ECGS Bushing + New Seal = Leaking Diff - HELP?! (NOW WITH SOLUTION)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by steveo27, Jul 8, 2017.
  1. Jul 8, 2017 at 8:35 PM
    steveo27
    steveo27 [OP] Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Need some help...
    I did the ECGS bushing and new axle seal on my truck about a month back. I replaced the seal as preventative maintenance since I had the CV shaft out.
    The replacement seal is an OEM part - 90311-47027, which is supposed to be the same as 90311-47012.
    The seal started leaking after a day or 2 to the point where there was a coating of gear oil on the under side of the truck.
    I figured the seal somehow got damaged when I installed it so I ordered another one and installed it. Its now leaking just as bad as the other seal. It not a small drip or 2, its almost like its pouring out of the seal. Its bad enough that I have a puddle of gear oil on the skids.
    I cannot figure out what I did wrong.
    I have a few questions....
    - I have the ECGS bushing installed like this -
    E2369F9C-EE25-4CD1-8D90-789B0E8AF0F7_zps_6b3c5722343242608c18f2ab81de18f9aaad9b53.jpg
    Is this not deep enough and causing the axle to not seat the whole way? Ive followed multiple DIYs online and some show it installed this deep, some show it installed deeper. Im worried Im going to drive it in too far and itll hit the spider gears.
    - Can anyone verify 0311-47027 and 90311-47012 are the same parts? I wonder if they arent? and the opening on the seal is too large for the CV shaft? Stupid me didnt slide the seal over the CV to make sure it fit tight before I installed it.
    - What exactly does the the round metal dust shield looking disk on the diff end of the CV axle do? Mine was bent when removing the axle. Ive straightened it back out and reinstalled it. Which way does it sit? Ive read this will cause the seal to leak if you install install it backwards. Does anyone have a name or part number for this piece?
    I plan on pulling the axle back out again for the third time tomorrow and trying to figure out what the hell is going on and I would like some insight before I do. Good news is Ive got it down to about an hour to pull and reinstall the CV axle.
    Ideally, I hope its something stupid and simple, but If I cant get it to stop leaking tomorrow, Id like to order another seal and dust shield thingy and start over. If anyone can provide the correct part numbers, that would be awesome.
    UPDATE -
    Problem solved. Bushing was in ass backwards.
    Solution / info -
    - Make sure the seal is installed properly. The spring faces the differential. The seal sits flush with the diff housing.
    INCORRECT -
    Seal driven in proper depth, but installed backwards (spring facing out).
    Not driven in far enough, seal installed backwards (spring facing out)
    CORRECT -
    Driven in correct depth (flush with surrounding flange) and installed corrected (spring facing diff)
    Tips -
    - Use a 2" PVC coupler to drive the seal in. I used a 1.5" to 2" coupler - https://www.lowes.com/pd/Charlotte-Pipe-1-1-2-in-dia-PVC-Adapter-Coupling-Fitting/3132735 - to do mine. Easier to hold the 1.5" diameter and drive in evenly using a rubber mallet with a 2" diameter head on it.
    - OEM part - 90311-47027 - is the correct part number for the driver side seal.
    - This is the correct depth for the ECGS bushing to be driven in -
    Correct dust shield orientation -
    The OEM PN for the shield is 41336-01010, I bent mind back into shape instead of replacing it.
    Ive currently have about 200 miles on the seal since installing it correctly with no problems.
    UPDATE - Roughly 1000 miles since reinstalling the seal, still dry.
  2. Jul 8, 2017 at 9:01 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I think your bushing looks fine. I didn't change the seal when I did my ECG bushing and it's been fine.
    I know that doesn't help you but again, I think the bushing looks fine. Most sit a tad proud like that anyway.
  3. Jul 8, 2017 at 9:11 PM
    Jaggerbub
    Jaggerbub Well-Known Member
    Tom
    Diamond Bar 91765
    2017 DCLB OR 4X4
    Following to see the outcome. Good luck. Crossing fingers for you.
