ECT sensor???
Discussion in '1st Gen. Tacomas (1995-2004)' started by nofx230, Mar 17, 2012.
  1. Mar 17, 2012 at 2:23 PM
    nofx230
    nofx230 [OP] Member
    Matthew
    Colorado Springs,CO
    2000 TACO
    the wiring going to the ect sensor by the timing cover is only getting showing .22 volts when the fsm says it should be getting 5v:eek: what do i do now???
    was having high idle issues and when i pushed in the clutch going at higher speeds the idle would bounce from 1000-1600 rpms and keep bouncing until i was almost at a dead stop. iv tested and cleaned TB,IAC,MAF,ECT sensor,TPS and everything has checked out kept for the voltage going to the ECT sensor:confused:
  2. Mar 17, 2012 at 4:37 PM
    nofx230
    nofx230 [OP] Member
    Matthew
    Colorado Springs,CO
    2000 TACO
    come on someones gotta have a clue??
  3. Mar 23, 2012 at 12:05 PM
    nofx230
    nofx230 [OP] Member
    Matthew
    Colorado Springs,CO
    2000 TACO
    or maybe someone could test their engine coolant temp sensor so i can compare numbers
    its the sensor by the timing cover right next to the coolant hose on top of the intake manifold turn the key on but don't start the motor and unplug the sensor connector and test it for volts fsm says it should be bout 5v but I'm not getting that and wanna see what other trucks are getting for a reference signal any help would be great
  4. Mar 23, 2012 at 12:10 PM
    98tacoma27
    Ben
    Not Beech Creek
    Do you have 5 volts at the ECM?
    Any codes?
  5. Mar 23, 2012 at 5:07 PM
    nofx230
    nofx230 [OP] Member
    Matthew
    Colorado Springs,CO
    2000 TACO
    no codes are being thrown, trucks just got a messed up high idle and while coasting at like say 50mph the rpms bounce from 1100-1500 or stick at 1600 its new everyday iv cleaned the iac like three times,TB is spotless, linkage is free,butterfly closes all the way,cleaned the MAF like 2 times with MAF cleaner i checked the ohms on the IAC,TPS,MAF,ECT sensor and checked their function and changed out the thermostat oh and pulled the EFI fuse bout ten times and disconnected the battery
    kinda at a loss and no i have not checked the ecu for five volts at the pin yet or continuity of the wire from sensor to ecu but when i unplug the sensor the idle bogs a lil when cold when i unplug it when its warm nothing?? its showing .22 volts by the sensor
    guess i need to get off my a$$ and check the ecu think by any chance you could humor me by checking to see if you got 5v at the act sensor
    all this shit started happening after i cleaned the TB and MAF the first time
  6. Mar 23, 2012 at 5:19 PM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    ur sayin ect as in electronic controlled throttle right? i arent there 3 wires in it? u sure ur in the right wires? and fyi our throttle body's do wear out... mileage?
  7. Mar 23, 2012 at 7:06 PM
    nofx230
    nofx230 [OP] Member
    Matthew
    Colorado Springs,CO
    2000 TACO
    no ECT as in (engine coolant temp) sensor the one that is for the ecu on the front/top of the motor and theres no way a worn TB would make my idle surge seeing as how the surging happens with the flap closed, its nothing mechanical thats causing it, its in a sensor somewhere getting a bad signal or something
    truck is a 2000 TRD 3.4L with 157k and believe it or not the throttle body has very minimal ware on the butterfly and none on the throttle body housing it self. hard to believe but its true
  8. Mar 24, 2012 at 8:24 AM
    lotsoftoys
    Jace
    Denver
    bunch of crap
    ur lucky then like me! just quoted a guy a new tb yesterday at work. he didnt like that.... ok so the ect sensor has 2 wires. 5 volt reference, then the sensor changes that voltge dependent on temp and sends that voltage through the other wire correct?
  9. Mar 24, 2012 at 9:37 AM
    nofx230
    nofx230 [OP] Member
    Matthew
    Colorado Springs,CO
    2000 TACO
    yeah after it receives the signal based on voltage or what not it then goes to the ecu and in theory the ecu then tells the IAC how much to open.
    the truck is thinking that its cold or not warmed up when it is and that would explain why my milage is shot 11-12mpg.
    but back to my original question, could you by chance humor me and check the voltage on the 2 wire connector going to the ect sensor
  10. Mar 24, 2012 at 12:52 PM
    lotsoftoys
    Jace
    Denver
    bunch of crap
    i could but im not at work right now.... ur sayin you only have .22 v at thereference? find the corrosion, check atthe computer would be my first point of diag
  11. Mar 24, 2012 at 4:44 PM
    nofx230
    nofx230 [OP] Member
    Matthew
    Colorado Springs,CO
    2000 TACO
    yeah was more busy with my supra today never got a chance to check to ecu plus I'm trying to figure out what pin on the ecu is for the ECT sensor
  12. Mar 24, 2012 at 4:58 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    All the sensors are 5 volt reference. How are you checking the wiring to ground or between the other pin? Check your temp sensor with an ohm meter they change with temperature. They are critical for the over all running and if it tells the ECU the engine is cold it will use more gas.
  13. Mar 24, 2012 at 5:19 PM
    nofx230
    nofx230 [OP] Member
    Matthew
    Colorado Springs,CO
    2000 TACO
    iv ohm checked 3 diff ect sensors that i have laying around and even tried the one outta my supra, they are all working good
    to check for 5volt reference i unplug the harness right by the sensor and touched the multimeter to the two wires in the connector and then i used check by using a chassis ground instead of the connector ground and still .22 volts
    I'm trying to find out what pins on the ecu that the two wires go to so i can check the ecu for voltage and also continuity of the wires going to the sensor,
    Anyone know what pins???? 2000 tacoma 3.4L non-cali version
  14. Mar 26, 2012 at 7:22 AM
    98tacoma27
    Ben
    Not Beech Creek
    The non-cali spec pics are a little fuzzy.
  15. Mar 26, 2012 at 7:26 AM
    98tacoma27
    Ben
    Not Beech Creek
    Here's a better one
  16. Mar 26, 2012 at 5:14 PM
    nofx230
    nofx230 [OP] Member
    Matthew
    Colorado Springs,CO
    2000 TACO
    well then i guess I'm all good on that note seeing as that link stats the pin for my act sensor should be .2-1.0 volts and I'm showing .22volts so i guess ill move on to something else
    but strangely the manual i have states it is a 5volt reference and any less is not suitable but the link you gave me states .2-1.0 volts wtf
