Eibach Pro-Truck lift system Stage 1 question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by thegrandpoohbah, Apr 15, 2021.
  1. Apr 15, 2021 at 9:04 PM
    thegrandpoohbah
    thegrandpoohbah [OP] Well-Known Member
    Terrace, BC, Canada
    2013 4x4 Double Cab V6 TRD Sport
    Thinking about getting this kit installed for a mild lift: https://eibach.com/us/1525/E80-82-007-01-22-TOYOTA-Tacoma-pro-truck-lift-system. Mostly highway and forest service roads, no serious off-roading. Just wondering why it states 0-1" lift for the rear. How is it doing that with just a pair of shocks?
    If it matters, I will be pairing this with Firestone airbags and an Air Lift 74000 compressor with wireless remote for towing.
  2. Apr 15, 2021 at 9:51 PM
    Ryan2103a
    Ryan2103a Well-Known Member
    SoCal
    2011 Sequoia 4x4 2022 SR 4x4
    I have these suspension and not sure why it states that either. I do have a single aal in the rear with the overload so approximately 2inch.
  3. Apr 15, 2021 at 10:09 PM
    thegrandpoohbah
    Terrace, BC, Canada
    Anyone know what would happen if I just got the kit by itself with no AAL in the rear? Would it level out the factory rake or will my front end up too high?
  4. Apr 16, 2021 at 5:49 AM
    jaredjnolan
    jaredjnolan Member
    Jared
    2007 Black Tacoma Long Box TRD Sport
    The 0-1" lift in the rear is NOT achieved with the shocks. Rather the shocks are able to be used on a lift up to 1". If shorter shocks are used on too big of a lift they would extend too far at full droop and damage the shock. I cant comment on whether that kit will level w/o a rear AAL, Maybe someone who owns the kit can chime in. But I know that my truck is level with Bilstein 5100 with 2" coils from headstrong offroad and a 3 leaf AAL in the rear.
    mark@eibach, winkel and ace96 like this.
  5. Apr 16, 2021 at 9:50 AM
    TrialMountain
    TrialMountain Member
    2009 Tacoma DCSB OR
    It will be too high in the front. I am on the first notch with my Eibach stage 1 lift and have an Icon AAL and its just about perfectly level.
  6. Apr 16, 2021 at 9:11 PM
    thegrandpoohbah
    Terrace, BC, Canada
    Thanks guys. Looks like I need to get the shop to price out an AAL as well.
  7. Apr 17, 2021 at 12:05 AM
    thegrandpoohbah
    Terrace, BC, Canada
    Here's another question that just occurred to me. I am running 265/70R17 tires right now without any issue. Will the lift kit result in fender rub?
  8. Apr 17, 2021 at 12:18 AM
    Brandon_cruuz
    Brandon_cruuz Member
    Brandon
    2017 Tacoma SR5 - White
    I have this setup paired with Camburg UCAs. I really like it. I’ll upgrade to full LT at some point but for now this is great. (No AAL in the rear)
  9. Apr 17, 2021 at 6:42 AM
    TrialMountain
    2009 Tacoma DCSB OR
    Very unlikely, especially if you do not rub now. However, depends on your wheels offset and your alignment settings. I do not rub with 255/80/17’s.
    I will always suggest getting an UCA to get your alignment where you want it to be after a lift.
  10. Apr 17, 2021 at 11:06 AM
    Brandon_cruuz
    Brandon
    Im running 285/75/16 and big spacers and I don’t rub
  11. Apr 19, 2021 at 9:36 PM
    thegrandpoohbah
    Terrace, BC, Canada
    So I went to chat with the guy at the shop today and he actually recommended that I don't bother with an AAL as it wouldn't ride as well without a constant load on the back. The guy has a pretty built up 1st gen Taco so I am inclined to believe that he knows what he is talking about. So I am going to go ahead with just the Eibach kit for now and see how that works out. Also, from what I can gather the airbags will add about a half inch of lift as they need to be kept at a minimum of 5 PSI. I can always add an AAL later if it becomes necessary I suppose.
  12. Apr 19, 2021 at 9:42 PM
    TrialMountain
    2009 Tacoma DCSB OR
    I mean you could do that, AAL’s aren’t designed for added constant load. More just matched to a better shock. You can always add an AAL later, especially since it does not require an alignment.
    However, you will have the front way higher than the rear. This is lowest notch on the front and before I added the AAL in the rear. 346A7432-DE02-42C1-B510-D7E5A3431F7C.jpg
  13. Apr 19, 2021 at 9:58 PM
    thegrandpoohbah
    Terrace, BC, Canada
    Thanks for the input. Sorry this may be a stupid question but what do you mean by lowest notch?
  14. Apr 19, 2021 at 10:02 PM
    TrialMountain
    2009 Tacoma DCSB OR
    No worries we all come here to learn what works best for our setup.
    The eibachs similar to the bilsteins come with grooves cut into the shock body. There are I think 3 notches depending on height/load in the front shock where you set the lower spring porch. You place a circlip into that groove to set the height/preload of the spring.
    I had mine placed in the lowest setting for the least amount of lift/load possible since I don’t have a heavy steel bumper and didn’t wanted to be excessively lifted.
    headstrong offroads website shows a good diagram of this when I was deciding my configuration.
    mark@eibach likes this.
  15. Apr 19, 2021 at 10:20 PM
    thegrandpoohbah
    Terrace, BC, Canada
  16. Apr 21, 2021 at 4:15 PM
    mark@eibach
    mark@eibach Well-Known Member Vendor
    see above.
    2014 DCSB TRD OR
    Eibach Pro-Truck Coilover 2.5 w/ Resi Dirtking UCAs Magnuson Supercharger HP Tuners MVI2 Pelferybilt Front / Rear Armor DeMello Sliders Fifteen52 Tarmac HD Nitto Ridge Grappler 265/75/16
    @trailmountain beat me to it. Thank you for your assistance.
    OP we originally designed this kit to be level with the rear at the bottom clip, but every vehicle is a little different and some leafs are more worn than others. If you don't care to upgrade the rear, you could always go with with just the four shocks and use your OE front spring. That being said, our whole system works together beautifully, and I found using the Toytec single AAL was a great solution on my 14', but it eventually sagged over time.
  17. Apr 21, 2021 at 5:59 PM
    thegrandpoohbah
    Terrace, BC, Canada
    Thanks! I'll try the kit first and then add an AAL if I need to.
  18. Mar 5, 2022 at 3:54 PM
    kbecerra
    kbecerra Well-Known Member
    2006 Red Tacoma Double Cab Long Bed PreRunner
    Eibach Pro-Truck Lift (Stage 1), Deaver AAL, JBA STD UCAs
    Awesome setup! I’ve been thinking doing this set since I’ve been going from Bilstein 5100 and this. But I do see an advantage where Eibach already comes with its own coils.
    How’s the ride/quality?
  19. Jun 15, 2022 at 3:39 AM
    Danieldee
    Danieldee Well-Known Member
    Daniel
    2015 Tacoma TRD
    Hello question. what are the negatives if i go over the 1 inch for the rear shocks on the stage 1?
  20. Jun 15, 2022 at 7:33 AM
    ZMan2k2
    ZMan2k2 “Hold my beer and watch this!”
    Richard
    ‘Berta
    06 Rad Red DCLB SR5, ‘25 SS Red Sport Prem. (on order)
    I went 2” in the rear with the Eibach shocks. I’ve noticed no problems, although I assume my down travel is reduced. But since I’m a lifted pavement-pounding mall-crawler, not much problem for me.
