Electrical Problem Affecting Headlights
Discussion in '1st Gen. Tacomas (1995-2004)' started by Robert Henley, Apr 30, 2015.
  1. Apr 30, 2015 at 1:01 PM
    Robert Henley
    Robert Henley [OP] Member
    2001 Toyota Tacoma Double-Cab Limited 4-WD
    2001 Tacoma DC Limited 4WD:
    Here's the problem: low beam headlights not working. High beam working. High beam headlight indicator light on bright (blue light) on both low beams (which are not working) and high beams.
    What done so far: Replaced headlight bulbs with new ones. Same problem. Replaced both (two) 10 A mini fuses. Lights started working as normally would. Problem appeared resolved.
    Next Night: Same problem recurs. This time, however, smoke comes out of the area where the lever is to tilt the steering wheel.
    Today: Problem appeared resolved.
    Any idea what is the problem?
  2. May 1, 2015 at 10:56 AM
    Robert Henley
    OK, here's the problem identified by the dealer service department:
    The connector on the wiring harness, in which the headlight switch plugs into (under the dash), is damaged and beyond repair.
    The solution is (1) a new wiring harness which costs about $1,200 and $1,800 labor for a total of $3,000, or (2) find a connector somewhere (junk yard, etc.) and it can be spliced into the current wiring harness and a new headlight switch ($75) installed.
    Therefore, I need help finding a connector. The dealer looked in its bin of old wiring harnesses and tried to locate one but was unable to do so.
    If someone out there has an old wiring harness for a 2001 Toyota Tacoma (not sure what other years would be compatible and maybe someone can advise if they know) with a usable connector for the headlight switch please let me know.
    Thanks,
    Robert
  3. May 1, 2015 at 12:13 PM
    Robert Henley
    Here's a picture of the damaged connector.
  4. May 8, 2015 at 11:37 AM
    Robert Henley
    I did some research on my own, and discovered the connector was available Toyota part number 90980-11672. Therefore, was able to fix by splicing the new connector into a new headlight switch. A lot less expensive than a new wiring harness. It turns out in this case that I knew more than the Toyota mechanic. The lesson is the dealer mechanics don't necessarily know the most efficient way to fix something.
    cruiserguy and OneWheelPeel like this.
  5. Sep 20, 2018 at 7:28 PM
    mike14mjh
    mike14mjh New Member
    Michael
    2001 Black Tacoma 4x4 2.7L Std Cab
    Hi Robert, thank you for documenting your problem and solution for it. I'm having the same issue. Where did you purchase the replacement connector? Did it come with the terminals and some length of wire in place?
    Thanks!
  6. Sep 21, 2018 at 7:15 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    Michael, first welcome to TW :)
    Second, you may not get a response from Rob. He hasn't been on in over 3 years. An easy way to check is to click on someone's user name and it will display the info.
    You can try a "conversation" which is a PM/DM but that all depends if he gets updates.
    You can do a Google search for that part number, this is the result:
    https://www.google.com/search?ei=af.....0.76.476.7......0....1..gws-wiz.zVhG-DylzOw
    You can also call a dealership or one of the listed parts places and see how much it would cost. :) GL
    mike14mjh[QUOTED] likes this.
  7. Sep 21, 2018 at 7:20 AM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    You could remove/cut the one wire in question out of both ends of the factory connector and add your own patch with a connector of your choice.
    mike14mjh likes this.
  8. Sep 21, 2018 at 11:50 AM
    mike14mjh
    Michael
    Thank you frizzman and Rob! I plan to purchase a new connector and terminal, and do as Rob mentioned.
  9. Dec 28, 2018 at 4:55 AM
    Boone1716
    Boone1716 Member
    Boone
    2002 tacoma
    None
    I have the same problem...why dont these things come up when you type them in...this thread would of saved me 3 sets of bulbs and racking my brain for hours...
