Engine oil drain plug torque spec 2014
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Blue Flames, May 8, 2017.
  1. May 8, 2017 at 6:17 PM
    Blue Flames
    Blue Flames [OP] New Member
    Greg
    2014 Tacoma 4wd Extra Cab
    Spent too much time searching. Anyone have the torque spec for the oil drain plug for a 2014
    V6 engine 4wd.
  2. May 8, 2017 at 6:33 PM
    3coma
    3coma my kid says my truck is "Boss"
    rob
    19 dcsb sport cement 4x4
    21 ft/lbs according to the torque value thread on the top section of this page.
    REDdawn6 likes this.
  3. May 8, 2017 at 6:43 PM
    HTX
    HTX Well-Known Member
    30 for the V6.
  4. May 8, 2017 at 7:44 PM
    Thillman
    Thillman Well-Known Member
    '12 Tacoma TRD Off-Road
    Tirty senor!
    Or 360 in lbs
  5. May 8, 2017 at 7:46 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    In my many decades of oil changes I have never used a torque wrench on an oil drain plug, never stripped one or cross threaded one.
    With a new gasket run it down by hand and give it a good snug crank on the wrench. Some on here have stripped the plug when using a torque wrench as the threads are oiled and easier to turn. Torque values are for a dry torque.
    PzTank, Sandman614, orezona and 4 others like this.
  6. May 8, 2017 at 7:46 PM
    Thillman
    ttran076 and Sandman614 like this.
  7. May 8, 2017 at 9:27 PM
    3coma
    rob
    I've got the fumoto valve, not my problem anymore.
    TexasWhiteIce and 1Shifter like this.
  8. May 9, 2017 at 2:10 AM
    1Shifter
    1Shifter Well-Known Member
    Jeff
    Outta the black and into the blue
    09 PreRunner
    Same as everybody else...
    :thumbsup:
  9. May 9, 2017 at 3:32 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    I have also converted to the Fumoto Valve.
    1Shifter likes this.
  10. May 9, 2017 at 3:37 PM
    Clearwater Bill
    Billy
    Largo Florida
    And too much time thinking/worrying.
    @Jimmyh has it in post 5.
    I've been changing oil for 50 years, never used a torque wrench.
    They are good/needed for engine assembly, suspension assembly (bushing areas) and, well, that's all I use one for. :anonymous:
    1Shifter and Jimmyh like this.
  11. May 9, 2017 at 3:42 PM
    STOCKTRD
    STOCKTRD Well-Known Member
    In Traffic
    CustomTacos Mafia!
    Nachos, Lemon Heads, My Truck Is Stock!
    I googled this and got an answer in less than a minute.
    jawscardodger likes this.
  12. May 9, 2017 at 4:25 PM
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    yep
  13. May 9, 2017 at 5:28 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Exactly, haven't had to worry about this in over 5 years now
  14. May 23, 2017 at 3:05 PM
    Blue Flames
    Greg
    Thanks for all the replies. Never thought to google it. Figured it'd be here somewhere. I don't see a tab for torque values at the top of this page. I'll hunt some more.
    I'd never used one for an oil drain plug either & ended up not using one here. (left it at work). I would have torqued it then checked it with the 3/8 ratchet to get the "feel" for the proper torque.
    As one of my mentors says "Everything has a torque value".
    Haven't looked yet, but where did everyone get their Fumoto valves?
  15. May 23, 2017 at 3:38 PM
    jbrnigan
    Midwest
    Amazon
  16. May 23, 2017 at 7:01 PM
    3coma
    rob
    Fumotooildrainvalve.com model F103 is $24 plus shipping.
  17. May 23, 2017 at 7:09 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
