Electrical for Dummies: Gas Caddy Ground in Bed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by sdbart27, Apr 29, 2022.
  1. Apr 29, 2022 at 2:13 PM
    sdbart27
    sdbart27 [OP] Member
    Encinitas, CA
    White 2020 Tacoma TRD Off-Road DCSB MT
    Hi all,
    I have one of those steel 30 gallon gasoline caddies (like this:https://www.handyindustries.com/gc-30-gas-caddy) and I will be filling it up in my 3rd gen tacoma bed since lifting it into the bed full of gas at 300 lbs would be a pain. The gas caddy comes with a 3 foot long ground wire with an alligator clamp to eliminate hazards from a spark.
    Question: where in the bed is the best place for me to connect this ground wire? There are the bed bolts on the floor of the bed but it's hard to get the clamp to connect to those. The other bare metal u-shaped tie down points towards the front of the bed (see pic) are probably just connected to the bed, but the bed is composite, not metal right? Any pointers?
    Thanks!
  2. Apr 29, 2022 at 2:30 PM
    saint277
    saint277 Vigilo Confido
    the only bolts that connect to the frame, and not the nonconductive composite bed material are the bed bolts on the floor. I would move the bed bolt near the rear of the bed, the one with the tiedown loop, and switch it with one near the front.
  3. Apr 29, 2022 at 2:40 PM
    tacovagon
    tacovagon Well-Known Member
    Dan
    Oceanside CA
    2016 SW SR5 DCLB 4x4
    ARB Locker 5100s w OME 887s OME EL095R Camburg BJ UCAs
    Check with Handy but I think the ground lead should connect to the fuel pump ground when filling the caddy. That is the way it was done when we filled drums with race fuel. There was a ground lead at the pump that connected to the drum. Your truck doesn't have a good ground since it is sitting on rubber tires. Your 3' cable sounds a little short though. Don't take this lightly. I saw a 5 gallon gas can explode that was being filled while sitting in the bed of a truck.
  4. Apr 29, 2022 at 3:16 PM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    I have that same unit (except bought mine from Amazon), actually 2 of them. Mine was about $250 except it came rusty inside.
    I complained to the vendor and they let me keep the old tank and sent me another. It was also rusty so they gave up and give me a refund.
    I used electrolysis to derust both tanks, and then coated them with POR-15.
    About the ground strap, that is critical during fueling and defueling operations. The fuel hose at the fuel pump (for normal gas stations) is electrically conductive. Before filling the tank from the gas station, make sure to touch the gas station hose to the tank to discharge any charge and keep the nozzle in contact with the metal tank during filling.
    The critical thing is during fueling of your items using the tank. Their provided hose may not be electrically conductive, therefore you need to ground the tank to your motorcycle, jetski, motorcycle before pumping to be safe. 3 ft isnt enough to do that, but that is why they provided it.
    I use one tank for avgas and one for ethanol free. Here are the tanks before repairing.
    I use a ceiling mounted 120v winch with the tanks. Strap is permanently wrapped around tank as a sling. Load empty tank into truck and strap into place. Drive to gas station and fill up. Drive home and hook up winch and lift up tank. Drive truck out from under tank. Lower tank and disconnect winch from tank. I included a water block filter on my installation, to make sure i dont pump rust or crap into my vehicles.
    Let me know if you want any more info on my setup...
    Kev250R likes this.
  5. Apr 29, 2022 at 3:23 PM
    sdbart27
    Encinitas, CA
    Awesome, thanks for all the info! Super helpful. So if I got that right, when you're filling it up in your truck bed, you dont connect the ground wire to anything? You only connect that wire to the thing you're filling up?
  6. Apr 29, 2022 at 3:33 PM
    tacovagon
    Dan
    Oceanside CA
    You connect the ground wire to the ground for the fuel pump that you're pumping from.
  7. Apr 29, 2022 at 3:37 PM
    BigWhiteTRD
    Ted
    A couple more pics
    Tank after derusting, it instantly flashes over with surface rust during the rinsing process, before starting the POR-15.
    A pic of tank after coating with fuel inside, POR-15 is silvery
    A pic of the ceiling hoist, there is heavy reinforcements above the ceiling.
    A pic of the straps I use for lifting
    Kev250R likes this.
  8. Apr 29, 2022 at 3:39 PM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    ^^ This. Otherwise.....
  9. Apr 29, 2022 at 9:51 PM
    sdbart27
    Encinitas, CA
    Roger that. yep just went to the gas station and my local Valero had a little ground tab at the base of the pump. Thanks guys
