engine dies when i come to a stop
Discussion in '1st Gen. Tacomas (1995-2004)' started by accarroll, Nov 7, 2012.
  1. Nov 7, 2012 at 2:22 PM
    accarroll
    accarroll [OP] Active Member
    charlotteslottesville
    1995 extended cab
    body lift
    Just got a pretty decent deal on a 95 4x4 tacoma. I got it pretty cheap b/c the motor cuts off sometimes when you come to a stop. Im a pretty good wrench turner and would like some suggestions on where to stert trouble shooting the problem. The motor starts right back up when i put it in neutral. By the way its a v6.
  2. Nov 7, 2012 at 5:57 PM
    Sittingbull2
    Sittingbull2 Old N.R.A. Hippy
    Mitch
    Southeast texas
    2000 Xtra Cab SR5 White
    3" Body lift, ARB Front Bumper w/9000 lb. Warn Winch, Chevy Alum. Rims w/ Kelly 285's M/S
    Any CEL come on in the dash?
    Could be MAF sensor needs cleaning or buy a rebuilt one like I did after 150,000 miles i believe it needed it. Made a world of difference
    Have you checked your sparkplugs I know on mine when I bought it which was used it had the wrong plugs in there. Mine called for the double electrode kind NGK or Denso plugs I went with NGK plugs. Made a world of difference also.
    Check your airfilter also.
    If the fuel filter hasn't been replaced in a long while change that out. I used a Wix filter others buy OEM it also helps the fuel pump. If it is dirty it makes the fuel pump work harder. Seafoam the crap out of it. It won't hurt nothing. Someone else might chime in and give some more advice anyway thats my 2 cents
  3. Nov 7, 2012 at 6:21 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    I would test fuel pressure. I had a motorcycle that did this. I discovered that at high RPM the piston could pull enough gas in to stay running but when it idled, it would burn the fumes and die. My guess is fuel rail related.
    Edit: The pump was weak on my motorcycle. New pump and it was fine.
  4. Nov 8, 2012 at 4:31 AM
    accarroll
    1995 extended cab
    body lift
    It don't have any lights on on the dash. Going to change the plugs and clean the maf first. Where should I check the fuel pressure at?
  5. Nov 8, 2012 at 11:11 AM
    Sittingbull2
    Mitch
    Southeast texas
    well if your's is like mine 3.4 V6 your filter should be on the drivers side under the truck almost under the door but on the inside of the frame rail. Your fuel line goes into the filter there. i guess you could check the pressure there. Or do like the FSM says.
  6. Nov 8, 2012 at 11:34 AM
    Littlebro 5
    Littlebro 5 Well-Known Member
    Tyler
    Wilsonville or
    01 4x4 3.4L sr5 manual all-pro lift
    6" deck plate mod, sweet bed bar.
    I had the same problem. Take the air intake off clean that and the MAS and take the throttle body off and flush it out and clean it. That fixed the problem for me.
  7. Nov 8, 2012 at 3:19 PM
    accarroll
    1995 extended cab
    body lift
    I just took a look around under the hood. I think its the MAF( the first sensor after the filter) doesnt have a plug to go in it. Its not hooked up at all. I looked everywhere and cant find the plug. Kinda funny b/c theres still no check engine light. Any ideas?
  8. Nov 8, 2012 at 3:41 PM
    TacoCBR
    TacoCBR Well-Known Member
    Irvine, CA
    13 Tacoma DCLB 4x4 TRD
    Does the RPM's drop before it cuts out? If so, could be an idle air control valve issue. Its an easy fix but it'll cost you a few hundred bucks...
  9. Nov 8, 2012 at 4:19 PM
    accarroll
    1995 extended cab
    body lift
    photo (1).jpg hope this is the right pic
  10. Nov 8, 2012 at 4:20 PM
    accarroll
    1995 extended cab
    body lift
    i dont think this is the right airbox. It doesnt line up with the bolts.
  11. Nov 8, 2012 at 4:28 PM
    accarroll
    1995 extended cab
    body lift
    The rpms dont really drop, its just stutters a little and dies.
  12. Nov 8, 2012 at 4:34 PM
    rondog
    rondog Well-Known Member
    Ronnie
    Escondido/San Diego
    You should check the idle air control valve too
  13. Nov 8, 2012 at 4:38 PM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    This is a 3.sl0w engine or a 5vz-fe?
  14. Nov 8, 2012 at 4:45 PM
    accarroll
    1995 extended cab
    body lift
    whats that mean?
  15. Nov 8, 2012 at 4:53 PM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    The airbox you took a picture of looks like one from the Toyota 3.0L engine found in Toyota trucks before the Tacoma. The Tacoma has a 3.4L 5vz-fe engine that looks like this:
    10154d1161824564-5vz-fe-top-end-power-en_7c4fa52525b3b720dfd3967e59ab071c71ac8f58.jpg
  16. Nov 8, 2012 at 5:34 PM
    accarroll
    1995 extended cab
    body lift
    my engine looks the same. It was in a wreck and i think they just threw a old school airbox on it. The airbox is held on the truck with 1 bolt. You think the flap inside of the part that i showed in the pic is closing when i hit the brake and cutting off the airflow?
  17. Nov 8, 2012 at 5:38 PM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    Very possible I suppose. Personally I would look for a new intake just because it sounds janky the way it is. Is there a way you can modify the airbox so there's no flap?
  18. Nov 8, 2012 at 6:00 PM
    accarroll
    1995 extended cab
    body lift
    I think im going to drive it without the airbox tomorrow and see what it does. I will be checking the scrapyards for the correct box for sure.
  19. Nov 9, 2012 at 2:38 PM
    TacoCBR
    Irvine, CA
    Sounds like idle air control valve. Had this issue on a few cars I've owned. You can try taking brake cleaner to it. If that doesn't work, you may need to replace it completely. The IACV runs about $200-$300 from what I remember.
  20. Nov 9, 2012 at 2:54 PM
    TacoCBR
    Irvine, CA
    IACV issue signs:
    When you're driving and slow or come to a stop the engine cuts out or when you cold start, it doesn't want to stay on sometimes.
    When it gets bad and starts cutting off all the time, try using 2 feet. When you come to a stop, brake with your left foot and give the throttle slight gas to keep the RPM's above normal idle. If this keeps the engine from stalling, you can be confident that its the IACV.
