Electric supercharger
Discussion in '1st Gen. Tacomas (1995-2004)' started by yotanation29, Mar 8, 2016.
  1. Mar 8, 2016 at 4:53 AM
    yotanation29
    yotanation29 [OP] Well-Known Member
    ADRIEL
    CHULA VISTA
    98 TRD
    all pro upper a arms, icon extended travel 3", bumper cb, clarion nav, and much more to come!!
  2. Mar 8, 2016 at 4:56 AM
    Clearwater Bill
    Billy
    Largo Florida
    Do a baseline dyno on your truck. Buy/install this device. Retest on dyno. Report back.
    Before you start, Google 'turbonator' and enjoy.
    Here's another thought. If something so cheap did so much good, why wouldn't every manuf. out there install it as standard equipment on every vehicle?
    One more clue. When an ad says 'up to x HP increase' that means the real answer is 0.
  3. Mar 8, 2016 at 4:58 AM
    sadmrhappy
    sadmrhappy <insert clever title>
    cylinder 0, head 0, sector 1
    2016 Inferno Tacoma DCSB TRD Sport 4x4
  4. Mar 8, 2016 at 5:35 AM
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    I'll play the devils advocate here.
    It's junk and most know it's junk. But I understand the concept. A normal aspirated engine operates on a vacuum. A forced air engine is on a vacuum until the engine is under a load. At this point it's positive pressure, whereas the NA is still vacuum.
    If all this device did was to break even under load and say was at atmospheric pressure, then it would be an improvement over stock. But how long would it last. A couple 1000 miles. At the higher RPMs it won't keep up. Now the fuel trims are off just at mid range. I highly doubt you'll see the suggested pressure either. That's more likely all that fan will produce static and now air flow.
    But any amount over a dead vacuum will see improvement.
  5. Mar 8, 2016 at 5:47 AM
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    With this, a CAI, and exhaust, it should be good for at least 50hp gain. 60 if add a couple of stickers
    Rock Lobster likes this.
  6. Mar 8, 2016 at 5:59 AM
    yotanation29
    ADRIEL
    CHULA VISTA
    98 TRD
    That's exactly what I was thinking. Like you said the concept makes sense but if it really was any good if would've heard of it by now and a lot more people would be using it. Just wanted to see if anyone else ever used one before
  7. Mar 8, 2016 at 1:25 PM
    Trapperr
    Trapperr Well-Known Member
    Reno, NV
    2002 Tacoma Double Cab 4x4 3.4l V6
  8. Mar 9, 2016 at 12:37 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Its sad knowing that people actually bought these.
  9. Mar 9, 2016 at 12:40 PM
    scocar
    scocar hypotenoper
  10. Mar 9, 2016 at 3:05 PM
    Indy
    Indy Master of all I survey.
    Much like the swallows of capistrano, the yearly appearance of the electric supercharger brings joy to the hearts of the the townsfolk. :)
    Combine this with an HHO system, a fart can and 4 go fast stickers and I bet you can break the speed of light. Not bend it, break it.
  11. Mar 9, 2016 at 6:55 PM
    BigBird
    BigBird Paddock Rat
    Michael
    S.F.Bay Area
    Prerunner
    19-BS-Inspection-at-24-Hours-of-LeMons-F_5b1449fdb757759616a2f894ce7c559fed9c0746.jpg
    Belt-driven leaf blower/supercharger......Done the LeMons way...
