Ecu location?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Natestew65, Sep 27, 2017.
  1. Sep 27, 2017 at 11:17 AM
    Natestew65
    Natestew65 [OP] Member
    Nate
    1999 Tacoma
    7.5 inch lift on 35s
    Can someone help me I need to know where the ecu is located in my 99 Tacoma and how to change it it’s is the v6 3.4
  2. Sep 27, 2017 at 11:34 AM
    Timmah!
    Timmah! Well-Known Member
    TIM
    I don't know how to change it but you find it by removing the glove box. Once the glove box is out, you'll see where all electrical connections plug in. The ECU is behind that plastic bar of plugs.
  3. Sep 27, 2017 at 12:55 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Disconnect your Negative Battery Cable
    Unplug all the plugs going into the ECM replace with the same part number
  4. Sep 27, 2017 at 6:16 PM
    Natestew65
    Nate
    1999 Tacoma
    Thanks guys really appreciate it
  5. Dec 8, 2021 at 9:41 AM
    turkeyhunter21
    turkeyhunter21 Well-Known Member
    1998 Supercharged Tacoma 4x4 Limited
    33X12.50-15's and zip-ties.
    What symptoms did you guys have with a bad ECU??
  6. Dec 8, 2021 at 11:40 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
