Elbow locking up....
Discussion in 'Health' started by Lentsnh, May 20, 2009.
  1. May 20, 2009 at 7:21 PM
    Lentsnh
    Lentsnh [OP] Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    After I have lifted something heavy (like firewood bags) and put them in my truck bed. Or even when I point with my whole arm extending with my finger, My elbow locks up and before I can stop it, it pops and hurts like a motherf*^ker.
    Anyway to help from doing this? I dont want this to get in the way of me pitching.
  2. May 30, 2009 at 10:07 AM
    EMR
    EMR Well-Known Member
    So Cal.
    2012 Tx Pro
    I'd be willing to guess that it's actually because of your pitching. Over use of your ligaments from strenuous things like sports can lead to stretching and misalignment. See what your doctor says about it. I'm sure there are excises and stretches you can do to strengthen them.
  3. May 30, 2009 at 10:14 AM
    KMN-BLU
    KMN-BLU less work/more play
    Destin, Fl
    2018 Tacoma TRD PRO
    I would probably agree. I had a similair issue about a year ago and I had to have surgery in my elbow to fix it. They actually cut the tendon and moved it to another spot. Almost all of the pain is gone and has not returned. Its different from tennis elbow as its on the inside of the joint.
  4. May 30, 2009 at 10:14 AM
    rpoint16
    rpoint16 Well-Known Member
    Tempe, AZ
    2022 TRD Off-Road, Super White.
    Bone Stock
    Definatley ice it down, take some ibprophen. If it persists see a orthapedic surgeon. Good luck
  5. May 30, 2009 at 2:34 PM
    Lentsnh
    but its my joint. the ligaments are fine i have no problem with them. Its just my elbow joint is all messed up.
    I can see how it could be misaligned But i dont know from what. It pops every now and then.... usually from doing extreme movements (ie Heavy lifting, extreme extending of the arm, etc.)
  6. May 31, 2009 at 12:33 AM
    EMR
    So Cal.
    2012 Tx Pro
    You're thinking of tendons. Though tendonitis is definitely something to consider. Ligaments are tissue that connect bone to bone (ie in this case your ulna and radius). If the ligament isn't holding the two proximal ends together correctly, your forearm won't articulate properly within the fossa in your humerus. Your "extreme movements" may be stretching your ligaments and causing your ulna and radius to not articulate properly within the humerus.
    Seriously though, there are so many possible things. Don't take action on account from something you heard from someone on the internet. Go see your doctor and go easy on the pitching until you do.
  7. May 31, 2009 at 12:34 AM
    tc2008
    tc2008 Well-Known Member
    Garden Grove, CA
    06 Speedway Blue
    8000K HID light, LED map and dome light, cluster + AC blue, Camburg 2.5 front and rear, Deaver 10 Packs. Satoshi Grille, Eyelids, Carbon fiber hood w/ scoop, BHLM, 285/75/16 km2s, KMC enduros
    break an arm... :D
  8. May 31, 2009 at 12:36 AM
    MiikeyD
    MiikeyD The Green Machine
    Upland, CA
    Green Prerunner DC 2.7L
    Suspension / Wheels / Tires 3.5" Fabtech lift w/ AAL 265/75/16 BFG A/T American Racing Baja Audio Alpine HU CDA-9886 Kicker DS650 Z-Edition 1000W Memphis M3 US Amps 4000W 2.5Farad Cap Lighting 6000K HID 2 Hella 500FF 2 Aux Bed Lights 2 Aux Driving Lights Performance Volant CAI Flomaster Super 44 Doug Thorley Long Tube headers (coming soon) NGK Iridium Sparkplugs Accessories Scanguage II Cobra LTD27-NW with 3' Firestik Radio Shack Triple Trunking Scanner Harbor Freight Hi-Lift Cosmetics Flat Black Bumper Trim Flat Black Grill Surrounding with Satoshi Clear Corners Future Modifications (not specific) Longtravel w/ king shocks or fox Caged bed Shackles rear suspension. Fox / king shocks custom front bumper Custom Glassworks extreme kit for 01-04 (only have hood and passenger side.. need driver panel) Supercharger + 8port intake manifold optima yellow top battery remounted new rims caged interior rear bench removal 4 sparc
    eat bananas
  9. May 31, 2009 at 12:37 AM
    tc2008
    Garden Grove, CA
    06 Speedway Blue
    and drink some viagras...:p JK but i thought eatting bananas only stop your muscles from cramping up?
  10. May 31, 2009 at 2:12 AM
    tacoholic
    tacoholic Well-Known Member
    East Bay, CA
    Yep, I got this problem. Sucks. Dunno what to do with it. I just suck it up and keep working usually. Oh well, hope you get it fixed Lents!
  11. May 31, 2009 at 2:27 AM
    jefferson
    jefferson needs to stop cruising Buy/Sell/Trade....
    Sex Panther
    San Diego (North Park!), CA
    05 PreRunner SR5
    toyota brand hitch and uhaul wiring harness, fog lamps on anytime, bed lamps, map lights on with dome, day time running lamps, remove secondary air filter, painted bumper grill, Double Din touch screen stereo, Sockmonkey custom SR5 decal, door & seatbelt bells disabled, painted engine cover, installed compass/temperature overhead console, failed mod: passenger side auto down window switches, weathertech front mats, RedLine hood struts, Cheap Beep piezo buzzer locking beep, 5100s in the front set at 2.5, 5100s in the rear, AAL, hitch safe, revenge fab sliders, bed bar, prerunner light, cb wired
    the same thing happens to me. I had surgery when i was like 10 though.. they replaced the whole joint.. so yah.. my other one doesnt do that though. BUt it makes for good stories
  12. May 31, 2009 at 2:07 PM
    Lentsnh
    So youre saying that the tendons in my arm aren't in the right place or are too loose?
    Thank you. Well Hopefully I dont have to go to an extent as surgery... I mean it seriously only happens after i lift something heavy and things like that
  13. May 31, 2009 at 2:08 PM
    Lentsnh
    :puke: the only food that I don't like.
    O.J. is the same thing:)
  14. May 31, 2009 at 2:09 PM
    Redfox458
    Redfox458 Well-Known Member
    07 Tacoma TRD Sport Access Cab
    Dont use your arm.......damn, I'd make an awesome doctor!
  15. May 31, 2009 at 2:11 PM
    Lentsnh
    I just take some Aleve after it happens.
    Thanks Jeff. It sometimes hurts sooo bad that it like gives a bad effect afterwords and it "paralyzes" my elbow
    Nope. I'll stick to the tendon problem:)
  16. May 31, 2009 at 2:41 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    keep ice on it for a while, and take advil. one thing though....you gotta keep stretching it out, then icing it down. only use heat minimally if needed. you probably just hyper extended it.
  17. May 31, 2009 at 4:31 PM
    tacoholic
    East Bay, CA
    Damn, mine isn't that bad! :eek: It just hurts for a sec and I keep going.
  18. May 31, 2009 at 4:43 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    my shouldier would lock up when ever I lifted anything over my head, or in a certain motion (benchpress, militay press, chest flies, etc). It would make a physically and audibly noticeable pop and feel like It was going to fail...not a good feeling military pressing with 2 35lb dumbells or a 90lb barbell directly over your head. Turns out when i dislatec it 4 times and popped it back in last season I tore some tissue.
    Now I have some popping in my other shoulder but my physical therapist said it was either the same thing, or a liginment stretched across the joint, and each pop is it slipping over the joint.
    Either way I would see an orthopedic surgeon. It doesnt mean that you will have to get surgery, since it sounds like it is something physical therapy can fix
