Engine swap, 3.4 to a Toyota 4.0, good idea?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Detiv, Mar 17, 2015.
  1. Mar 17, 2015 at 6:12 PM
    Detiv
    Detiv [OP] New Member
    Joe
    Georgia
    Black 01 PreRunner DoubleCab SR5 TRD 2WD V6
    Has anyone done a swap from the 3.4L to the 4.0L? I have a 2001 PreRunner DoubleCab 4x2 TRD, and I may have a cracked head or blown head gasket on my 3.4L. I have 166,000 miles on it, and I've heard that the repair,( new gasket, new head, or both) can get pricey, and there is no guaranty on how long it would last before something else happens. I saw where someone had asked about swapping to a small block V8 and they were told it would be pretty tough and expensive. One guy suggested the Toyota 4.0 or a supercharger. Well, a supercharger would do me no good at this point, so, I figured I'd ask about the 4.0. I'm curious if this would even be a good idea. Would I be able to swap in a Toyota V8? I'd like to keep the same transmission and rear end.
  2. Mar 17, 2015 at 6:16 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    No, not a good idea. If I had a 2nd gen, I would be doing it the other way.
    3.4L > 4.0L
    But in all seriousness, again no. For the same price, you can get a built 3.4L and its would be way easier to drop in.
  3. Mar 17, 2015 at 6:26 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    The 4.0L is a better engine, but you'd have to deal with integrating the 2nd gen ECU and throttle-by-wire controls. The ECU also controls the transmission, so you'd need the 2nd gen 5-speed auto (fine transmission, but again, more work for you).
  4. Mar 17, 2015 at 6:42 PM
    Tinmann
    Tinmann Well-Known Member
    NorCal
    COMAtized transplanted a Tundra V8 into his 1st Gen several years ago I think. Maybe you can do a search and locate his post. I think it is very labor intensive if you decide to go that route.
  5. Mar 17, 2015 at 6:50 PM
    Idaholandho
    Idaholandho The other white meat
    3 Now - 2022 Trail Edition, 2015 TRD 4x4 and a 2006 SR5 4x4
    2015 Tacoma, Magnuson Supercharger, Bully Dog Flash and GT, Safari Snorkel, Toytec BOSS 2.5 Coil Over Front, Toytec BOSS Aluma 2.5 Rear, Toytec 10 Leaf Pack, Stainless Brake Lines, Icon UCA's, CBI Reverse Adj Shackle Mounts, CBI Ubolt Flip Kit, Timbren Bump Stops, CBI Bushmaster 2.0 Front Bumper w/ Warn M8000S Winch and SR2 Rigid Flood Lights, CBI Bushmaster 2.0 Rear Swingout Bumper, Rigid SR2 backup lights and Dual RotopaX / Fuel/First Aid Pack, CBI Rock Sliders, CBI Full Skids and CBI Rear Diff Armor, BAMF LCA Skids, FrontRunner Outfitters Slimline II Roof Rack w/ Rigid SR2 40" Combo Light Bar, Rock lights, Rigid pods in Bed Rack, Intelligent Battery System w/ Dual NorthStar batteries, Spod Power Distribution, illuminated switch panel in sunglasses holder, Viar Extreme Duty On-Board Air w/ 2.5 Gallon Tank under bed, Air 2 Air Sys, Magnaflow Exhaust, Fuel Off Road Trophy Wheels, 285/75/17 Toyo Open Country R/T, Diff breather mod, FX-R BHLM Demon Eye headlights, Esuse LED Fog Kit, Pelfreybilt Camera Relocation mount, Pelfreybilt ax/shovel bed mount, Debadged, tint, a 2006 Tacoma SR5 and a 2022 Trail Edition
    I installed a crate Chevy Vortec 4.3 LUC in a 1987 4Runner with the help of Advanced Adapters mounts with plenty of room, power and fuel efficiency. I sent the ecu to a company in Cali that programmed it and built the wiring harness very reasonably.
  6. Mar 17, 2015 at 7:04 PM
    Tinmann
    NorCal
    Awesome! I would think that'd be the way to go. I wish that I didn't live in a smog check required area of the state!
  7. Mar 17, 2015 at 9:15 PM
    Idaholandho
    Although I had the 02 sensors canceled in the reprogram they could of left them to allow for a passable exhaust :).
  8. Mar 18, 2015 at 12:06 AM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    If you are going to do that much work, why not just V8 it instead? Be the same amount of work involved, but you have more power! A guy on here has a 4.7 V8 from a Tundra in his first gen and it's a screamer from what he says.
  9. Mar 18, 2015 at 7:51 AM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
  10. Mar 18, 2015 at 9:53 AM
    KenLyns
    Belly of the Beast
    ^COMAtized99 had the 5-speed manual, which simplifies things a bit. Not sure if the 1st gen Taco's 4-speed auto had its own control electronics or used the engine ECU.
  11. Mar 18, 2015 at 6:14 PM
    Detiv
    Joe
    Georgia
    Man, I do appreciate all the advice. I love the V8 swap. I would love to make mine 4 wheel drive too. I got a call today saying that all I need is plugs, wires, and a good fuel system cleaning. The plug wires are bleeding out the sides and the plugs are showing wear. Both were changed just over a year ago. Now, the wires are AC Delco, and I can't remember, but I think I put the stock plugs in, they are the dual ones, and I've only put about 13,000 miles on them. They say that's what my problem is. (Misfire on #6) We'll see. I'm praying they are right. Compression test I did showed 150psi on #2 after about 2-3 revolutions and 120psi on #6 after 6-10 or more revolutions. They said they KNOW that the plugs and wires will fix it. I do know I need the throttle body and injector cleaning.
  12. Mar 18, 2015 at 6:19 PM
    KenLyns
    Belly of the Beast
    ^Lol, GM strikes again. Get Denso wires which are OEM-grade and $10 cheaper than ACDelco.
    I suppose the problem could also be the ignition coil, but it would be more likely to affect both cylinders it's driving.
