Electrical Q: Blue Sea Fuse Block
Discussion in '3rd Gen. Tacomas (2016-2023)' started by scifidelity, Sep 18, 2020.
  1. Sep 18, 2020 at 10:04 AM
    scifidelity
    scifidelity [OP] Well-Known Member
    Hi All,
    I have a switchpro but still have too many wires directly connected to my accessory (2nd) battery. So to clean things up, I thought the blue sea fuse block would be a good idea. However, the blue sea unit obviously needs fuses to function. All of the wires I have already have those inline fuses. So do I just add another of the same amp fuse to the blue sea? There is no way I'm cutting those in line fuses out of my ARB items. Should I scrap this solution in favor of another? If so, what product should I be using?
  2. Sep 18, 2020 at 10:08 AM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Typically you cut out the inline fuse and re-terminate the wire with an appropriately sized #8 or #10 ring terminal. You then place the appropriate size fuse in the Blue Sea fuse block. However, note that the Blue Sea fuse block has a maximum fuse size of 30A, so I doubt your ARB (compressor?) will be able to run through it.
    I'm not an electrician, but I don't believe there would be any issue with leaving the inline fuse in place, and then putting the same size fuse in the block. However, I don't think the existing ARB ring terminals will fit in the block (too big).
    Good luck!
  3. Sep 18, 2020 at 10:10 AM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    If you don't want to cut wires and reroute to a fuse block, get a terminal distribution block. One cable goes to the battery and your smaller wires attach to the distribution block.
    Personally, I think rewiring everything to an aux fuse panel would look better. But, I do use one of these as a ground distribution block on my trailer.
    scifidelity[OP] likes this.
  4. Sep 18, 2020 at 10:21 AM
    TheTacoAbides
    TheTacoAbides Well-Known Member
    Randy
    2013 Black Tacoma SR5
    Rough country 3" lift and level. Tuff AT 20" rims. Nitto Terra Grappler G2.
    I have run across a prior installation that had several wires with inline fuse holders going to a fuse block. The inline fuse holders had the fuse component replaced by a hollow "dummy" fuse. Basically just a copper tube of the diameter of the original fuse. I didn't really understand why until now. This might be the use case for you as well. I'm not sure if they are commercially available but I think if you found the right sized copper tubing they could be fabricated.
  5. Sep 18, 2020 at 10:24 AM
    scifidelity
    just found these too. thanks for the idea.
    https://www.bluesea.com/products/category/18/6/BusBars/MaxiBus
  6. Sep 18, 2020 at 10:26 AM
    scifidelity
    thanks for the idea, sounds a little bit like a fire to me though.
  7. Sep 18, 2020 at 10:32 AM
    TheTacoAbides
    Randy
    True that. Although I think you just have to pick your poison - fuse at the point of distribution or fuse inline after a distribution block. I don't think having two fuses in the circuit buys you twice the protection:)
    Kinda like the guy that jumps out of the plane with a chute on his back. But he also keeps a chute on the ground as a backup.
