engine sputtering after cleaning with water and degreaser
Discussion in 'Technical Chat' started by Toyota Stan, Jan 21, 2018.
  1. Jan 21, 2018 at 6:03 AM
    Toyota Stan
    Toyota Stan [OP] Active Member
    Ugh,
    First time I ever cleaned an engine yesterday with hose water and degreaser.
    So I have a Toyota Tacoma 2002 and covered the battery, alternator, wires. etc.
    Had about 7 bags in place.
    Degreased engine and sprayed water with hose all over the place yesterday.
    Well now when I start truck, it sputters and water is coming out the tailpipe, ugh.
    So,
    Is it ok to run truck in idle ? Could it be spark plugs got wet ? or distributor cap ?
    Help !! I'm never, ever putting water on my engine again.
    Stan
  2. Jan 21, 2018 at 6:14 AM
    20tacoma17
    20tacoma17 Well-Known Member
    2017 DCLB Sport AT
    Kings, 275/70/17, a few custom items, lots of Meso mods.
    Does that year have a distributor cap? If so take it off and blow out the inside of the cap. May have got moisture in there. Also if you have a compressor and blow tip, blow out around plugs, coil etc.
    Toyota Stan[OP] likes this.
  3. Jan 21, 2018 at 6:17 AM
    Toyota Stan
    Not sure on distributor cap, but will find out from neighbor. Thanks for advice sir. Is it ok to drive truck or start and idle ?
  4. Jan 21, 2018 at 6:20 AM
    20tacoma17
    2017 DCLB Sport AT
    It's not uncommon for a engine to run a little rough after cleaning. I would let it idle a bit with hood closed to keep the heat in but would blow things off first if you can? Many times it will fix itself as it dries out.
  5. Jan 21, 2018 at 6:20 AM
    Forshee47
    Forshee47 Well-Known Member
    Trent
    North Carolina
    2015 Off-road DCSB 4x4
    A small amount of water coming out the exhaust while it’s cold isn’t unusual. Most likely just got water or degreaser in a plug for one of your sensors. I would start by checking all the plugs around you air intake system. Like said above just unplug them blow them out and try again. A little bit of water causing a bad reading could be all the problem is
    20tacoma17 likes this.
  6. Jan 21, 2018 at 6:54 AM
    medic2230
    Murph
    Bama! Roll Tide
    4 or 6 cylinder? On the 4 the o-rings on the plug wires get old and will let water down around the plugs shorting it out and can cause that.
  7. Jan 21, 2018 at 7:09 AM
    Markcal
    Markcal Well-Known Member
    I don't mean to be critical of your post, but that was tough to understand.... "tell me" or better yet tell the OP, that's why he made the thread and we are all here to learn from your "TONS" of experience, but next time please add a few more exclamation points.
    wilcam47 and JGO like this.
  8. Jan 21, 2018 at 7:17 AM
    Markcal
    Your post is self explanatory comprehension-wise, remember this isn't a PM, so any member of TW has the right to post their opinion, so sorry to get your panties in a bunch.
    wilcam47 likes this.
  9. Jan 21, 2018 at 9:27 PM
    Toyota Stan
    All good guys.. I'm up and running.
    Blew out the cylinder #6 and some water came shooting out. Also blew out the air filter. Tacoma now runs smooth as silk.
    Put 28 miles today.
    Love my 2002 Toyota Tacoma !! Next week I'm splurging for a paint job and running another 150,000 miles !!
    $6800.00 Paid in full, cash.
    Toyota Stan
  10. Jan 21, 2018 at 10:32 PM
    20tacoma17
    2017 DCLB Sport AT
    That's great news. Glad it's up and running...
  11. Jan 21, 2018 at 10:38 PM
    black coffee
    black coffee A is A.
    Glenn
    509
    2010 AC 4x4 SR5 V6
    No distributor on that truck.
