Engine shut off while driving
Discussion in '3rd Gen. Tacomas (2016-2023)' started by sphornet, Sep 21, 2021.
  1. Sep 21, 2021 at 8:03 AM
    sphornet
    sphornet [OP] Active Member
    2021 ORDCSB MT I have about 12,000 miles on truck. Driving home from the mountains of West Virginia to Maryland. I put the transmission in neutral as I was going down a steep decline. Probably doing around 80 mph when the engine shut off. Pulled to the side and restarted no problem. Next decline I did it again and the same thing happened. Needless to say I didn't try anymore. Anyone heard of or had this happen?
    Roberto123 and MOC221_ like this.
  2. Sep 21, 2021 at 8:04 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Why are you putting a vehicle in neutral while it coasts?
    If you wish to control speeds while descending, you normally go into a lower gear.
  3. Sep 21, 2021 at 8:05 AM
    cryptolyme
    cryptolyme Well-Known Member
    Virginia
    2021 SR Access Cab 4x4 2.7L
  4. Sep 21, 2021 at 8:05 AM
    sphornet
    Its a manual transmission so why not?
    I wasn't trying to control speed. It was the perfect descent to simply coast.
  5. Sep 21, 2021 at 8:06 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Regulating speed, for safety reasons to start off with.
    Safety should be your number 1 priority.
  6. Sep 21, 2021 at 8:07 AM
    sphornet
    Burn less fuel in gear then coasting in neutral? I think not.
    Unsafe to coast down a hill? Please explain.
    SunRunner, tcjacado and Roberto123 like this.
  7. Sep 21, 2021 at 8:08 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Fuel pump? What year?
    whatstcp and Tacospike like this.
  8. Sep 21, 2021 at 8:08 AM
    Delta09
    Delta09 OSHA Violator
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Engine management cuts fuel on decel in gear. Idling uses fuel.
  9. Sep 21, 2021 at 8:09 AM
    sphornet
    Thanks for the safety meeting but I have been driving for 40 years. Let's stick to the topic if possible.
    Guydlow, Jerry311SD, Anton338 and 6 others like this.
  10. Sep 21, 2021 at 8:09 AM
    ajmogen
    ajmogen Well-Known Member
    Aaron
    Wisconsin
    OR MT TACO T4R YARIS MT Corolla Hatchback MT
    Same thing happened to me, my oil catch can unscrewed itself. Probably not your problem though
    Hobbs likes this.
  11. Sep 21, 2021 at 8:09 AM
    cryptolyme
    Virginia
    the fuel shuts off when you are coasting in gear. and in neutral you are actually putting more wear on your transmission because instead of the torque converter slipping, the internal clutches in the transmission are slipping. The ECU will actually shift to neutral automatically if necessary (like stopped at a light).
    this isn't a 1980s truck.
    Astr0Aar0n and Kev250R like this.
  12. Sep 21, 2021 at 8:11 AM
    ajmogen
    Aaron
    Wisconsin
    MT
    SR-71A, Anton338 and Skydvrr like this.
  13. Sep 21, 2021 at 8:11 AM
    sphornet
    Bro its a manual transmission..............................Thats what MT means.
  14. Sep 21, 2021 at 8:11 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    You asked us to explain it so we did... :rofl:
    CalcityRenegade and Kev250R like this.
  15. Sep 21, 2021 at 8:12 AM
    sphornet
    See first sentence....................
  16. Sep 21, 2021 at 8:14 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
  17. Sep 21, 2021 at 8:15 AM
    sphornet
    There has been zero explanation of the topic..............
    Toyko Joe and Roberto123 like this.
  18. Sep 21, 2021 at 8:18 AM
    sphornet
    I already have 5 friends. Actually trying to whittle that down to 3.
  19. Sep 21, 2021 at 8:24 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I've coasted down long hills in neutral that were just right to hold the speed that I wanted and the engine just purred along at idle. Interestingly per the display, this yields better mileage because those hills still take some throttle when in gear to maintain speed. Coasting in gear had too much engine braking.
    It might be a difference between the non-TSS-P and TSS-P Tacos? I know that for the TSS-P ones (2018+), folks can shift gears and it will keep CruiseControl engaged after the shift.
    IIRC, it was around 5% or 6% grades at about 65mph or 70mph where things balanced nicely.
    G8R_Taco and tcjacado like this.
  20. Sep 21, 2021 at 8:41 AM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Nope, and this is the first time I've heard of it.
    Not apples to apples, but my truck is a '19 MT with TSS.
    I rarely coast downhill in neutral though, FWIW.
    shakerhood likes this.
