Engine coolant for 1987 Toyota with 22-R 4 cylinder....
Discussion in '4 Cylinder' started by revsam937, Jul 2, 2018.
  1. Jul 2, 2018 at 9:22 PM
    revsam937
    revsam937 [OP] New Member
    Sam
    1987 Toyota Pickup Base Model, 22-R with Carb., 5 Speed
    Upgraded instrument cluster from speedometer and 2 gauges to one with tachometer plus 4 gauges. Also completely replacing AC system, repairing dash pad cracks and restoring paint, as a start.
    The Owner's Manual for my 1987 Toyota pickup says to use "ethylene glycol" antifreeze which is green in color. But, the label of a Zerex Asian variety says it should be used in Toyotas, etc. It has a different color (blue?).
    Problem is, the owner's manual is vague about what was put in it on assembly back in Japan. And, on a bottle of G-05 (HOAT) antifreeze I read it is recommended for 1995 and earlier Toyotas.
    I'm new to the Toyota scene, so what's the best for my truck? I hear that Toyota "red" antifreeze is best, but this antifreeze chemistry is new to me. What's up?
  2. Jul 5, 2018 at 1:58 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
  3. Jul 16, 2018 at 9:09 PM
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    There are so many different anti-freeze formulations for different engines that I just don't play the guessing game. I go to the dealer and ask them what to use. Color means nothing. It's the make-up that does. Chances are that if you're engine calls for the green then just any green would work but I still wouldn't take the chance. You put the wrong stuff in there and you could be looking at some really expensive repairs down the road. To me, an extra $5 per gallon is good insurance especially since these 4 cylinders don't hold much.
