ECU Resetting itself
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bshammer0, Jul 18, 2018.
  1. Jul 18, 2018 at 6:47 AM
    bshammer0
    bshammer0 [OP] Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    I doubt many have had this issue or, if they have, are unaware of it but I won't know if I don't ask!
    I've had an intermittent issue w/ my truck for several months. I call it an "issue" because it's abnormal though it hasn't adversely impacted performance and the truck has always started but it's odd.
    What happens: The ECU / DTCs clear unexpectedly from time to time. Similar to the behavior you would get when disconnecting a battery or clearing DTCs. The best way you know this is happening is that when firing up the truck, there is a split second delay where it sounds like the ECU is getting an initial airflow reading before it sparks the ignition for the first time.
    I then plug in my Carista and OBD Fusion app and can see the clear signature of an ECU reset (miles since DTCs cleared are 0, warm-ups since cleared are at 0-1, etc.,) and the truck restarts its learning behaviors for ignition timing, fueling, etc.,
    Things I've tried: Replaced my stock battery with a Northstar and it's strong as it gets so it's not that. Make sure there are no power draws when I have the truck shut off or when starting up. At one point I thought that perhaps b/c I leave the Carista plugged in that could be the cause but it isn't since I had this happen yesterday.
    One other note is that it generally seems to happen when I have been driving the truck (warm engine) then let it sit for a short period (less than 90 mins) and fire it back up. Doesn't seem to happen on a cold start.
    While not a "big" issue now it is concerning if it could be an electrical gremlin or ECU issue that could bite me down the line. I do know the ECU is intended to hold it's memory and not reset (dealerships go to great length to ensure power isn't interrupted to the ECU when doing service) so the behavior is not normal.
    Anyone had this happen?
    MOC221_ likes this.
  2. Jul 18, 2018 at 7:06 AM
    commbubba19
    commbubba19 Well-Known Member
    '23 TRD PRO
    are you noticing this only when you have a dtc?
  3. Jul 18, 2018 at 7:17 AM
    bshammer0
    Brandon
    Nashville, TN
    I don't have any DTC. Have never had any codes on the truck... I just use that as a reference b/c when you read the stats on the ECU that's the most apparent way to tell when things have been "cleared" is "miles since DTCs cleared"
  4. Jul 18, 2018 at 7:44 AM
    commbubba19
    '23 TRD PRO
    weird. i have bluedriver obdII reader. i should scan mine and see if it shows anything similar. is your only symptom the initial start delay? how are you determining the relearn? asking so i can be aware of any similar symptoms.
  5. Jul 18, 2018 at 7:51 AM
    bshammer0
    Brandon
    Nashville, TN
    You can tell the ignition is a bit jumpier and shifting isn't quite as smooth for a bit but not a ton noticeable other than that in terms of driving, but in the OBD data I can see that learned values for high/low/mid throttle, ignition, etc., get reset to zero so it's having to relearn all that stuff when it resets. It's definitely clearing it's memory - just not sure why. probably electrical but would be interested to see if anyone else sees similar behavior.
  6. Jul 18, 2018 at 7:52 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Warranty, take it in and see if the Dealer can chase it down
  7. Jul 18, 2018 at 7:55 AM
    bshammer0
    Brandon
    Nashville, TN
    Yeah, not something urgent but something I'll have them look into on my next visit if I haven't gotten to the bottom of it. I will be shocked if they can determine the root cause given how odd it is and how I can't prove it's actually causing "issues" but will be a topic on the visit nonetheless.
    Man, my truck has such a wrap sheet! CKP, rear diff, fuel pump, warped rear drums, low ATF from factory, dry u-joints, uneven bed mount
    and yet. I still love the truck so that says something I guess.
    MOC221_ likes this.
  8. Jul 18, 2018 at 8:11 AM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    I have exactly the same setup as you, and while this is not happening on my truck (to my knowledge), I will check it out later today.
    I also leave the Carista BT dongle plugged in 24/7.
  9. Jul 18, 2018 at 8:16 AM
    badhabit2break
    badhabit2break Well-Known Member
    Stephen
    Houston, TX
    2018 Red Tacoma TRD Off-Road
    Stock
    Are you able to check your emissions completions through your setup? If so, see if they are complete. If not then, that would be a sign that the ECU is resetting.
    I run Torque Pro.
  10. Jul 18, 2018 at 8:20 AM
    bshammer0
    Brandon
    Nashville, TN
    They were incomplete the first startup after this happened, but after 2 more warm ups they are cleared since it's had time to run the emissions checks now.
  11. Jul 18, 2018 at 8:48 AM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Have you tried flashing back to stock?
  12. Jul 18, 2018 at 8:52 AM
    bshammer0
    Brandon
    Nashville, TN
    Yes, I have but not for long enough. It did happen a couple of times BEFORE I was tuned though to be clear. I'm not running stock for thousands of miles to see if this happens again tuned or not and it's quite intermittent
  13. Jul 18, 2018 at 8:52 AM
    Lt. Dangle
    Ohio
    You know you want to... Do it. Do it.
  14. Jul 18, 2018 at 8:54 AM
    MOC221_
    Frank
    NO. Just no.
    Ask @dingel5 what he thinks of that idea :D
    dingel5 and bshammer0[OP] like this.
  15. Jul 18, 2018 at 9:23 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    This is interesting. I feel like mine does this as well, but it's been so hit and miss I can confidently say it's the same thing. Every so often it'll seem like the truck takes a couple extra revolutions before starting. It's so sporadic that I'm never expecting it and can't tell if it's in my head or not lol.
  16. Jul 18, 2018 at 9:30 AM
    PB FAB
    PB FAB Well-Known Member
    2017 SR DCSB 4x4 v6
    I have had a few Chrysler ecm’s do this. The ecm would loose power and clear all stored test data. I had one Jeep that would stall, automatic tranny, cycle key and fire right back up.
    The only solution for both of these were new ecm’s. Good luck.
  17. Jul 18, 2018 at 9:31 AM
    PB FAB
    2017 SR DCSB 4x4 v6
    And now when mine occasionally sputters when I start it in the morning I will be checking the stored data.
  18. Jul 18, 2018 at 9:34 AM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    What was your build date? Also, you live in an area with mice? A poke under the hood for mice damage might be worthwhile
  19. Jul 18, 2018 at 9:45 AM
    bshammer0
    Brandon
    Nashville, TN
    Aug 2016 Baja build
    Yes definitely in an area w/ mice but I have 2 cats and the truck is garage kept and I've looked for any signs of chewing to no avail. Cats kill the mice in the garage and bring them in the house as trophies.... ha
    dingel5 likes this.
  20. Jul 18, 2018 at 9:45 AM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    I'm curious what it is. Keep us informed!
    bshammer0[QUOTED][OP] likes this.
