Edge Insight digital gauge monitor
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lynyrd3, Sep 10, 2017.
  1. Sep 10, 2017 at 1:07 PM
    lynyrd3
    lynyrd3 [OP] STRENGTH DETERMINATION MERCILESS FOREVER
    Bill
    East Central Upstate NY
  2. Sep 10, 2017 at 1:13 PM
    igno1tus
    igno1tus Small member
    Lehigh Valley Area , PA
    '07 Tacoma Access Cab TRD Off Road
    lynyrd3[OP] likes this.
  3. Sep 10, 2017 at 1:29 PM
    lynyrd3
    Bill
  4. Sep 10, 2017 at 1:45 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Mx1.3
    igno1tus and lynyrd3[QUOTED][OP] like this.
  5. Sep 10, 2017 at 3:04 PM
    igno1tus
    Mx1.3 is the one most have (as do I) it does trans temps (torque converter temp and trans pan temp) , engine temps, intake temps , MPG , MPH (if you have over sized tires , it can be calibrated to your tires so) . I think for a Tacoma it will read 40 (maybe more) different Sensors on the truck , I forget the exact amount for a Tacoma . I will take some pics of mine of what I am monitoring . It's fully customizable with what you want to monitor
    The em plus doesn't do trans temps but it does do 0-60 times , breaking 60-0 , and performance related stuff . I think it also does like lap times (not positive on that thou)
    The scan gauge does the same I believe but it's harder to "program" from what hear . And it's more expensive too than a ultra gauge
    lynyrd3[QUOTED][OP] likes this.
  6. Sep 10, 2017 at 3:11 PM
    lynyrd3
    Bill
    Ok ,thanks I would definitely like to see some pictures thanks again .The website has them on backorder again :annoyed:
    igno1tus[QUOTED] likes this.
  7. Sep 10, 2017 at 3:19 PM
    igno1tus
    Yea I had to wait too when I got mine , they are on back order a lot !! .... I've had mine for about 2 months I think
    It does ALOT , more than I'll ever need . It will give you good data if your into that kinda stuff . It also does DTE AND TTE (Distance To Empty and Time to empty) and a ton more , but you can set it up to be as simple as you want it also . Basically you have to select which gauges to display so you can literally show 2 trans temps and that's it OR you could have 6 pages of all the gauges on the truck if you wanted
  8. Sep 10, 2017 at 3:21 PM
    igno1tus
    When I bought mine I emailed ultra gauge and they gave me a estimated time that they would be back in stock
  9. Sep 10, 2017 at 3:25 PM
    lynyrd3
    Bill
    My mechanic recomended the Edge products over Scan gauge .He said Scangauge was kind of a real plasticy and cheap . Edge displays up to 6 gauges at once .The one he told me about was over $400 of course . Sounds like the Ultra is the way to go.
    igno1tus likes this.
  10. Sep 10, 2017 at 3:46 PM
    igno1tus
    This is from that company's web site But I wrote on comparison to ultra gauge
    ( I'm NOT A ULTRA GAUGE SALES MAN OR HAVE NOTING TO DO WITH THEM) I just like their product
    Zoom into read lol
    Depoxy and lynyrd3[OP] like this.
  11. Sep 10, 2017 at 5:05 PM
    inwood customs
    Dave
    keep in mind..... how many EXTRA gauges do you want to be distracted by?
    Im happy with scangauge, and Ive had em both (sg and ultra)
  12. Sep 10, 2017 at 5:53 PM
    igno1tus
    So my first page of gauges from top left to right is :
    Instant MPG
    Avg MPG
    TTE (time to empty)
    DTE (distance to empty)
    (these gauge resets every time you turn the truck on)
    Mph start (avg mph for the current trip)
    MPG start (avg mpg for the current trip)
    Miles start (miles this trip)
    Run start ( how long the trucks been running this trip)
    This is a 8 gauge display
    My second page of gauges I have set up from top left to right
    Torque converter temp of trans
    Pan temp of trans
    Engine temp
    Intake temp of air coming in
    ECM voltage (voltage of alternator)
    Blank ( for now)
    UG temp (the temp of the ultra gauge)
    % Engine load
    8 gauge display
    My page 3
    Again from top left to right
    Rpm
    Mph
    Instant gallons per hour
    Fuel level left in tank
    Torque converter lock up
    Timing advance
    6 gauge display
    Page 4
    These all reset when the truck turns on and a per trip basis
    Miles start
    MPG START
    run start (time the trucks been running this trip)
    Mph start (avg mph for this trip)
    Gal start (fuel used this trip)
    Gal/Hr start
    6 gauge display
    Page 5
    These you have to manually reset in the device . I usually reset the trip each tank but I'm calibrating the unit over 1116 Miles for Accurate calibration of the mpg later I will reset these
    Run Trip
    Mpg trip
    Mph trip
    Gal trip
    Miles trip
    G/h trip
    And you can set yours up anyway you like with any gauges anywhere , this is just how I have mine for now , I may change the layout later
  13. Sep 11, 2017 at 3:54 AM
    lynyrd3
    Bill
    Wow ,thats a lot of info . Thanks for posting the pictures .
  14. Apr 7, 2018 at 3:52 AM
    lynyrd3
    Bill
    Finally ordered the Ultra Gauge mx last night !
  15. Apr 7, 2018 at 9:00 AM
    igno1tus
    Good luck with it , you’ll like it ! It will take a little time to set up the way you want it but it works good once your gauge layout is done
  16. Apr 7, 2018 at 11:03 AM
    lynyrd3
    Bill
    Thanks
  17. Apr 7, 2018 at 1:15 PM
    inwood customs
    Dave
    This.... id suggest
    Download the manual and printout the diagram and pencil in what gauges u think u want where.
    Check them off as u add them to the actual gauge.
    I threw out my final hand written pages, but its something like this...
    Before i had the mx1.3 i wrote things out like this with pages defined
    Then i got the beta mx1.2and it was more fun trying codes
    Then the beta mx1.3
    Just print out page 17 of the reg ultragauge manual for the templates if the company doesnt have a in depth mx manual yet... its been a few yrs as u can see the date on the mx instructions was 2013 and 1.3 was 2014 instructions
  18. Apr 7, 2018 at 1:20 PM
    inwood customs
    Dave
    Actually in that binder i have the scangauge2 manual printout, ultragauge, and the mx1.2 and 1.3
    Came in handy as we used cross referenced codes from 1 gauge and alot of trial and error to get the trans temps working on the mx1.3
  19. Apr 7, 2018 at 1:50 PM
    lynyrd3
    Bill
    I would hope it comes with a manual !
  20. Apr 7, 2018 at 2:33 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    So when you get the mx1.3 you then need to enter a code in order to get auto trans temp ? And where do you get the code from.
