Engine code P0011. Help!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Enino12, Mar 9, 2013.
  1. Mar 9, 2013 at 9:13 AM
    Enino12
    Enino12 [OP] Well-Known Member
    Eric
    Phoenix
    06 PreRunner Dub Cab
    Two 10" Rockford Fosgate P2 Subs, R/T 10" Dual Ported Box Behind Back Seat, Powered by Rockford Fosgate Punch 600.2 T Amp, 3" Rough Country Suspension Lift, Tacoma Running Boards, N-fab Light Bar, 4 KC HiLites, More to come soon
    Ok so let me start by saying that I just got done making the drive up to California from Phoenix, Az. As I was about 40 miles from my hotel my ultra gauge threw a code. The code is P0011 and after some research is due to the cams timing being advanced?? What should I do? Will I be ok driving till I get back to Phoenix?
  2. Mar 9, 2013 at 12:07 PM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    how long since the last oil change? just a thought process here
  3. Mar 9, 2013 at 12:35 PM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    U do anything to the truck before this?
  4. Mar 9, 2013 at 12:54 PM
    Enino12
    Eric
    Phoenix
    No I haven't touched the engine at all for awhile it's been about 3000 miles since the last oil change. I use synthetic
  5. Mar 9, 2013 at 1:22 PM
    TXtycoon
    TXtycoon Well-Known Member
    Kyle
    Houston
    2010 DCSB TRDOR
    I just recently had a P0012 code on mine. Went to autozone to check the code and they gave me a similar description saying my camshaft timing was off. However, when I took it to the dealership the real problem was a bad oil control valve. My code kept getting thrown every time I got my oil changed...
  6. Mar 9, 2013 at 2:06 PM
    wrmathis
    Bonaire, GA
    parts and stuff
    the OCV is real easy to replace.
  7. Mar 9, 2013 at 2:27 PM
    Enino12
    Eric
    Phoenix
    Thanks for the responses guys. So should I be ok clearing it and driving back to Phoenix? Ill look into it further once I'm home tomorrow night
  8. Mar 9, 2013 at 2:42 PM
    TXtycoon
    Kyle
    Houston
    2010 DCSB TRDOR
    I would say you're good to drive back. The ECU has a failsafe in it if the OCV gets stuck open or closed. Not saying this is a good thing, but I drove with my bad OCV for over a month before having it replaced. Is your CEL intermittent?
  9. Mar 9, 2013 at 2:52 PM
    Enino12
    Eric
    Phoenix
    How much was it to replace? And the CEL was a steady constant light. I cleared it using my ultra gauge and hasn't been thrown again yet so we will see. Thanks for the help man
  10. Mar 9, 2013 at 2:58 PM
    wrmathis
    Bonaire, GA
    parts and stuff
    i found the part online for bout 90 bucks and replaced it myself. only thing u really need to do is remove the throttle body to get it out of the way and loosen one bolt and disconnect one connector and then remove
  11. Mar 9, 2013 at 3:05 PM
    wrmathis
    Bonaire, GA
    parts and stuff
    this is where the 2 OCV valves are located. its one of the 2 orange circle. the code yours is throwing deals with the one on the passenger side. You don't have to remove your intake manifold/supercharger(if u have one) to get to these. the reason mine was removed was to change out the valve covers. anyways, just wanted to show you where they were in case u wanted to replace them yourself
    SR-71A likes this.
  12. Mar 9, 2013 at 4:01 PM
    Enino12
    Eric
    Phoenix
    Awesome thanks for going out of your way for helping me out guys. It doesn't seem too complicated I may attempt to do it myself when I get back home. Do you have the link and part #? Again, thanks so much I was worried it would be something a lot worse
  13. Mar 9, 2013 at 4:18 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    so does that mean your truck has a mean lope at idle?! id sport it!
  14. Mar 9, 2013 at 6:12 PM
    Enino12
    Eric
    Phoenix
    Hahah no it doesn't idle high or rough and doesn't make any weird noises or anything. You wouldn't notice anything unusual if it weren't for the CEL
