
    basiclly just start from fuel tank and work towards motor, eliminating items..
    dont forget muffler bearing adn blinker fluid :gossip:
  4. Dec 27, 2013 at 12:11 PM
    hawkeyefan
    Ben
    Fort Riley, Kansas
    1995 Toyota Tacoma
    I have the 2.7L 4 cylinder motor. The fuel pump does come on and their is fuel flowing through the filter. I have put a new filter on in the last 6 months so that isn't the issue as well. I have checked the plugs, which are only 4 months old, and they are producing spark. i was thinking it might be the timing belt or maybe a blown head gasket. Just didn't know if that was a common issue with this year of truck.
  5. Dec 27, 2013 at 1:51 PM
    josh843
    Josh
    moncks corner, sc
    I had a 92 w 22re timing chain popped an did the same thing ur saying. Not sure on ur motor but the 22re you can take the distributer off and stick ur finger in and hopefully you'll feel the chain on the sprocket and not just the sprocket. Check oil for head gasket failure
  6. Dec 27, 2013 at 1:57 PM
    josh843
    Josh
    moncks corner, sc
    Also how was the truck running before? Fine? Or was it a slow problem then finally gave out? Before my chain broke it was making a loud banging sound for skipping links or jumping time or somethin when I cranked it up.. Also just because you replaced parts recently doesn't mean they're not the problem. Parts do fail for no apparent reason, and most times it's the things you've recently messed with that are the culprit. You could also remove the valve cover and get someone to turn the ignition while u look at the valve train. No movement = timing chain/belt failure most likely
  7. Dec 27, 2013 at 2:39 PM
    hawkeyefan
    Ben
    Fort Riley, Kansas
    1995 Toyota Tacoma
    My truck ran great before all of this. The only issue i had was that it was kind of hard to start in during cold weather. I would pump the gas a few times and she would start right up. Other than that no problems, and once i got it started for the day it would start fine the rest of the day.
  8. Dec 27, 2013 at 4:19 PM
    josh843
    Josh
    moncks corner, sc
    Check oil and for belt/chain
  9. Dec 27, 2013 at 4:53 PM
    josh843
    Josh
    moncks corner, sc
    Although that sounds like fuel delivery problems, any codes? If not... Another new filter, go in through intake with 24" extension and universal joint with 10 or 12 mm, can't remember, lot easier than other ways. Do that or/then check voltage at ignition coil, could also be problem, mabe getting power/spark but not enough. AND GO TO LOCAL PARTS STORE AND BUY HAYNES MANUAL!!!!!!!, truly an invaluable tool. Keep me posted. Want to know what the deal is.
  10. Dec 27, 2013 at 5:00 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Ignition Control Module, perhaps.
    [​IMG] or Crank Position sensor, maybe.
  11. Dec 27, 2013 at 6:12 PM
    fpradojr36
    fpradojr36 Well-Known Member
    J.R.
    90804
    04 Prerunner, 2019 TRD 4x4
    I have an 04 tacoma. I had similar issues with mine. But mine would act up after being warmed up and trying to turn on again. It would crank and want to start but wouldn't . After a couple of weeks of diagnosing off and on I found a bad IAC valve. Not saying that's what yours is, but if you checked out all what you said it could be it.
  12. Dec 28, 2013 at 3:09 PM
    hawkeyefan
    Ben
    Fort Riley, Kansas
    1995 Toyota Tacoma
    After all day of ruling out problems we are still at a stand still. I have confirmed that it isn't the timing belt, put a new ignition coil in it and the spark is good, fuel pump still works, and there are no codes being thrown. It seems of fuel really bad so i'm thinking i may have flooded it. I'm going to let it rest tonight and clean the plugs tomorrow morning. try again. if not i'm going to run it to a shop and find out what the problem is. I'm putting a lot of time and money into this with no results.
  13. Dec 28, 2013 at 5:14 PM
    HBtaco02
    HBtaco02 Well-Known Member
    Allen
    Huntington Beach
    02 4wd SR5 TRD
    ARB Front Locker grey wire mod Camburg UCA's Extended Kings All-Pro expo's 10" Bilstien Brute Force Hybrid front bumper Smitty XRC8
    ECM? That's what happened to mine.. if you know someone with the same truck swap ECM's out...
  14. Dec 28, 2013 at 6:18 PM
    hawkeyefan
    Ben
    Fort Riley, Kansas
    1995 Toyota Tacoma
    My question is if it was a sensor wouldn't it throw a code? I had it hooked up to a code reader today and didn't get any.
  15. Dec 28, 2013 at 8:24 PM
    josh843
    Josh
    moncks corner, sc
    I would imagine so. If it was just a sensor, but mine never threw a code when my chain popped. Everything worked just there was no valve train movement to finish the combustion process. I'm bettering its something simple, and those are often the hardest things to find because you overlook them so easily. Prob a bad wire or something like that. Like I said be thorough from tank to motor. That's all the mechanic u take it to is going to do. Mechanics 101 process of elimination
  16. Jan 7, 2014 at 2:23 PM
    Rickalders
    Rickalders Well-Known Member
  17. Jan 7, 2014 at 2:31 PM
    Rickalders
    Even with a partially obstructed fuel filter, it should start and idle. You might have problems with fuel starvation under heavy load (floored or up hills) but it should still idle. If you have spark, check the fuel injectors to make sure you're getting fuel. Either use a noid light or a stethoscope to make sure the injectors are firing. If they pulse once and only once, it could still be an ignition problem as the systems are interrelated. If they pulse continuously while cranking, you know they're working. You might want to disconnect all the injectors to do this test to avoid flooding the engine.
  18. Jan 8, 2014 at 2:45 AM
    Loggerhead
    Loggerhead Well-Known Member
    Seán
    Alaska
    2002 SR5 TRD 5spd 3.4 Xtra Cab
    Are you getting fuel at the fuel rail? Have you checked compression? You can test resistance across the coils to see if they are in spec but if you're getting spark they are probably good. Pull timing cover to check the timing chain.
    Hope you're able to figure it out without too much more trouble. Troubleshooting can get really frustrating
    Edit: you can also put a screwdriver to your injectors and listen through it to see if your injectors are firing. You should hear clicking from them.
  19. Jan 8, 2014 at 8:42 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    A faulty fuel pressure regulator could prevent sufficient pressure in the rail.
  20. Jan 8, 2014 at 9:29 AM
    Rickalders
    I think that's a bit extreme. If you have compression on all cylinders, the chain is fine. Plus, even cranking an engine with a broken chain makes such a different than normal sound, no one could miss it.
