Economical Way to get rid of 2” Rake
Discussion in '1st Gen. Tacomas (1995-2004)' started by Shane_O, May 16, 2022.
  1. May 16, 2022 at 6:04 PM
    Shane_O
    Shane_O [OP] Well-Known Member
    Shane
    San Angelo, TX
    2004 Tacoma Ext Cab 4x4
    Howdy,
    Looking for some thoughts/ advice on how to get rid of a 2” rake on a 2004 Tacoma. I tried to take pics of the suspension, but I bought the truck this way and can’t really give you much detail beyond that. I’d prefer to raise the front, rather than lower the rear.
    Icons in the front, Bilsteins in the rear. I did not see any blocks in the rear.
    E43A2A91-584F-4BB7-A6E8-A11550A17652.jpg 06CA104D-BA84-4BED-9224-1F1CDE92E022.jpg
    Approx. 7.5” in the front, 9.5” in the rear on 235/85/16s.
    Hopefully that’s enough info for those of you willing to help to provide thoughts, opinions, advice, etc.
    PS - if possible without complete suspension do-over, I’d like to run 285s when these 235s wear out.
    Thanks In Advance
  2. May 16, 2022 at 9:26 PM
    AmherstAndy
    AmherstAndy Well-Known Member
    Andy
    Masshole
    2003 2.7L 5 speed, 4x4 J shift, Xtracab
    Economical? Either crank up those icons a little more or just toss a few 80lb bags of quikrete in the bed. Just watch your cv angles.
  3. May 16, 2022 at 10:31 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Shocks don't raise or lower height, so the mention of the 5100s in the rear is irrelavent. What you need to do is post your full rear setup.
    Leaf pack doesn't look stock, and for having a camper shell, that rear end is sitting up pretty high.
    But like mentioned above, add a bit more preload (within reason) to raise the front.
    Gunshot-6A and tacojim02 like this.
  4. May 17, 2022 at 4:21 AM
    Shane_O
    Shane
    San Angelo, TX
    Thanks for the info. So, from what you both said, you see enough adjustment left in the front to get me closer to level? You say within reason - what will it do to the ride if I end up trying to squeeze too much out of it?
  5. May 17, 2022 at 4:41 AM
    An3
    An3 Well-Known Member
    Andrew
    White '96 Manual 4x4
    You could crank up the front coilovers to achieve a higher front end but that may also make your CV angles too sharp and put in the territory where your UCAs can get the wheels in proper alignment. I’d say the most economical way to get rid of the rake would be to take a leaf or two out of the back and lower the rear just a tad. I had a similar issue with my truck, and after I took a leaf out it dropped me enough to be level with the front. Here’s a reference:
    Taco critter likes this.
  6. May 17, 2022 at 4:47 AM
    Rexfordian13
    Rexfordian13 Well-Known Member
    J
    Albany/NY Capital District
    2015 TRD Sport DCSB MT
    I’d explore dropping the rear down a bit…lower the center of gravity for a new driver. Just being a dad, can’t help it.:notsure:
    (Referring to your other post about being your sons first truck)
    AmherstAndy likes this.
  7. May 17, 2022 at 4:50 AM
    Shane_O
    Shane
    San Angelo, TX
    Very nice. What is your setup? Lift, tire size, etc. See, the whole problem is that I thought I knew what my plan was until I took it to the shop. The guy came out and looked at the front and said they were just about maxed out. He also told me I couldn’t run 285s. Thoughts?
    An3[QUOTED] likes this.
  8. May 17, 2022 at 4:54 AM
    Shane_O
    Shane
    San Angelo, TX
    Much appreciated - thank you!
    And it doesn’t help that the stock wheels and skinny tires add to the top-heavy feel.
  9. May 17, 2022 at 5:02 AM
    An3
    Andrew
    Thanks, in those pics I’m running full OME suspension with 882 coils in the front and the Dakar leaf pack with a leaf removed. Also have adjustable SPC UCAs up front. For wheels and tires I’m running 285/75/16 Yokohama Geolandar G003s on 16x7 4Runner wheels along with a 1.5” wheel spacer all around. Had to do some trimming and bashing to get the tires not to rub. I do love the 285s but a 265 honestly would have been more manageable.
    This is also just personal opinion, but running the lowest amount of lift with the largest tire for that set up would be ideal such as 1.5-2” of lift with a 265 would be perfect. This way the truck still rides really well on and off road, tires are easily available in any configuration in that size and you really don’t have to regear for any power loss. If I did it again, I would have probably gone that route since this is 99% an on road truck with the occasional trail riding
  10. May 17, 2022 at 5:04 AM
    Shane_O
    Shane
    San Angelo, TX
    Great info - thanks for sharing! I’ll definitely start looking that direction.
  11. May 17, 2022 at 6:08 AM
    AmherstAndy
    Andy
    Masshole
    A lot of practical experience and wisdom in this post. :thumbsup:
  12. May 17, 2022 at 6:10 AM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    I would pull out a leaf or 2 from that pack
  13. May 17, 2022 at 6:23 AM
    Shane_O
    Shane
    San Angelo, TX
    I came here with one plan in my head (maintain rear lift, increase front), but so far, it seems like the consensus is to simply lower the rear.
    See? This is why I came to you guys! You've helped a poor fool with what should have been an obvious solution. You all deserve a cold beer - it's 5:00 somewhere!
  14. May 17, 2022 at 6:27 AM
    mlcc
    mlcc Well-Known Member
    Oregon
    2002 DC TRD/ 1995 4runner
    Mid travel, armour all around
    From the looks of it id say the upper control is aftermarket as well, maybe an spc. Can you take a picture of the upper control arm, spc control arms are super adjustable.
  15. May 17, 2022 at 6:28 AM
    Shane_O
    Shane
    San Angelo, TX
    You know, I thought about that and then ended up not taking a separate pic. Thanks for the offer! I'll do that when I get home. I honestly wouldn't know stock from aftermarket, so I'll let the jury decide.
  16. May 17, 2022 at 6:31 AM
    mlcc
    Oregon
    This is an spc control arm
  17. May 17, 2022 at 7:02 AM
    AmherstAndy
    Andy
    Masshole
    This is a rare Tacomaworld moment that should be memorialized. All too often, new members are hesitant to abide by the advice that they solicited. With time, you will learn more about your truck and what you want from it, and may eventually experiment with a different approach. :cheers:
    Strictlytoyz and Justinogo like this.
  18. May 17, 2022 at 7:18 AM
    Shane_O
    Shane
    San Angelo, TX
    For the record, your Quikrete comment is still my favorite one on the thread. :) It may yet come to that - I might have my son building fence this summer, so we'll just load 'er up til it looks like a Cali lift. Rake problem solved!
  19. May 17, 2022 at 7:23 AM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    That's just what I'd do / recommend. Your wants/ needs may differ. If you are dead set on keeping the rear at said height you could either crank the preload on those coilovers a little more or get a heavier rated spring, but in doing so like others have stated will increase your cv axle angles thus making harder to get a proper alignment and a stiffer ride. Pros and cons in whatever route you decide. Feel free to pm me if you have any questions
    Shane_O[QUOTED][OP] likes this.
  20. May 17, 2022 at 7:24 AM
    AmherstAndy
    Andy
    Masshole
    Stick around for a while....lot's of good humor to be found here. In my case, I didn't need quikrete when I did my fence...our soil already resembles concrete.
    Shane_O[OP] and Strictlytoyz like this.
