Engine codes P117B & P0174 2019 tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Drtbker, May 2, 2021.
  1. May 2, 2021 at 3:22 PM
    Drtbker
    Drtbker [OP] Well-Known Member
    2019 Cement Tacoma OR 6speed
    Was driving to the store today and this code popped up when I turned into grab coffee.
    I have a 2019 manual 3.5l with 25,000 miles. Just trying to see what could cause this code.
  2. May 2, 2021 at 3:39 PM
    SRBenjamin
    SRBenjamin Well-Known Member
    Benny
    Cylinder A/F Imbalance Monitoring Bank 2
    System Too Lean Bank 2
    5 second search found that. This your first day on-line?
    9TRDTCO and MOC221_ like this.
  3. May 2, 2021 at 3:41 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Smells like a fuel pump recall
  4. May 2, 2021 at 3:49 PM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Wow, put down the fucking coffee man.. geez!
    o_O
    RedWings44 and Georgia Native like this.
  5. May 2, 2021 at 3:53 PM
    Drtbker
    Yeah, I actually meant to put that in, just wanted to see what others experienced this
  6. May 2, 2021 at 4:00 PM
    SRBenjamin
    Benny
    Go find a safe space, FL.
    MOC221_[QUOTED] likes this.
  7. May 2, 2021 at 4:02 PM
    MOC221_
    Frank
    Huh, maybe it's the bottle you need to put down.
    RedWings44 likes this.
  8. May 2, 2021 at 9:37 PM
    Drtbker
    I checked for recalls for the truck but didn't find anything
  9. May 3, 2021 at 3:40 AM
    jws6295
    jws6295 Well-Known Member
    Central PA
    2016 SR5 double cab long bed
    Is the truck running okay? From what I’ve seen around here and the internet means when that code appears it’s normally a compression issue inside the motor. Some people had valve issues.. can’t remember if it was burnt valves or valve seats not sealing. Which kinda go hand in hand.
    MOC221_ and TX BAJA1 like this.
  10. May 3, 2021 at 3:46 AM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    MOC221_ likes this.
  11. May 3, 2021 at 3:57 AM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    Its the fuel pump. I had my fuel pump replaced last week and all my issues went away. I had issues with it stalling right after starting
  12. May 3, 2021 at 4:11 PM
    Drtbker
  13. May 3, 2021 at 4:12 PM
    Drtbker
    Did you have the recall for the truck? I checked for recalls and it didn't show anything with my vin.
  14. May 3, 2021 at 4:13 PM
    Drtbker
    Truck seems to be running fine. did not notice anything when the check engine light came on.
    jws6295[QUOTED] likes this.
  15. May 3, 2021 at 4:17 PM
    brandon78lusch
    Brandon
    I think every 2019 is affected by it
  16. May 3, 2021 at 4:18 PM
    Drtbker
    Cool, ill take it in. just wanted to know what I was looking at so I understand before taking it in.
  17. May 3, 2021 at 4:41 PM
    Exfordman
    Exfordman Well-Known Member
    Norman
    2021 Tacoma TRD OR 4X4 LB White
    None
    fuel pressure loss would normally effect both cylinder banks. If only one bank is setting a lean code it could be any cylinder on that bank. PCM's monitor the HEGO sensors to set the fuel trims. A lean cylinder would put more air by the HEGO. I have seen a bug/debris go through a MAF sensor causing weird lean codes. You could clear the code and see if it comes back. That way when you go to the Dealer you know its a verifiable issue. Good Luck
  18. May 3, 2021 at 5:04 PM
    jws6295
    Central PA
    Good deal. Yeah I’d have someone look at it with a scan tool with live data and monitor short term fuel trim on that bank. I’ve had a Toyota tech tell me straight out that the cylinder imbalance issue normally leads to heads being pulled but that’s when they have a misfire. Vacuum leak would be the thing I’d be starting to look for at the moment.