    Bullnettles, TACOVRD and BassAckwards like this.
  4. Jul 8, 2017 at 9:15 PM
    jtrue
    jtrue Well-Known Member
    SLC, UT
    2014 Super White Tacoma TRD
    Did you overfill the clamshell, ie keep pumping once diff fluid overflows and installing plug prior to letting the flow slow down?
  5. Jul 8, 2017 at 9:22 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Had this problem forever...went through many seals...was a cv sxle
  6. Jul 8, 2017 at 9:24 PM
    anthony250f
    Anthony
    San Diego, CA
    Yes those part numbers are the same...I went through 4 seals at least lol.
  7. Jul 8, 2017 at 10:11 PM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    Did you use OEM or aftermarket? What brand of aftermarket
  8. Jul 8, 2017 at 10:19 PM
    BrokenMech
    BrokenMech Well-Known Member
    Upstate, NY
    2019 4Runner TRD Pro
    I had the same problem OP. It ended up been that the seal needed to be flush with the inner lip and not bottomed out. That helped me, just FYI.
    trktwo and Sub-Zero like this.
  9. Jul 8, 2017 at 11:08 PM
    anthony250f
    Anthony
    San Diego, CA
    All oem seal with napa cv
    Tacoma_Wa253 likes this.
  10. Jul 9, 2017 at 7:48 AM
    steveo27
    Pittsburgh
    Thanks for chiming in guys. The original seal didn't leak with the axle, I kinda regret replacing it now since it was fine
    I never thought about the seal being driven in too far, but that make sense.
  11. Jul 9, 2017 at 7:50 AM
    anthony250f
    Anthony
    San Diego, CA
    It must be flush with the carrier. Use a 2" pvc pipe as a driver
    tcjacado and BrokenMech like this.
  12. Jul 9, 2017 at 8:17 AM
    Rogelio22
    Rogelio22 Get him a body bag! [TTC #030]
    Roger
    Sioux City, IA
    2018 Chevy Silverado 1500 Z71 Texas Edition
    Blank slate, ready to start
  13. Jul 9, 2017 at 8:42 AM
    anthony250f
    Anthony
    San Diego, CA
  14. Jul 9, 2017 at 8:44 AM
    Rogelio22
    Roger
    Sioux City, IA
    Gotcha, that's what I thought but didn't know for sure.
    anthony250f likes this.
  15. Jul 9, 2017 at 8:50 AM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    Sub'd for outcome. GL OP
  16. Jul 9, 2017 at 10:39 AM
    steveo27
    Pittsburgh
    Thanks. I've decided against doing it today. It's too hot out, plus I wanna do a little more research on the dust shield thingy and order a spare seal so if it needs replaced again I'll have it when I pull it all apart. Ideally I'd like to replace that dust shield as well but I haven't found the part number yet
  17. Jul 9, 2017 at 12:44 PM
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    Here's a thought op, is all the rust around the edge damaging the seal as it's being put in? In your pic it looks to me like there's a good 1/8" of rust inside the bore the seal sits in. Maybe your leak is from the seals' outer (diff) side, not the inner cv side. Clean that all up then install a new seal.
  18. Jul 9, 2017 at 2:50 PM
    TtPaul
    TtPaul Well-Known Member
    SoCal
    DCSB 4x4 6SPD
    I just ordered my ECGS bushing today, did you guys replace the CV axles too? Ideally I would want my axles to stay oem.
  19. Jul 9, 2017 at 2:51 PM
    Rogelio22
    Roger
    Sioux City, IA
    I didn't replace my axle. Just the bushing and seal
  20. Jul 9, 2017 at 2:57 PM
    Basikbiker
    Basikbiker Well-Known Member
    Trav
    09 AccCab 4x4 spaceship
    My doors are the only stock things left besides the headlights
    Most likely you have the seal riven in too far, I've done this mod to a few trucks, if it's driven in too far they leak, flush with the carrier or a tiny smudge past the lip
    BrokenMech likes this.
