Electronic cooling fan
Discussion in '1st Gen. Tacomas (1995-2004)' started by Littlered_1998, Oct 5, 2019.
  1. Oct 5, 2019 at 5:14 AM
    Littlered_1998
    Littlered_1998 [OP] Member
    Matthew
    1998 Toyota Tacoma 2.4 liter 2 wheel drive 4 speed automatic
    I put in aftermarket halo headlights and ran them off of my running lights, swapped I'm bigger tires went up to a p225/R75.
    I just have a question, does anyone know any good brands for electronic fans, my fan clutch is starting to go out and instead of replacing it I'm thinking about just swapping over to an electronic fan system. Anything helps thank-you.
    Gunshot-6A likes this.
  2. Oct 5, 2019 at 11:48 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    No it is one of the worse things you can do !!!
    Unless you have a clearance issue because of a engine swap stay away .
    I have changed back several (10 +) of these .
    Not knowing where you live the best failure or worst was on the Cross Bronx Expressway at rush hour on a Friday night
    jammer and cruiserguy like this.
  3. Oct 5, 2019 at 11:59 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    I agree with this. Generally speaking it's not a good idea to convert to electric cooling fan as you lose cfm and lose reliability. Actually I don't remember of anyone here having done this conversion and was able to get as good of results as the stock oem fan clutch
    jammer and Night_Wolf84 like this.
  4. Oct 6, 2019 at 11:55 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Your stock fan clutch will still work to a degree .on it`s way to complete failure
    The electric fan just how would you plan to control it ?
    Every connection, every sensor, switch or relay, and the fan motor is a point of failure
    Full stop
  5. Oct 6, 2019 at 1:42 PM
    sonoran
    sonoran Big Loop
    Brob
    Flagstaffrica, AZ
    Tacoma 4X4 3RZ
    Tires: BF Goodrich TA KO2 235/85-16 Matching Spare (in rotation) Rear Suspension: King 2.5 shocks Custom Alcan springs OME greaseable shackles Front Suspension: King 2.5 coil overs Total Chaos UCAs New OEM LCAs Total Chaos Steering knuckle gussets Total Chaos Steering rack bushings Rear Diff: ARB locker (Zuk-Built diff) ARB HD Compressor Rear diff breather extended Armor: Custom full-coverage skid plates Stubbs sliders CBI rear bumper CBI Frame plates Engine: 3RZ Custom over leaf spring exhaust LCE Heavy Flywheel, Pro clutch LCE Stage 1 Head LCE Stage 1 Cams LCE Balance Shaft Delete Bed: Flip-PAC Camper Spray-in bed liner Footman’s loops Canyon Cooler KIST bottle opener Recovery: Custom and very complete tool/service kit including angle grinder and impact HiLift (I know how to use it) and/or Solo skid floor jack depending on trip Glock e-tool (shovel) Strap Interior: Fire Extinguisher Saddle Blanket seat cover Alpine sound Exterior: Anza Headlights WeatherTech wind deflectors “One Less Sprinter” bumper sticker
    Don't do it. Fix the clutch if you must.
  6. Oct 6, 2019 at 1:59 PM
    Littlered_1998
    Matthew
    Thank you, I was a little hesitant because was worried if the electronics fail I would be stranded, and I was looking at this for a clearance issue I was about to do a engine swap from the 2.4 to the 2.7 with a couple add-ons. But I will stay away from the electronic fans
    cruiserguy likes this.
  7. Oct 7, 2019 at 8:27 AM
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    I swapped to an electric fan. Though I had very tight tolerances that I had to. If I could've done clutch I would've but this works surprisingly well and is well known to work in the pick up world.
    22re champion radiator with the Ford Taurus 2 speed fan swap
    det107 likes this.
  8. Oct 7, 2019 at 12:01 PM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    OK I'll ask... the hell is that hanging out of your hood?
  9. Oct 7, 2019 at 12:03 PM
    RedManRocket
    Red
    2002 Double Cab LT
    A bumper :rofl:
  10. Oct 7, 2019 at 12:04 PM
    RedManRocket
    Red
    2002 Double Cab LT
  11. Oct 7, 2019 at 12:11 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    The dual electric fans the previous owner put on my truck did an awful job of cooling, had overheating issues in 4wd especially and with the AC on. Got a new mechanical/fan clutch installed and no more overheating issues.
    I think e-fans are better suited for street/racing applications but for most of us and our Tacomas, the fan clutch does a better job
    1997tacomav6 likes this.
