ECM replaced??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BOONDOCKSAINT, Dec 29, 2017.
  1. Dec 29, 2017 at 6:01 AM
    BOONDOCKSAINT
    BOONDOCKSAINT [OP] Well-Known Member
    Central Louisiana
    WHITE 2016 DC OFF ROAD 4X4
    Pioneer 400w amp Infinity Reference Ref 6x9 (front doors) Infinity Reference Ref 6 1/2(rear doors) Kicker HS 8" hideaway
    Ill try to give you the short version of this story.
    Coming home a few weeks ago on a 4hr road trip in which I averaged speeds of 85 to 90mph, my truck threw every warning light imaginable, lost power steering, but engine was still running.
    Luckily I was at a manageable speed 35ish.
    Pulled into parking lot shut truck off and back on everything cleared, and it drove like normal.
    Brought to dealership ( the kept it about a week) they checked crank sensor it was good, but replaced the ECM.
    Didn’t seem to really know if that was the problem or if it was fired.
    But they had gone back and forth with Toyota and it’s what they recommend.
    Truck has 31,000 miles and only mods are new speakers, sprint booster, spidertrax, Chinese pro grill.
    Anyone else read about or have an issue like this?
    I’ve seen things about ECU is that different than an ECM?
    Forgive me if that’s a dumb question, mechanically limited.
    If you have experienced with this, what should I know or be on the lookout for?
    Worried because obviously I’m approaching the end of my warranty.
    Thanks for any helpful input.
  2. Dec 29, 2017 at 6:24 AM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    To start off, let me tell you I have been in the mechanical field for over 7 years, certified in ATV, Outboard, and Sterndrive engines. I have had to replace three ECMs in that time. One was from the guy sinking his ATV in a mudhole and fried the whole electrical system. Another was a result of some other component failure which caused a fire on the outboard engine. The third was caused from a short in the coil pack harness, which backfed and shorted the ECM.
    So, I am not saying that an ECM/ECU can not be bad on its own, however, its not likely. There is a good chance there is an underlying issue there. Also, the fact that the engine was still running and it started back up and drove like normal. The ECM/ECU is the engine control module or engine control unit, so for it to be bad and the engine still run, not likely.
    How did they ¨check¨ the crank sensor? That would be my question to them. I see you have a 2016, what was your trucks build date?
    BOONDOCKSAINT[OP] likes this.
  3. Dec 29, 2017 at 6:24 AM
    Scooby24
    Scooby24 Well-Known Member
    Greg
    2017 DCSB OR 4X4
    Another person with a sprint booster had a similar failure as I recall. Dealership replaced ECU as well.
    Ovtune has ran into early model 16 ECUs and throttle map changes he made as well. They may have problems with higher throttle input voltages.
  4. Dec 29, 2017 at 7:52 AM
    BOONDOCKSAINT
    Central Louisiana
    Build date is 4/16 out of Texas.
    Said there’s a recall on some crank sensor, mine didn’t fall under the ones being recalled.
    Something about a dot being on them.
    My concern was the sprint booster, but my efforts to search or google the problem only showed if it wasn’t properly snapped in all the way.
    Felt like they were just taking a shot in the dark and hoping this fixed the issue.
    Didn’t walk away feeling confident it wouldn’t happen again, especially before warranty runs out.
    Bought the truck with 5500 miles on it and carfax was clean.
    Should I lower the peddle response on the sprint booster or pull it all together?
    Does that mean I shouldn’t do the OVtune if I pull the sprint booster?
  5. Dec 29, 2017 at 7:59 AM
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    I agree.
    It's possible the ECM just froze up like a computer, but I'm kind of the opinion that if the ECM failed, it wouldn't run until replaced. I would think the same about the crank position sensor. I guess it might be flaky, but IDK if I believe that. A bad ground or something sounds more likely.... mice in the engine bay?
  6. Dec 29, 2017 at 10:57 AM
    Scooby24
    Greg
    2017 DCSB OR 4X4
    My Frontier had a bad ECM. It ran fine other than was throwing a code for a PNP switch. I replaced the switch and it never had a problem with starting. Just threw a code for it, and no amount of resetting the codes would get rid of it. Always came back. Only after the ECM was replaced was it gone forever...so they can definitely be bad and still have the vehicle run.
  7. Dec 29, 2017 at 6:25 PM
    Mt4cylclifton
    Mt4cylclifton Well-Known Member
    2017 4 cylinder Tacoma
    My truck did this within the first week of owning it!!! Since then I've not had it happen I'm just over 10k
    However after that initial "whatever the heck" Total shut down of everything including the power steering and all electric....I've had a speedometer tic to issue. I've had the combination meter replaced 3 times to try and remedy the issue, it's only done it in warmer temps. So I'll have to see if the third combo meter did the trick?
  8. Dec 29, 2017 at 6:30 PM
    Mt4cylclifton
    Actually the tic toc on the tac has happened since day one sorry I brought it in after the speedo got stuck on 20mph the day after it shut down like yours did
  9. Dec 29, 2017 at 7:25 PM
    BOONDOCKSAINT
    Central Louisiana
    I haven’t had any other issues since the initial event.
    The day after the event I drive it all day, before I could get it to the dealership.
    They had it for 9 days, and I’ve had it back for 2 days.
    Supposedly with a new “ECM” and stil nothing out of the ordinary.
    The wondering and not knowing if this will happen again is what will eat at me for a while.
  10. Feb 27, 2024 at 12:33 PM
    tacofanboy8
    tacofanboy8 Active Member
    Alex
    2018 Tacoma TRD Sport - Cement
    none
    Any update on this fix?
    I had a really similar event happen to me this week. Coming back from a road trip and I had the engine light flashing, clearly had a misfire with inability to accelerate and the engine chugging. Had to tow it to the dealership and after a few hours of diagnosing, changing spark plugs, checking for cylinder pressure, valves etc, they come back that I have to have the ECM replaced. Luckily it is covered under warranty but I'm worried about it happening again as well
