EGR Vacuum Solenoid 3.4l
Discussion in '1st Gen. Tacomas (1995-2004)' started by Thedoobster, Oct 9, 2021.
  1. Oct 9, 2021 at 11:39 AM
    Thedoobster
    Thedoobster [OP] Well-Known Member
    Brandon
    California
    1999 Tacoma SR5 3.4L 4x4
    3" Lift, 1.5" Wheel Spacers, 285/75r16 Tires
    I own a 1999 Tacoma with a 3.4l, today I'm driving it and check engine light pops on. Ran the code and it's the EGR Vacuum Solenoid so I'll have to replace it. I'm wondering where it is located? I have a good idea but I want to make sure.
  2. Oct 9, 2021 at 12:28 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Top middle of engine under intake.
    Follow the 2 hoses.
    Thedoobster[OP] likes this.
  3. Oct 9, 2021 at 1:18 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Remember it is the complete sensor circuit .
    Make sure it has failed before replacing.
  4. Oct 9, 2021 at 4:22 PM
    USMILRET
    USMILRET Tacoma Owner
    1998, 2007 and 2020 Tacoma
    I agree 100%
  5. Oct 9, 2021 at 7:12 PM
    Thedoobster
    Brandon
    California
    Ok thank you, what should I look for to be sure if it's all faulty?
  6. Oct 9, 2021 at 7:30 PM
    Bivouac
    First check that your solenoid indeed has failed?
    look for broken or rubbed wires
    Time to break out the multi meter
  7. Oct 9, 2021 at 7:32 PM
    Thedoobster
    Brandon
    California
    Haha ok understood, thank you.
    Bivouac[QUOTED] likes this.
  8. Oct 9, 2021 at 8:25 PM
    Black DOG Lila
    Virginia
    Use a 9 volt battery and jumper wires to test the VSV.
    With power applied you should be able to blow air through valve.
    Remove power you should hear a click and no longer be able to blow air through valve.
