Emergency brake problems after lift.
Discussion in '1st Gen. Tacomas (1995-2004)' started by VintageFast, Sep 21, 2015.
  1. Sep 21, 2015 at 5:18 AM
    VintageFast
    VintageFast [OP] Well-Known Member
    Jim
    DFW, Texas
    02 Prerunner 3.4
    Ok. So I put 1"blocks under the leafs to compensate for the rear sag after I replaced my stock leafs from Kansas City Spring. When I replaced the leafs I put Daystar greasable shackles on with a 1.25" lift. So my lift in the rear is a total of 2.25".
    The problem is that the ebrake cable is stretched across the top of the leafs now. Is there a trick to the cable? I had to unhook it so the cable wouldn't snap due to the tension so I could drive the truck.
  2. Sep 21, 2015 at 6:48 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Best solution is to remove the blocks (or overload leaf?) and upgrade the leaf pack for the additional lift that you need.
  3. Sep 21, 2015 at 6:58 AM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    Couple of options
    1. Ditch the block and use 2" lift shackle
    2. Ditch the overload and use wheelersoffroad.com progressive mini pack with the shackle you have now for 2 1/2" lift.
    3. Make a custom add a leaf out of your factory pack that goes in as a 3rd leaf I think is where I put mine for about 1 1/2" lift.it can only fit in one spot and I can give you the measurements.
  4. Sep 21, 2015 at 12:18 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Do you have any adjustment left at the intermediate lever??
    Maybe you can get enough to use the e brake.
    Make up some short extension cables Some cable and a few cable clamps.
  5. Sep 21, 2015 at 1:16 PM
    Toyomonkey59
    Toyomonkey59 Well-Known Member
    James
    Hedgesville Wv
    2012 toyota tacoma Trd 4.0 4x4 Doublecab
    Dont they make a extesion for the rear brake cable. Like this Or does this not fix the issue op is talking about?
  6. Sep 21, 2015 at 2:20 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    There problem is the emergency brake cables are to short after adding the blocks
    Drill a hole through the blocks for the cable!!!
  7. Sep 21, 2015 at 2:38 PM
    tan4x4
    Rick
    Folsom, CA
    OP
    Completely ignore the previous 3 posts. :eek:
  8. Sep 21, 2015 at 2:45 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    What do any of these answers have to do with the OP's cable being too short ? He didn't ask about how to lift his truck. It doesn't matter how you go about getting the lift the end result is that your axle / drum are X distance away point A to point B...it doesn't matte if he spends $1k for a custom leaf pack or puts a piece of fire wood in there X is the same.
  9. Sep 21, 2015 at 3:13 PM
    TACO TX
    Kelly
    Denison ,Texas
    Well for one, the E brake cable shouldn't be going over the leafs anyhow, it goes under regardless of blocks or shackles. Like this!20150913_144907.jpg Two, if you were gonna buy new leaf packs why not just get some that add lift instead of trying to use cheap lift blocks and shackles. I was simply trying to make him aware of better options including one that is pretty much free other than some time.
  10. Sep 21, 2015 at 3:45 PM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    LOL...so you knew what he had probably routed that wrong but instead of giving him that info you skipped it and decided to tell him three other ways he should have done his lift that he already bought and installed and is probably perfectly happy with ?
  11. Sep 21, 2015 at 3:49 PM
    TACO TX
    Kelly
    Denison ,Texas
    Actually no, I have just been thinking about it and I didn't remember dealing with my cable at all other than bolting th e shock up. That's when I went back and looked at pictures. I just don't know how they got the cable that far out of place. Geesh, I'm not that much of an ass, it just dawned on me.
  12. Sep 21, 2015 at 3:56 PM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    You'll have to forgive me for assuming that someone was intentionally being an ass on TW...kind of the norm around here :crapstorm::thumbsup:
    pretty sure you solved his prob with that photo.
    TACO TX[QUOTED] likes this.
  13. Sep 21, 2015 at 5:55 PM
    tan4x4
    Rick
    Folsom, CA
    I'm assuming that the OP's axle is similar to mine, in that the e-brake cable goes ABOVE the leaf spring pack, like this:
    I'm not sure which models have the brake cable going underneath and which have it going over.
    If the OP's are like the above picture, then the block would have lifted the spring pack up too far, causing it to push up on the cable. Not good. This is just one reason why a block lift is not recommended. I am surprised that there was less than 1" of space between the top of the pack and the e-brake cable.
  14. Sep 21, 2015 at 6:03 PM
    TACO TX
    Kelly
    Denison ,Texas
    Yea I figured if it was like mine theres no way to get it wrong and go over, he says his is a 02 and mine is 03. It would definitely interfere though.
  15. Sep 21, 2015 at 6:12 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Easiest option would be to remove the blocks and replace lost lift with aal. The block raises the pack up into path of cable. This isnt a problem on newer models where cable is routed bellow axle.
  16. Sep 21, 2015 at 6:19 PM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    This won't necessarily solve the issue. Yes the aal will be thinner than the block, but the cable still may hit the leaf pack.
    OP get under there and measure how much clearance you need. You can get the specs on the aal thickness and compare it to your block.
  17. Sep 21, 2015 at 6:36 PM
    devinzz1
    devin
    2023 aclb trd or mt
    will
    will be nowhere near the thickness of block (if replacement pack is an oem replacement with 3 or even 4 leafs) aals are well used without this issue.
  18. Sep 21, 2015 at 7:14 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    This is true for '03-'04 (and MAYBE '02) trucks but not earlier ones. My '04 is setup like this and gave me no problems when I installed my lift.
    This is the setup through '01 (and MAYBE '02) trucks but not later ones. My son's '01 is setup like this, with the cable is stretched across the top of his Dakar leafs (with no blocks installed). Would like to see REAL potential solutions...
  19. Sep 21, 2015 at 7:32 PM
    devinzz1
    devin
    2023 aclb trd or mt
    People have extended the arms the cable pulls on. Not a hard task but not a job some want to do.
  20. Sep 21, 2015 at 9:34 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    There was just a thread that had this info the other day, I can't find it for some reason. But a small piece of angle iron and a bolt is all that's needed to extend the arm to raise up your cable... Works perfectly.
