Emblem Overlay Application Temperature
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dleonard1122, Dec 25, 2020.
  1. Dec 25, 2020 at 12:11 PM
    dleonard1122
    dleonard1122 [OP] Well-Known Member
    New Jersey
    2020 Cement SR5 Tacoma DCSB 4x4 2021 RAV4 Hybrid
    Santa brought me new black emblem overlays and a TACOMA tailgate insert that I'd love to install ASAP. How important is application temperature to having the 3m tape adhere properly? I'd love to put them on tomorrow, but I don't have a heated garage and it's supposed to be a high of 34°F where I'm at tomorrow. If temperature is important, do you think I could get by with heating everything up with a hair dryer for a few mins?
  2. Dec 25, 2020 at 12:17 PM
    TRD-Troll
    TRD-Troll Smoked Orc 75% off
    NV
    2019 TRDOR DCSB AT
    I would guess if the surface and overlays are put on warm and dry it would be fine.
    i was mostly concerned with cleaning the surface first with alcohol first.
  3. Dec 25, 2020 at 12:50 PM
    chstaco
    chstaco Well-Known Member
    SC
    2020 Tacoma
    The emblem install instructions recommend a minimum temp of 70 degrees. Definitely use a heat source if it's a high of 34.
    Be smart and don't damage your paint. :cheers:
  4. Dec 25, 2020 at 1:04 PM
    NJCementaco
    NJCementaco Well-Known Member
    NJ
    2021 Cement TRD OR DCSB
    I installed my overlays when it was about 50° out and I used a hair dryer to heat back of the overlay and the panel on the truck. Also wiped the panel and existing badge down well with rubbing alcohol first.
    I’m in NJ too and it’s supposed to get really cold at night depending where you are so maybe wait for a warmer day to be safe.
  5. Dec 25, 2020 at 1:06 PM
    jakbakcrak
    jakbakcrak Well-Known Member
    Jack
    2020 Quicksand TRD Off Road Tacoma
    Several aesthetic
    I put some overlays on, in my garage at about 45 degrees but just used the low setting on the hair dryer for a couple minutes. Keep the overlays in a warm spot also before install. Worked fine and the truck has been through a few car washes with no probs.
  6. Dec 25, 2020 at 1:14 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    too cold unless midday whereby U might gain20degrees
    anxiety is not Ur friend.........check local weather might come Ur way n a few days
    make sure ALL surfaces are clean.................. i used dawn to clean then wiped with alcohol
    nxt i used distilled water with just a drop o 2 of natural soap drops
    nothing fancy with lotion or oil ......deodorants
    just plain soap drops......as little as possible....................what the pros do
    see bubbles Uv used TOO much soap
    just enuf where there are no separate drops
    makes it slick to position decals square plus smooth
    U would think long term it might NOT stick strong......... NOT SO !!
    just a few drops..........
  7. Dec 25, 2020 at 1:35 PM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    Temperature is important. Do you have a garage you can heat up? If not, a friend's garage you can use up some of their electricity for? Otherwise, I'd wait it out. Sucks because the temps have recently dropped lately, but better off doing it correctly from the start if you want minimal issues.
  8. Dec 25, 2020 at 1:38 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Being in the north my entire life I can say from my own experience that everything that I have applied in the cold has never held up... Even things that I have heated. I pretty much just tell myself that I need to wait a few months every time.
  9. Dec 25, 2020 at 1:43 PM
    dleonard1122
    New Jersey
    Thanks for the responses everyone. Monday's high looks like it'll be closer to 50°F. I think I can at least wait until then and my results shouldn't be any worse than they'd be if I tried to do it tomorrow. I am planning on using mineral spirits as my cleaner/degreaser.
  10. Dec 25, 2020 at 1:50 PM
    TacoMamba35
    TacoMamba35 Well-Known Member
    PNW
    2021 Tacoma TRD OR DCSB 3.5
    I stuck mine on at about 40 degrees Fahrenheit, after a good cleaning of the area. They're still stuck on there a couple weeks later...
    NoVa TRD Sport likes this.
  11. Dec 25, 2020 at 8:08 PM
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    I have decals for the letters on the glove box. Wanted to do them today but the instructions say not to try it the temperature is below 50f. I'll be waiting a while too.
  12. Dec 30, 2020 at 9:43 AM
    anthonynoriega
    anthonynoriega I just wanna disappear and find nothing.
    Anthony
    Idaho
    2019 Tacoma SR5 QS DCLB
    OV Tune 2.0, UpTop Rack, RTT, Total Chaos Bed Stiffeners, LED Grille Lights, Custom decals and pretty stickers.
    Same same... I got the matte black tailgate decals I REEEAALLLY want to put on today, but I am sitting at a high of 36 today.... I was going to try the hair dryer trick and such, but it sounds like I should wait till the spring thaw.
    I also have the black V6/4x4/SR5/Tacoma badges on the way... figured I could spend a warm day and do them all then.
    That with my new upTop bed rack and my overlander tent... whooooo weeeee.... its gonna be a fun spring!
  13. Dec 30, 2020 at 9:50 AM
    MR E30
    MR E30 Well-Known Member
    Michael
    Wherever it's parked
    2021 Silver TRD OR DCLB w/ AluCab and All the Mods
    I installed some tailgate inserts two years ago shortly after I got the truck. Was ~50 degrees outside, but I positioned the truck so that the sun shined on the tailgate most of the morning. Kept the emblems inside over night and laid them out in the direct sun as well.
    Everything went peachy without any additional warming of items. That was over 2 years ago now, no issues.
    Point: Make sure it's warm. Applying sticky things in the cold never works out long term.
    anthonynoriega likes this.
  14. Jul 7, 2024 at 4:50 AM
    Tacoma Mark
    Tacoma Mark Member
    Maryland
    2020 tacoma sr
    Black out fog lights, black out bar light, black out marker lights (raptor grill stye), DRL marker lights (uner headlight), remote start and door locks, sun visors with vanity lights, extra fuse box, peddle commander, under hood light, hood struts, heated seats, anytime camera and step lights. Painted headlights, added fender flares and installed indestructible vinyl on sides. Seat covers.
    What if outside temperature is 95F?
  15. Jul 7, 2024 at 5:32 AM
    fiftysix
    fiftysix Mell-Known Wember
    Midwest
    2023 TRD OR
    Then grab an ice cold beer to help you out
  16. Jul 7, 2024 at 6:58 AM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    doesn't matter. the trucks melts at that temperature.
  17. Jul 7, 2024 at 2:26 PM
    TRD-Troll
    NV
    2019 TRDOR DCSB AT
    If the surface has been cleaned well I don't think ambient temp being higher is a negative. I would be more worried about applying them when cold.
    Maybe just keep them out of direct sun light the rest of the day.
    My EyeCatcher brand ones were applied in 2019 and still looking new.
    Tacoma Mark[QUOTED] likes this.
