Engine Code P1780 Solution!
Discussion in 'Technical Chat' started by CayucosTacoma, May 5, 2013.
  1. May 5, 2013 at 9:02 PM
    CayucosTacoma
    CayucosTacoma [OP] Just think outside the Yota
    San Luis Obispo/San Jose
    2004 Double Cab 4x4
    Specs in the Build Thread
    So had this weird engine code pop up on my truck. P1780.
    Did some searching and came up with the problem of "trans neutral Switch".
    Replaced the part(100 bucks shipped of rock auto), light went away for about 30 minutes.
    Comes back on, so I think it might be a faulty connection. Some Electric parts cleaner and Di Electric grease doesn't solve the issue.
    Today out of random luck I was messing with my tail light wiring, because it was pretty torn up.
    Connected the wire that illuminates the brake "light" when you hit the brakes back together and boom engine code gone.
    The tail light wiring and Trans Neutral Switch is somehow linked?
    But anyways just made this post incase someone scoping google is having similar issues.
    :cheers:
  2. Jan 5, 2014 at 10:39 AM
    philga5
    philga5 New Member
    phil
    canada
    02 tacoma 4x4 xcab 3.4l v6
    Thanks for this post ! I checked my tacoma for codes this morning ( CEL bulb is dead ) and P1780 appeared... I had to clean my break light connector maybe 2 weeks ago after removing it and replacing it the connection was bad and all kind of weird shit would happen like my fog lights would come on when braking. Anyway. I got this fixed and this is probally what triggered my p1780 ! now its cleared , ill wait a couple of days and check it again and will update this post !
    all this to say : thank you very much !
  3. Jun 3, 2014 at 9:20 AM
    darqnez
    darqnez Member
    DarqComa
    Howdy guys, I know this is kind of old, but I am having similar issues, my rear lights have lost their mind and do all kinds of weird stuff like the blinkers and brake dont work on the passenger side but if you turn on the emergency blinker the reverse light blinks on that same passenger side and if you press the brake with the blinker on the running lights light up and not the brake etc
    Also my front right headlight is always on when the truck is "on" and when started - so basically whenever the key has been turned, my drivers left head light is usually on when the truck is "on" but not when started... I also have had the p1780 code
    what exactly did you clean to resolve your issue? the plug that connects to the tail light housing?
  4. Jan 21, 2020 at 8:37 PM
    Tacotimer
    Tacotimer Shade tree mechanic in training
    Harry
    OR
    01 DC SR5 4x4
    I know this is an old post but I just wanted to say a big thanks to the OP @CayucosTacoma for posting this. You saved me a lot of trouble.
    So, I want to install a backup camera and was checking out my tail light wiring around where u haul had spliced in my trailer lights connector many years ago. It was getting dark and my flashlight was going dim so I taped it back up and called it a night. The next day I start the truck to drive to work and my CEL comes on and the trans is stuck in low. I can't go over 25 mph! I limp to work (luckily, its only 3 miles away on surface streets) and notice my backup lights are always on, no matter what position the AT selector is on!
    I tell my boss I gotta take the day off and limp back home to figure it out. A scan brings up P1780 "Trans Neutral Switch". A quick search takes me to this post and upon closer inspection of my tail light wiring I realize how bad some of the wires are. For example, someone had done repeated crimp type splice attempts in the same area of one wire. My untaping of the wiring bundle the night before had just pushed that damaged wire over the edge. I repaired the wire, cleared the code, and Boom - Problem Solved! OK, I knew it was something I had messed with recently, so that was a big clue, but if you didn't have that would you think a transmission switch problem might be related to damaged tail light wiring? Thanks again OP!
  5. Jan 21, 2020 at 9:50 PM
    CayucosTacoma
    2004 Double Cab 4x4
    Hey, glad to hear that you got your issue worked out.
    Definitely unsure how the two are related but is what it is.
  6. Jan 5, 2024 at 2:32 PM
    wjohnston
    wjohnston New Member
    Glad I found this post via a Google search (over a decade later). Frayed wire is all it was. Now shifts through gears (was stuck in 1st) and CEL is again off. Thanks!!
  7. Jan 20, 2024 at 9:31 PM
    CayucosTacoma
    2004 Double Cab 4x4
    Lol shit what a blast from the past.
    Glad it helped you!
