Engine cranks and starts too quickly
Discussion in '3rd Gen. Tacomas (2016-2023)' started by typicalatypical, Jul 20, 2023.
  1. Jul 20, 2023 at 7:18 PM
    typicalatypical
    typicalatypical [OP] New Member
    Ri
    2016 Silver Tacoma TRDS DCLB
    Stock to the bone
    2016 DCLB V6 with 185,000km.
    Lately I have noticed that sometimes the engine turns over a little too quickly, and feels like engine misfired/detonation/piston slapping sound as it starts. It takes less than a second to start, like almost instantly as I press the start button.
    Normally it takes about 1.5 seconds to crank. What could it be?
    Engine sounds normal otherwise
    danny15l and Gfenza89 like this.
  2. Jul 20, 2023 at 8:30 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    This is the first time I’ve ever heard someone complain that their engine starts too fast. 1st world problems. You could try pouring some sugar in the gas tank to slow it down. No guarantees. YMMV.
    kona61, soundman98, TS4x4 and 13 others like this.
  3. Jul 20, 2023 at 8:35 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Its catching a cylinder right at the beginning of a compression stroke. Quick suck and bang, and you're off and running
    Are you in a hot climate? Maybe the rotational drag is a little lower at cold start because the block is already warm-ish. I dunno
    :notsure:
    SpeySquatch likes this.
  4. Jul 20, 2023 at 8:47 PM
    Blak Shinobi
    Blak Shinobi Well-Known Member
    taco
    2020 MGM Sport DCSB 4x4
    n/a
    maybe you gotten faster at counting, count slower
  5. Jul 21, 2023 at 9:51 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    No no, adding sugar will make the engine more hyper.
    Stevie17 likes this.
  6. Jul 21, 2023 at 9:53 AM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    Try turning the key slower.
    joba27n, lbhsbz, Dfpftw and 1 other person like this.
  7. Jul 21, 2023 at 10:01 AM
    zoo truck
    None
    You can try a nearly dead battery, I'm sure that will get slower cranking results.
  8. Jul 21, 2023 at 10:07 AM
    Gfenza89
    Gfenza89 Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    Lol every 2gr-fks engine I ever owned feels like it takes forever to turn over. Not to mention it sounds like it’s struggling
  9. Jul 21, 2023 at 10:07 AM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Oh look a Friday thread.
    soundman98, Squirt, JFriday1 and 4 others like this.
  10. Jul 21, 2023 at 10:08 AM
    Gfenza89
  11. Jul 21, 2023 at 10:10 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Any CEL’s?
    Check for codes, or better yet, get to someone that can read codes and actually use the data.
  12. Jul 21, 2023 at 10:30 AM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
  13. Jul 21, 2023 at 10:41 AM
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    Years ago where I worked a supervisor complained that the siren in her vehicle was too loud and the warning lights were too bright.
  14. Jul 21, 2023 at 10:46 AM
    Mike402
    Mike402 Well-Known Member
    Palm Springs, CA
    2020 Custom TRD Off Road
    I occasionally experience the exact thing as the OP in my 20 OR and even started a thread about it and nobody could explain it. The above makes perfect sense to me, thanks for solving the mystery.
    If it helps I live in a scorching desert environment (it was 121 on Sunday), and it definitely seems to happen more the hotter it is outside.
    drizzoh and Gfenza89 like this.
  15. Jul 21, 2023 at 10:50 AM
    Mike402
    Palm Springs, CA
    I wouldn't call it complaining, just curious what causes it. It doesn't sound normal when it happens.
  16. Jul 21, 2023 at 10:53 AM
    Gfenza89
    These trucks have more Damn quirks than any vehicle I’ve ever owned . I can’t keep up with them all after owning 4 third gen tacomas. Between weird starting, rattles, random squeaks, vibrations etc etc between the 4 of them they all had different but similar personalities . Get used to it dude lol
  17. Jul 21, 2023 at 11:10 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    They are like old wives. They gripe, b**ch, moan, complain, get hard to start, run too hot or too cold, eat too much, gain weight with each passing year [new doo dads and add ons], their looks fade, but we will still miss them when they are gone.
    Blak Shinobi likes this.
  18. Jul 21, 2023 at 11:13 AM
    Shawgf2000
    Shawgf2000 Well-Known Member
    2018 Silver TRD Off Road
    Squirt and SR-71A like this.
  19. Jul 21, 2023 at 11:44 AM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    HELP. Followed your instruction poured 2 cups of sugar and now it won’t start :anonymous:
    SR-71A and gudujarlson[QUOTED] like this.
  20. Jul 21, 2023 at 11:59 AM
    nucl3ar
    nucl3ar 2021 White Tacoma Limited 4x4
    Raleigh, NC
    OVTune Meso Total Tail Stage 1 tail lights BAKFlip MX4 Tonneau Cover
    Friday jokes aside, I have experienced quite a few times. It started after I used some Royal Purple fuel cleaner and even had a rougher than normal idle for the next 1200 miles. I'd say 1 out of 4 start ups would be exactly as described.
    It eventually stopped happening frequently, but every now and again it will crop up.
