EIBACH PRO-TRUCK LIFT KIT (STAGE 1) FOR 16+ TACOMA REVIEW
Discussion in '3rd Gen. Tacomas (2016-2023)' started by androofoo, Feb 21, 2019.
  1. Feb 21, 2019 at 9:15 AM
    androofoo
    androofoo [OP] Well-Known Member
    2018 Tacoma TRD Off-Road Cement
    I recently installed the Eibach Pro-Truck Lift Kit on my 2018 Tacoma paired with the OME Dakar HD leafs and I am loving this setup! The ride quality is improved even with my 400 lbs static weight in the bed. Best thing is that I didn't have to use my UCA and I still got 2.75" of front lift with proper caster setting. So in summary...
    • Achieve up to 3″ front lift
    • 2.5″ rear lift with OME HD Dakar leaf springs (not AAL)
    • No UCA required; alignment within OEM spec
    • Great alternative to the popular Bilstein 5100
    • Less than $600 for full kit
    I did a full review of the kit and install process here: https://thetrailhunters.com/reviews/eibach-pro-truck-lift-kit-stage-1-for-16-tacoma-review/
    The picture below is without the leaf installed. I will update thread with my OME HD Dakar leafs.
  2. Feb 21, 2019 at 9:20 AM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    I'm going to be installing mine soon.
    How is the ride? I've heard these are valved progressive vs digressive on the 5100's.
    ETA - I love the wheels you have. Reminds me of slipstreams from my old Honda days :thumbsup:
    Acivichb and Bot_Chu like this.
  3. Feb 21, 2019 at 9:40 AM
    SumAznGuy210
    SumAznGuy210 Well-Known Member
    Sam
    2018 Cement TRD Off Road
    Appreciate this! Thank you
  4. Feb 21, 2019 at 9:53 AM
    JD45535
    JD45535 Well-Known Member
    Jeff
    2017 Black TRD Sport
    Pro Comp Series 34 Wheels Falken Wildpeak Tires Rough Country Bed Cover Cali Raised LED Fogs and Ditch Lights
    Would you mind sending me the contact info used for the Eibach folks? I'm debating between the 5100 setup vs this one. Awesome write up too btw!
  5. Feb 21, 2019 at 9:54 AM
    azstruble
    azstruble Member
    Nya the AZ Taco
    Side steps thus far, just began off roading, joining group to discuss priority/best/needed mods for beginners
  6. Feb 21, 2019 at 9:56 AM
    FirsandFire
    FirsandFire Well-Known Member
    New York
    No more Taco. A 2500HD and a Bronco sport
    I’m intrigued. I will definitely be looking into this; thank you!
  7. Feb 21, 2019 at 9:57 AM
    SpeySquatch
    2016 TRD OR DCSB
    Curious to know how these rubber boots on the rears will work out. I had those and then took them off because they can cause BAD corrosion from trapping water and also trapping dust/dirt...food for thought
  8. Feb 21, 2019 at 10:00 AM
    eldedo
    eldedo voted most likely eaten by a bear
    Mojave Desert
    '16 DCSBOR 4X4
    2888/5100/Dakars 285's/Camburgs
    good review, however oem alignment spec is not what you want. Also UCA's are definitely recommended anything over 2". Caster target for a lift is ~4 degrees.
  9. Feb 21, 2019 at 10:12 AM
    dat taco
    dat taco Active Member
    adrian
    cement grey trd off road
    nothing yet ;(
    where did you get the full kit for less than 600??
  10. Feb 21, 2019 at 10:12 AM
    androofoo
    Oh. Can you please explain how OEM-spec alignment is not what I want?
    JD45535 likes this.
  11. Feb 21, 2019 at 10:12 AM
    androofoo
    Wheeler's Off Road has then for $595.
    dat taco[QUOTED] likes this.
  12. Feb 21, 2019 at 10:16 AM
    androofoo
    I'm a car enthusiast as well so I know exactly what you're talking about. These are actually JDM wheels ;)
  13. Feb 21, 2019 at 10:17 AM
    dat taco
    adrian
    nothing yet ;(
    thanks!
  14. Feb 21, 2019 at 11:03 AM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    You didn't answer my question about the ride quality :spy:
    King Kermit V likes this.
  15. Feb 21, 2019 at 11:18 AM
    androofoo
    These do ride a bit soft. The handling is not as great as the Bilstein digressive, but handling is controlled by the sway bar anyways so I'd much rather have the plush feel while having better small/large bump performance.
  16. Feb 21, 2019 at 11:19 AM
    FlavorChef7
    FlavorChef7 Well-Known Member
    Austin
    Livermore,CA
    2017 Toyota Tacoma SR5
    Interested to see how this is after a few thousand miles
  17. Feb 21, 2019 at 11:50 AM
    eldedo
    Mojave Desert
    '16 DCSBOR 4X4
    you want to get caster somewhere between 3-4 degrees. This will make tracking much better and give you clearance(between the rear of the wheel and the fender) that you will want. The rest will be oem spec. In order to get the 3-4 degrees caster aftermarket uca's will be needed. Also aftermarket UCA's have more articulation than stock.
    71tattooguy likes this.
  18. Feb 21, 2019 at 11:53 AM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Good deal. I was looking for a soft(er) ride anyway considering I do 80mi a day commute.
  19. Feb 22, 2019 at 1:34 PM
    androofoo
    Yeah just over $1k. Leafs were just as expensive as the coil kit.
  20. Feb 28, 2019 at 4:58 PM
    xxtavixx
    xxtavixx Well-Known Member
    Jacksonville fl
    2018 6MT
    ARB rear locker OVtune Mobtown sliders Core-shifter short throw Trd bro-phony grill Caliraised bumper light bar Caliraised ditch lights Rigid ignite back up lights FN Five Star 16x8 Et0 255/85/16 cooper st maxx MesoJDM fuse box cover MesoJDM led interior lights Bilstein 6112 fronts Bilstein 5100 rears Headstrong 3 aal Toytec 3* shims Mesjodm dome and map lights Diode dynamix ss3 pro yellow Mobtown aluminum front skid 2lo mod SOS front recovery point
    Any updates?
