ECU RESET, HOW LONG DOES IT TAKE? HOW TO TELL ITS COMPLETED
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1997tacomav6, Oct 18, 2019.
  1. Oct 18, 2019 at 8:32 AM
    1997tacomav6
    1997tacomav6 [OP] V6 5sp,RegCab,TVS1320 Supercharger,Haltech, 800k
    Denver
    How long does it take for the ECU to reset?
    I have read lots of info from 100-500 miles and certain driving conditions.
    With that said is there a way to know when it ACTUALLY is reset more importantly?
    How can one know when it’s completed the leaning period
  2. Oct 18, 2019 at 8:54 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    What do you mean reset?
    Are you talking about the emissions readiness?
    For that you need to have an OBDII code reader. I have one that's bluetooth and connects to my phone via the Torque Pro ap.
    You can setup a screen like this:
  3. Oct 18, 2019 at 8:59 AM
    1997tacomav6
    Denver
    If you disconnect the battery clearing the memory the ram so the ECU has to reset itself how do you know it has reset and relearned the bell curve and the maps
  4. Oct 18, 2019 at 9:01 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Does anyone have any documentation on this learning that the ECU supposedly does? There's a little voice in my head that says we're making a bigger deal of it than it deserves.
  5. Oct 18, 2019 at 9:07 AM
    jbrandt
    Justin
    I believe those constantly change based on driving conditions anyway, but I'm pretty sure those get "relearned" within a few minutes. The emissions take a while longer but as long as you know what the exact drive conditions are, hat can be done in a few minutes. Generally, if you drive around normally for a day or two, it sorts itself out without you ever noticing.
    The only reason it matters to know exactly how long that takes is if you have to get the vehicle smogged in the morning (like what happened to me after I did my timing belt).
  6. Oct 18, 2019 at 9:11 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    I would imagine by the time the OBD2 compliance readiness shows complete that the the ecu has pretty much 'mapped out the fuel stuff'. I think the big thing is to disconnect the power so that the remapping is quicker than if you didn't remove power from ECU, so the ECU isn't factoring the old data from the old sensors into the equation. If that's even the way it works. Kinda the way I picture it in my head
    BatteredTaco likes this.
  7. Oct 18, 2019 at 9:11 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i have enough on my plate as it is! ... what else is going to go wrong on my truck :annoyed:
  8. Oct 18, 2019 at 9:13 AM
    0xDEADBEEF
    The key to driving an older vehicle is knowing what problems you can safely ignore. :)
  9. Oct 18, 2019 at 9:14 AM
    cruiserguy
    Elijah
    SEKS
    And knowing how to determine what is an actual problem vs a fake problem we create in our minds
  10. Oct 18, 2019 at 9:16 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    ECU learning ? Yet to experience said event. Sounds hinkey to me also.
    Wyoming09 likes this.
  11. Oct 18, 2019 at 9:18 AM
    0xDEADBEEF
    Given the technology in use in these trucks when they were designed was probably early 90's at the latest, I think whatever learning they do is limited to a couple of values such as fuel trim.
    cruiserguy likes this.
  12. Oct 18, 2019 at 9:28 AM
    1997tacomav6
    Denver
    Do you happen to know what the ScanGauge can give you that information as far as the readiness
  13. Oct 18, 2019 at 9:37 AM
    Black DOG Lila
    Virginia
    Toyota FSM snap test recommends snap throttle open rapidly while engine is running. ECU forgets what it was doing, wonders what the hell is going on and starts paying attention. Learning DONE. If I close my eyes and picture things in my head I fall asleep.:D
    BatteredTaco and Wyoming09 like this.
  14. Oct 18, 2019 at 9:38 AM
    cruiserguy
    Elijah
    SEKS
    Not sure, but I was referencing kinda the image that jbrandt posted how it shows when all the parameters have been met for OBD2 readiness. Oh that's right scan Guage and ultra Guage have their own display screens. Not sure man
  15. Oct 18, 2019 at 9:39 AM
    cruiserguy
    Elijah
    SEKS
    Lol :laugh:
  16. Oct 18, 2019 at 9:47 AM
    Black DOG Lila
    Virginia
    I'm not aware of a scan gauge engine readiness test. OBDII Ready test shows when all cycles have run. I force ready test while driving, takes 5 min. But I don't clear codes beforehand.
  17. Oct 18, 2019 at 7:26 PM
    Rachelsdaddy
    Rachelsdaddy Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    No sh*t? Interesting....
  18. Oct 18, 2019 at 7:29 PM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    Once you've set all the monitors it has had enough time to learn. Usually the idle relearn takes the longest but the only other learning is long term fuel trims which is just an average of how you usually drive, speeds and loads.... So if you've driven your usual variety then it's probably learned what it's gonna learn
  19. Oct 18, 2019 at 7:35 PM
    1997tacomav6
    Denver
    A month ago maybe less my fuel trim that were usually are -+5 sometimes up to 9 Max, they changed to +25 +30,
    After doing a smoke test and replacing all the vacuum lines and a fuel pressure test with no answers I decided to replace the fuel pump that had 300k and get an dealership OEM MAF.
    THe results after the fuel pump and new MAF were perfect with fuel trims 0 to +3 or 4,
    I DID also reset the ECU by disconnecting the battery overnight after the fuel pump.
    A few days later and 300 miles the truck still dose not have any where as much power then it had before and the AFR at high rpms with the methonal spraying is very rich at 10. If the methis not spraying the AFR is good.
    I can change out the nozzle to a smaller nozzle size to compensate for the difference in AFR and get it to 12.
    So this evening I put my old MAF back in and the truck runs completely different as in excellent.
    Has full power with AFR at 12.5 where it should be at full boost with the methonal spraying.
    BUT the fuel trims are at +10 to +15 when full acceleration.
    Idle is zero.
    All this is from just changing out a new MAF for the old one with two very different results.
    And the better overall performancepower wise MAF by far, is showing long terms at 10-15.
    What’s up with this?
    Do I run the new MAF with perfect trims With obvious less power
    OR
    the MAF with high trims that makes much more power over the rpm range
    BatteredTaco and cruiserguy like this.
  20. Oct 18, 2019 at 7:53 PM
    cruiserguy
    Elijah
    SEKS
    Wow. That's a tough one. But I guess if I was in your shoes I'd run the MAF that gives l you the correct numbers. And obviously you'll be keeping an eye on it.
