Electric Brake Controller install question....
Discussion in 'Towing' started by JWWPHOTO, Mar 5, 2009.
  1. Mar 5, 2009 at 10:52 AM
    JWWPHOTO
    JWWPHOTO [OP] Well-Known Member
    Westlake, Louisiana
    2008 Tacoma Pre-Runner w/ TRD packag
    I bought the Hayes G2 Brake controller for use pulling a new travel trailer.
    When you are installing the electric brake sys controller, it comes with a wiring harness specifically for Toyota. One end plugs into the controller. Where does the other end plug into. I have not recieved the controller as of yet, but went and looked to see a socket under the dash and I can't tell where this it to plug in at.
    Has anyone installed their own electric brake sys in a 2008 Tacoma?
    Please help me out.
    Jeff W. Waldrop
  2. Mar 5, 2009 at 10:53 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    IIRC, the place in which you will see the plug is above the driver side kick pannel.
  3. Mar 5, 2009 at 10:53 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Let me see if I can find something for ya....
  4. Mar 5, 2009 at 10:54 AM
    JWWPHOTO
    Westlake, Louisiana
    I do have the towing package, BTW
    Jeff
  5. Mar 5, 2009 at 10:57 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Dam...These instructions will get you to the towing relay. You will have to follow the wires and you should see the plug in for the brake controler
  6. Mar 6, 2009 at 4:18 AM
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    Towing bible chapter 6 covers brake controllers
    The first picture in the link above shows the plug you are looking for, and Chris is right it is above the driver's side kick pannel, however it may be easier to get to and access if you remove the kick pannel.
  7. Mar 6, 2009 at 1:43 PM
    JWWPHOTO
    Westlake, Louisiana
    Adam, and others,
    Right above that photo in the towing bible, it says that the pigtail came with the truck and was in the glove box. I found mine and that helps me to identify the mating plug that I am looking for.
    But, if my controller comes with the Toyota specific harness, I should not need it, right?
    I am assuming that this pigtail that comes with the truck is if you have to wire into yourself...... hmmmm
    Jeff W. Waldrop:confused:
  8. Mar 6, 2009 at 4:36 PM
    maverick491
    South Jersey
    That is correct. The pigtail that came with the truck connects a toyota to any brake controller. The pigtail that came with your controller connects that controller to any toyota.
    So if you've found the connector above the kick pannel, then you are good to go it'll be plug and play.
  9. Mar 9, 2009 at 4:07 AM
    JWWPHOTO
    Westlake, Louisiana
    Thanks for the help.
    Jeff W. Waldrop
