Energy Suspension control arm bushings
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ktaco, Jul 13, 2018.
  1. Jul 13, 2018 at 4:02 AM
    Ktaco
    Ktaco [OP] Well-Known Member
    New Brunswick, Canada
    03 Black 4x4 TRD SR5 Xtra cab.
    Grey wire mod, Deck plate mod, diff breather mod. K&N air filter. Toytec coilovers. AAL. Custom rear lift shackles. diff drop. Centerforce clutch. Superwinch LP8500 with custom "behind bumper" mount. Winch solenoid relocation with in cab winch control. 33x12x15 Duratracs. Aisin manual hub swap.
    My question is if anyone has successfully used the energy suspension control arm bushing kit WITH aftermarket bushings.
    I've read a few comments where guys have said the poly bushings did not fit with aftermarket bushing sleeves. You have to reuse the outer shells and inner sleeves for the lower control arms and I have MOOG bushings installed. I don't want to go through the job of burning a bushing out only to learn the new poly ones won't fit.
    I emailed energy suspension about it but was told their kit was made to OEM specs so cannot comment on aftermarket products.
  2. Jul 13, 2018 at 5:11 AM
    jjsul
    jjsul Well-Known Member
    James
    New Hampshire
    95.5 OME
    fatfurious2 likes this.
  3. Jul 13, 2018 at 5:37 AM
    jonesbt
    jonesbt Well-Known Member
    Brett
    Monroe, La
    01 3.4L DC PreRunner—>4WD
    TRD Headers TRD Supercharger Custom Cavalry Blue Paint
    Please do yourself a giant favor and order whiteline. I have energy suspension upper and lower control arm bushings in my OEM arms. I hired a machine shop to complete the job. Between 2 super experienced machinists(~50 years between them) they said that the job was a total nightmare. They plain wished they had turned me away when I walked in with the work. This stuff is certainly possible to do if they fit your application. I was hardheaded and had to see for myself on the ES bushings... I learned the hard way by paying that shop more than I should have.
    BillsSR5 and The Driver like this.
  4. Jul 13, 2018 at 6:06 AM
    Ktaco
    I wouldn't even think about doing the ES kit if this was my first time doing the bushings. I know the issues of cam bolts being seized into the bushings, bushings seized into arms, etc because I went through it all 12 months ago. My Moog bushings are already worn so I figured the ES kit would be a fairly easy job seeing how everything is still relatively "fresh" and shouldn't be seized.
  5. Jul 13, 2018 at 9:07 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    You need to find a different shop then...
    You burn out the oem rubber (time consuming? yes, but the flame does all the work, you just sit there with a beer and watch it), clean it up with a wire wheel. Lube and push in the ES bushings.
    The hardest part is probably dealing with the OEM sleeve/washer thing, but even that was pretty simple to press back in place with a vice.
    It's not rocket science...
  6. Jul 13, 2018 at 9:26 AM
    COMAtized99
    COMAtized99 Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    I went through the Energy suspension LCA bushings swap deal. I feel like I have the tools and skill to do it, but I had already swapped in Moog LCA bushings. They ended up being too soft and wouldn't hold an alignment.
    So I pulled the Moog bushings out, burnt the rubber off, and went to put the bushings together and the Moog inner sleeve was to thin. It just slipped in the bushings with no effort. The OEM bushings took a lot of lube, and was all I could do to get them together. However, I didn't have all 4 inner sleeves from my OEM bushings because some of the cam sleeves where stuck and had to be cut off.
    Anyway, I assembled the ES bushings on the Moog sleeves. Same thing. Play in the lower bushings. Enough to be able to see it in how the tire was angled.
    I finally ordered the whitelines, and dude... So easy. No burning anything, they come ready to go. And they are only cost a little more.
    BillsSR5 likes this.
  7. Jul 13, 2018 at 9:29 AM
    COMAtized99
    North Carolina
    99 DCLB v8
    The one OEM inner sleeve I had, would barely fit the bushing. And I could not get the washer to line up with the sleeve to save my life.
  8. Jul 13, 2018 at 9:50 AM
    01GreenTacoma
    01GreenTacoma Well-Known Member
    I did the energy suspension about a year ago and it took me an afternoon to complete. I am very happy with them.
  9. Jul 13, 2018 at 9:52 AM
    Ktaco
    jonesbt likes this.
  10. Jul 13, 2018 at 12:46 PM
    UnderFire
    UnderFire Well-Known Member
  11. Jul 13, 2018 at 1:46 PM
    jonesbt
    Brett
    Monroe, La
    Time consuming = pain in the ass. Time is money. For just a few more dollars I could’ve saved a lot of time(money) on my overall install. These guys are as good as it gets. I would be comfortable saying these guys completed this job much faster than any Joe in his garage.... With real shop tools. The work I paid for was performed by people with a good professional sense of how to do this kind of stuff. If you’re doing this yourself and just really enjoy extra frustration in life just to pinch a penny then energy suspension is a good option, but it seriously doesn’t make sense to use them otherwise. Just because you can doesn’t always mean you should. That was my firsthand experience with these bushings and I just wanted to share my opinion. Take it or leave it, but I felt obligated to try to save someone else the nonsense.
  12. Jul 13, 2018 at 3:04 PM
    jbrandt
    Justin
    Most of time time "spent" on my ES bushings was spent drinking beer watching a fire - kinda like camping. Not actually working.
    You said in your previous post that "Between 2 super experienced machinists(~50 years between them) they said that the job was a total nightmare."
    All I'm saying is that if I - some goober with an internet connection - can figure out how to do it with very little sweat or frustration, maybe your mechanics aren't as good as you think...
  13. Jul 13, 2018 at 4:02 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    Why burn them? Different vehicle but I just drilled them full of holes and twisted the stockers out of their sleeves.
    Goosie0080 and FromTejasWithLove like this.
  14. Jul 14, 2018 at 7:39 AM
    FromTejasWithLove
    FromTejasWithLove Well-Known Member
    Cale
    Hurricane, Utah
    '99 Taco SR5 4x4 V6; manual everything
    Turtle Top Shell, Rear Single Motorcycle Carrier, Refrigerator
    This guy knows his ish. Don't burn plastic or rubber unnecessarily. Way2Go Crux!
  15. Jul 14, 2018 at 1:53 PM
    jbrandt
    Justin
    Everyone has a little pyro in them...:devil:
    I burned only enough to get the rubber melted enough to be able to pull the sleeves out.
    The other benefit I failed to mention earlier (vs. going with other press-in bushings) is that changing them WHEN they wear out again is a 10 minute job now. No special tools, (obviously) no burning, etc... Just remove the LCAs, push old ones out, lube and push new ones back in. Done.
    I have nothing against whitelines or any other brands, this just worked well for me..
  16. Jul 15, 2018 at 7:23 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    The Driver likes this.
