ECU problems
Discussion in '1st Gen. Tacomas (1995-2004)' started by flatlandtaco, Jun 3, 2023.
  1. Jun 3, 2023 at 9:05 PM
    flatlandtaco
    flatlandtaco [OP] Member
    Larry
    Kansas
    1999 SR5 3.4l 4x4
    I am fairly certain I have zapped my computer and was wondering what you guys have used for replacement computers?
    thanks
  2. Jun 3, 2023 at 10:54 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
  3. Jun 3, 2023 at 11:17 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    The number on your ECM needs to be replaced with the same part number.
    The ECM and Engine Harness and sensors are a matched set.
    You can change the year if you swap everything then match up the 4th ECM plug that is attached to the cab harness.
    you might try a rebuilder but if it is zapped good no core value.
  4. Jun 3, 2023 at 11:20 PM
    O'Silver_Taco
    MD
  5. Jun 4, 2023 at 12:48 AM
    O'Silver_Taco
    MD
    Thats not necessary accurate ....the harnesses only change every few years.....so most everybody has a choice of a couple or three of them.......you just cant go very far forward too many years, and cant go too far back....
    Toyota is a little over zealous when assigning part numbers.....the same exact part might have 16 different part numbers attached to it depending on how many different models and many different body sizes and years.....
    example my front hubs....there's a left # and a right #, even though they are exactly the same part....
    There are some ecm programmers....that you send your old ecm in and they send it back just like new....
    last I heard It was $200 and some change....and they guarantee it....
    https://www.ebay.com/itm/373917443774
  6. Jun 4, 2023 at 7:47 AM
    flatlandtaco
    Larry
    Kansas
    1999 SR5 3.4l 4x4
    Yeah I have struck out recently finding an exact part number match on a used computer. Talking to a friend about sending it to a third party to be programmed, said it more than likely can’t be reprogrammed if something is zapped inside. However I have found a couple businesses that sell certified refurbished products with matched vin code that is plug and play. Just seeing if anyone has had luck with either flagship one or module mechanics?
  7. Jun 4, 2023 at 10:35 AM
    O'Silver_Taco
    MD
    I would suggest putting a WTB ad in classifieds here....
    because of the rusted frames....and the 'T' bones there's is a fair number of donor trucks that come thru..
    ie.....from a couple of days ago .....2001 3rz MT left overs.....
  8. Jun 4, 2023 at 10:57 AM
    Bivouac
    I have yet to ever find any wire harnesses that were able to interchanged from different years without lots of repining
    You have personal experiences you would love to share then?
  9. Jun 4, 2023 at 11:13 AM
    O'Silver_Taco
    MD
    5vz I have no experience with....but the 3rz and the 2rz's swap fairly easily....
    key there is you got to know the different sensor's age's or periods on the subtle changes.
    Another words you need an expert on that model.....like Timmy...
    Again they dont come up with a new novel harness every single year........even tho it may issued a different part #....
    If toyota did a complete remake of all their cars and trucks from scatch every year.....think what mess that would be .....a logistical and manufacturing nightmare ...
    And the US is just a fraction of their inventory......
    my guess is most of those different ecm's for same year have slight firmware revamps....
    just like android devices....still function just fine....
    my 3rz did not crash or explode when it was running a 2rz ecm.....from a different year....
  10. Jun 4, 2023 at 11:51 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    How do you know the computer is toast? That’s pretty rare.
  11. Jun 4, 2023 at 12:03 PM
    O'Silver_Taco
    MD
    That was next thing I was gonna say .....alot of people swap ecm and still have no change....
    these rarely bite it unless they get wet and corrode somehow....
    If you pull it, pop off the cover and see the green mess....then it may be finished...
    anything else is repairable.
  12. Jun 4, 2023 at 12:20 PM
    flatlandtaco
    Larry
    Kansas
    1999 SR5 3.4l 4x4
    I sent 12v on the cam sensor wiring back to the computer in an attempt to check continuity… I’m fairly confident that would ruin a computer
  13. Jun 4, 2023 at 12:25 PM
    O'Silver_Taco
    MD
    So you were trying to troubleshoot something else?
    your story, maybe you should start from beginning.....
  14. Jun 4, 2023 at 12:26 PM
    0xDEADBEEF
    Hmmm. There are ecu repair services out there, if you can tell them what you think is fried they might be able to fix it
  15. Jun 4, 2023 at 12:37 PM
    flatlandtaco
    Larry
    Kansas
    1999 SR5 3.4l 4x4
    Got the truck with crank no start issues. Being manual you could push start and it would fire up. I had my scan tool plugged in but was having trouble getting the codes (hadn’t used it in forever) ended up clearing the three out thinking they will come back if they’re important. Replaced the TPS, Crank and Cam sensors and wanted to check continuity on the wiring to make sure it wasn’t a wiring issue. Mistakenly grabbed the positive terminal. Now when I plug into it with my scan tool I have to manually enter the truck (has always pulled itself up and just read the codes). I have good fuel pressure, I have 12v to all three coil packs, I have spark but it’s sporadic and not in a pattern. Timing is in time. My guess is I zapped the computer and it’s confused now.
  16. Jun 4, 2023 at 12:59 PM
    Ozark_RegCab
    Ozark_RegCab Well-Known Member
    Nick
    Northwest Arkansas
    1996 Tacoma SR5 4x4 5 speed
    Sliders, lift, 275/70/17
    I have no idea if that’d fry the computer, but I was having similar issues not being able to read codes or connect to the ECU. I sourced a used 95-97 5 speed ECM from a generous member on here and that seemed to solve my issues.
  17. Jun 4, 2023 at 2:44 PM
    O'Silver_Taco
    MD
  18. Jun 4, 2023 at 2:48 PM
    flatlandtaco
    Larry
    Kansas
    1999 SR5 3.4l 4x4
    Worth a shot maybe but I have already had it unplugged and removed to get the part number and it was out for about a month
  19. Jun 4, 2023 at 4:28 PM
    Aircates
    Aircates Well-Known Member
    Texas
    1997 Tacoma lowboy
    Specifically which wire of the cam sensor harness did you blast 12 volts to? Some of our ecu systems have an overload protection that will shut down the ecm to protect it. I had a sienna a/c amplifier that had a 12 volt short to a 5 volt reference and the ecu survived.
  20. Jun 4, 2023 at 4:47 PM
    flatlandtaco
    Larry
    Kansas
    1999 SR5 3.4l 4x4
    I don’t remember specifically which wire good chance it was both. What did you have to do to remedy that?
