Engine Revving while on Brake
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ShootyzGruve, Dec 8, 2016.
  1. Dec 8, 2016 at 5:06 AM
    ShootyzGruve
    ShootyzGruve [OP] Member
    Hi all,
    2016 TRDPro 6MT in question. When Im on the brake in traffic, the engine picks up a bit and revs to roughly around 1200rpms. I checked and the brake pedal is not mashing a floor mat into the gas pedal. Anyone have a similar thing going on?
    Thanks!
    Skeeter42 likes this.
  2. Dec 8, 2016 at 5:32 AM
    TacoMan2017
    TacoMan2017 Well-Known Member
  3. Dec 8, 2016 at 5:41 AM
    Pittrider
    Pittrider Pitty, those needing correction.
    Greg
    B.C.
    2016 MGM LTD LB
    Do you need to know, or care?
    It's normal for the engine to jump a little rpm while at stop. Defroster, air conditioner, little pressure on steering wheel all put load on the alternator causing bump in rpm. 1200 is extreme though, maybe a 100rpm jump would be a more normal. Unless you are talking about a cold motor that is already revving high to warm itself up, then ya, could be that high with a jump.
  4. Dec 8, 2016 at 8:19 AM
    oorah54
    oorah54 Well-Known Member
    Darren
    Guyton, GA
    2015 Blue Tacoma Base
    I think I've noticed it as well. Almost as if the torque converter is partially locked because as soon as I let off the brake the truck jumps out of the gate. Not just an easy roll into it like you typically feel when you let off the brake and let it roll.
  5. Dec 8, 2016 at 8:25 AM
    highwhey
    highwhey Well-Known Member
    Alan
    Phoenix
    2016 Tacoma OR m/t
    yes, my truck likes to do the same. i have 16k miles, going strong.
  6. Dec 8, 2016 at 8:25 AM
    walterj
    walterj Well-Known Member
    PA, USA
    Sexy Black '17 Taco 4x4 DCSB TRD Off-Road 6MT
  7. Dec 8, 2016 at 8:31 AM
    ShootyzGruve
    Interesting. I put in a message into Toyota corporate about it today along with vibration during decel. It seems the TSB they just put out for the decel vibrations is just for AT. I'll let you know what they say. This is my first ever brand new car so I don't know how these things are typically handled aside from just showing up at a dealer.
    I'll ping thread with their response.
  8. Dec 8, 2016 at 9:33 AM
    wxm8562
    wxm8562 Well-Known Member
    OP, I just bought a '17 M/T. One of the first things I noticed is that the engine rev's when at a stop when depressing the clutch. I have not noticed it when just on the brake. It doesn't feel like an issue to me. Just the way the truck behaves. I actually thought it was a little feature that Toyota put in that revs the engine a bit when you depress the clutch to help you get going from a stop. Like the feature that holds the brake for a few seconds after you release the clutch when on an incline (Hill Start Assist?)
  9. Dec 8, 2016 at 9:36 AM
    ShootyzGruve
    I thought that maybe it was a hill assist thing too but I notice it when Im on the brake without my foot on the clutch.
  10. Dec 8, 2016 at 9:39 AM
    wxm8562
    It might happen on the brake for me too, but I just recall noticing it more when on the clutch. It is different than other cars I've driven, but I wouldn't be concerned about it. I'm sure it's just how this engine/tranny combo behaves. If you are concerned, bring it up to the dealer when you have your next service. Or you can take another manual for a test drive and see if it does that same thing.
  11. Dec 8, 2016 at 9:43 AM
    pjensen641
    pjensen641 Well-Known Member
    Boone, IA
    '17 MGM ACLB Sport Manual
    1200 RPMs sounds high, mine goes to 1000 RPMS or so. Read about the injection cleaning mode. When the engine is hot and at idle, it will sometimes go in to an injection cleaning mode. I think this might be what it is. It usually drops as soon as I put it in gear, but before I release the clutch.
    DeadEyeWI likes this.
  12. Dec 8, 2016 at 9:44 AM
    Clearwater Bill
    Billy
    Largo Florida
    OP is manual.
  13. Dec 8, 2016 at 9:44 AM
    BCSpazer
    BCSpazer Well-Known Member
    2020 Tundra TSS Off Road
    Mine does this. As someone else said - it seems to be related to load on the engine. It'll do it while downshifting as well. I'm in a A/T.
  14. Dec 9, 2016 at 9:23 AM
    wxm8562
    OP, so I paid close attention to this on my commute to and from work over the past day.
    The RPM's don't increase when I depress the clutch like I originally said. It only happens when I depress the brake. I also noticed that it does rev up to exactly 1200 RPMs like you stated. However, I found that it only does it while the truck is warming up. Once the truck is fully warm it won't do it anymore. The RPMs don't move when depressing the brake.
    In conclusion, this is just how the engine behaves. It keeps it's revs up until the engine is fully warmed up.
    winterwolf likes this.
  15. Dec 9, 2016 at 9:29 AM
    winterwolf
    winterwolf Well-Known Member
    Arthur
    Surrey, BC Canada
    16 White TRD Sport SB 6spd
    Mine does that too when my truck is cold, doesn't do it when its warm. 16 6spd trdsport
  16. Dec 9, 2016 at 9:31 AM
    wxm8562
    Yep, it's how the truck operates. Not an issue.
  17. Dec 12, 2016 at 4:39 AM
    ShootyzGruve
    Thanks all for the responses. This weekend I was a little more diligent in observing it and it definitely did coincide with the accessories being on. If I shut off the HVAC system and hit the brake there was no revving.
  18. Dec 12, 2016 at 5:52 AM
    Riding Dirty
    Riding Dirty Sinner; saved by grace
    Before: '16 TRD OR 4x4 AC QS//After: 17 T4R Pro 040
    PlastiDip
    Mine is an auto, and it does this too, but only when cold. When the engine warms up, its fine. I guess all these engines and tranny's do this.
