EFI 3 vs INJ fuses
Discussion in 'Technical Chat' started by Tullie D, Mar 31, 2019.
  1. Mar 31, 2019 at 5:18 PM
    Tullie D
    Tullie D [OP] Well-Known Member
    Tullie
    Wilson, NC
    2019 SR5 V6 SSM Access Cab
    I initially connected my Raptor style grill lights with an add-a-fuse to the EFI 3 fuse. The lights were on whenever the ignition switch was on. Just like I wanted . :thumbsup:
    I'd read that EFI 3 would turn back on for an emmision test after 4 hours. Sure enough, about 4 - 5 hours after shutting down the engine, the lights came back on. I'm not sure how long. They turned back off while I was thinking about it. o_O
    It "appears" that the INJ fuse will perform like the EFI 3 fuse, except NOT turn itself back on for an emmision test. So I've moved my add-a-fuse to the INJ fuse .
    Can anyone confirm how the INJ fuse works? Is it only hot when the ignition switch is on?
    Edit: If it matters, I have a 2019 SR5 V6.
    12/4/20 Edit: This information applies only to the V6. Study @caribe makaira 's post #14 carefully to figure out WHY. Post #45 shows it more clearly. Thanks Caribe!
    LP808 and jmpell like this.
  2. Mar 31, 2019 at 7:51 PM
    pmortiz01
    pmortiz01 Active Member
    Michael
    2016 Toyota Tacoma Limited
    I’ve had my lights hooked up to that same EFI fuse and always wondered why the lights came on. Good to know. Nervous for a short to blow a fuse or something in my EFI OR INJ system so thinking about somewhere else to tap into currently
    uploadadventure likes this.
  3. Mar 31, 2019 at 9:30 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    I would recommend getting a schematic and wiring diagram for your truck to confirm before randomly connecting to fuses.
    12TRDTacoma and Tullie D[OP] like this.
  4. Apr 1, 2019 at 12:37 AM
    Tullie D
    Tullie
    Wilson, NC
    I'm game. Would you happen to know where I can find them? I haven't had much luck searching for them.
    SR-71A likes this.
  5. Apr 1, 2019 at 4:14 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    LP808, JJ Diablo and SR-71A like this.
  6. Apr 1, 2019 at 5:26 AM
    Tullie D
    Tullie
    Wilson, NC
    Thanks. I'll check 'em out. :thumbsup:
  7. Apr 6, 2019 at 3:23 PM
    Tullie D
    Tullie
    Wilson, NC
    I decided to leave the add-a-fuse on the INJ fuse. Its working like I wanted it to. The lights only draw 0.160 Amp. I'm happy.
  8. Apr 7, 2019 at 8:38 AM
    pmortiz01
    Michael
    quick question does that add a fuse protect the INJ fuse from the raptor lights? is that why theres two fuses on it?
  9. Apr 7, 2019 at 8:41 AM
    DLRIII
    DLRIII Well-Known Member
    David
    Baton Rouge
    2018 Quicksand SR5 DCSB V6
    I've been trying to do the same thing you did but the only INJ fuse I see is a 20 amp, is that the one you're using?
  10. Apr 7, 2019 at 9:06 AM
    Tullie D
    Tullie
    Wilson, NC
    My INJ fuse is a 10 amp. The add-a-fuse for the grill lights is a 5 amp. Heck even a 1 amp would be big enough for my grill lights. They only draw 0.160 amp. If something goes wrong with the grill lights, that fuse should provide isolation from the INJ circuit.
    GoldenTaco27 and nvnv like this.
  11. Apr 7, 2019 at 9:19 AM
    Tullie D
    Tullie
    Wilson, NC
    Yes to both questions. :thumbsup:
  12. Apr 7, 2019 at 9:20 AM
    DLRIII
    David
    Baton Rouge
    So weird, we both have SR5 as well. I'm gonna poke around some more, but do you see a reason why it would not work for me to use the add a fuse in that slot with a 20a fuse for the INJ and a smaller fuse for the lights?
  13. Apr 7, 2019 at 9:27 AM
    Tullie D
    Tullie
    Wilson, NC
    I'd check the layout drawing inside the fuse panel cover. Use whatever size it calls for as your INJ fuse. Then a smaller fuse for the lights, like you said. I've got a 5 amp in mine but plan to change it to a 1 amp.
    Edit: I couldn't readily find a 1 amp low profile fuse. I did find a place where I could order 100 of them, but had no idea what I'd do with the extra 99. :rolleyes:
    I WAS able to find a 2 amp fuse, so that's what I'm using. Realistically, the 5 amp fuse would have been fine, but I feel better with the 2 amp. :cool:
    daveeasa likes this.
  14. May 15, 2019 at 10:22 PM
    caribe makaira
    Caribbean, Puerto Rico
  15. May 16, 2019 at 3:47 AM
    Tullie D
    Tullie
    Wilson, NC
    Thanks for posting the schematic Caribe.:thumbsup:
    It still doesn't completely answer the question though, because it doesn't show how and when the relays are energized. :confused:
    However, I've been using the INJ fuse spot for over a month now, and it does APPEAR to only turn on whenever the ignition switch is on, like I wanted. :fingerscrossed:
  16. May 16, 2019 at 5:12 AM
    caribe makaira
    Engine ECU at ignition. Not always "hot".
    Down "stream" from IGN sourced 10 Amp INJ fuse:
  17. May 16, 2019 at 5:24 AM
    caribe makaira
    I should mention that the add-a-fuse/circuit in the pic is inverted, adding a fuse after the Inj fuse, not in parallel with it. They do sell "left" facing add-a-fuse but I don't know it it'll fit.
  18. Oct 16, 2019 at 5:48 PM
    rdpoe
    rdpoe #2WDFTW
    Central Kentucky
    2019 TRD OR DCLB (Sold), Honda Civic TRD PRO
    Im curious, and prefer a yes/no answer. Is there a problem with using add a fuse off the INJ fuse?
    Is yes, please explain why in layperson terms! I genuinely want to learn and understand, but I have to understand :rofl:
    LP808 and Tullie D[OP] like this.
  19. Oct 16, 2019 at 6:28 PM
    Tullie D
    Tullie
    Wilson, NC
    As long as the additional load is small, there should not be a problem. Altogether, my 4 grill lights (which have 3 LEDs each, for a total of 12) draw "about" 1/2 amp. It's been a while, so I don't remember exactly. I was going to use a 1 amp fuse for them, but ended up using a 2 amp because of availability.
    My lights are on anytime the ignition is on, and they haven't been a problem for the 6 months that I've had them.
    EDIT: I read back over some of my old posts in this thread, and found the number that I couldn't remember earlier. My grill lights draw 0.160 amp, so it's way less than 1/2 amp. :rolleyes: That was measured with a multi-meter back when I first installed them.
  20. Oct 16, 2019 at 6:29 PM
    rdpoe
    rdpoe #2WDFTW
    Central Kentucky
    Thanks for the quick response!
    Tullie D[QUOTED][OP] likes this.
