Easy way of wiring a topper third brake light
Discussion in '4th Gen. Tacomas (2024+)' started by bird dog 3, Dec 17, 2024.
  1. Dec 17, 2024 at 12:32 PM
    bird dog 3
    bird dog 3 [OP] Member
    Roger
    2024 Tacoma
    what is the easiest way to wire the third brake light on a camper topper so it doesn't flash with the turn signal on?
  2. Dec 17, 2024 at 12:45 PM
    TurboDA6
    TurboDA6 Well-Known Member
    Trailer hitch adapter harness maybe?
    Puppypunter and Pithy like this.
  3. Dec 17, 2024 at 12:53 PM
    Pithy
    Pithy Well-Known Member
    Christopher
    Idaho Springs, CO
    2004 3.4L V6 4x4 SR5 Double Cab Impulse Red
  4. Dec 17, 2024 at 5:43 PM
    bird dog 3
    Roger
    2024 Tacoma
    This is the way I have the camper topper wired but when the turnsignal is turned on to the left the third brake light turns into a blinking light. This is on a 2024 Tacoma and this is the way the camper dealer wired it. There must be a way to wire the third brake light to the truck so the third brake light stays a brake light and not a blinking light when the turnsignal is turned on.
  5. Dec 17, 2024 at 7:11 PM
    caribe makaira
    Caribbean, Puerto Rico
  6. Dec 17, 2024 at 8:06 PM
    Sagebrush
    Sagebrush Well-Known Member
    Gens 1, 2, 3, and 4
    My Smartcap came with a harness that plugs in-line with the trailer plug harness. So you could connect down there. You can pull the connector out from the back side of the trailer plug.
    shakerhood and TurboDA6 like this.
  7. Dec 17, 2024 at 8:22 PM
    caribe makaira
    Stop & Turn is also combined in the trailer plug.
  8. Dec 17, 2024 at 10:36 PM
    Pithy
    Christopher
    Idaho Springs, CO
    The brake light should be a separate bulb with separate wires than the turn signal. It seems like the dealer didn’t do the wiring from the rear lights correctly and have the signal bulb wires running to it.
  9. Dec 18, 2024 at 12:02 AM
    caribe makaira
    In the 4th Gen it's not the usual setup. Stop & Turn are same circuit like towing.
    Reverse/Tail/Turn & Stop/Ground
    shakerhood likes this.
  10. Dec 18, 2024 at 2:01 AM
    HighCountryTacoma
    HighCountryTacoma Well-Known Member
    Colorado
    2017 DCSB TRD Off Road Quicksand
    There’s a guy on here @Puppypunter that makes brake light taps. Not sure he has one for the 4the gen yet but it is quite possibly the same wiring. I used one to add a 3rd brake light to my soft topper. Worked great!
    Puppypunter likes this.
  11. Dec 18, 2024 at 6:39 AM
    Pithy
    Christopher
    Idaho Springs, CO
    Ohh, Interesting. I didn”t realize I wasn’t in the 1st gen section. I will step back now as I don’t know how to help!
  12. Dec 18, 2024 at 7:08 AM
    TurboDA6
    As far as I know, the standard for a 7 pin trailer plug is that there's a separate brake light circuit, even if your tail lights are combined.
    The easiest way to access brake light circuit on any truck with a 7 pin trailer connector is to buy an adapter and you can run the wires very easily to either corner of the truck bed and up to the cap, usually behind a tail light and thru the top inside of the bed.
  13. Dec 18, 2024 at 8:15 AM
    caribe makaira
    That is so wrong.:smack:
    TurboDA6[QUOTED] likes this.
  14. Dec 18, 2024 at 8:16 AM
    caribe makaira
    It's NOT the same wiring.o_O
  15. Dec 18, 2024 at 8:53 AM
    Puppypunter
    Puppypunter Well-Known Member
    Johnny
    2019 Black SR
    The 4th gen does combine the turn/stop, so a simple tap won’t work unfortunately. Your best bet is to use a 2-to-3 adapter and tap off the trailer plug. I think Curt or someone might make a set up for that already? @daveeasa might remember that better than I do. If they didn’t, it is something I can make for sure, but given the cost of parts for me, it isn’t exactly cheap.
  16. Dec 18, 2024 at 8:56 AM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
  17. Dec 18, 2024 at 9:30 AM
    soupy1234
    soupy1234 Well-Known Member
    2024 Celestial Silver TRD OR LB
    Smartcap harness has an adapter box that takes care of it. I would expect that vendors should be coming out with something soon.
  18. Dec 18, 2024 at 9:33 AM
    daveeasa
    David
    PNW
    My pref is T off cargo, longer wire run but simpler/effective/straightforward and can capture cargo at the same time which is nice for shell dome.
  19. Dec 18, 2024 at 10:14 AM
    caribe makaira
    A simple posi-tap at the towing converter and a long wire to cap is the cheapest way. Even if the converter is missing, the connector is there.
  20. Dec 18, 2024 at 2:47 PM
    Puppypunter
    Johnny
    2019 Black SR
    That is Q20? Do you know how to access that plug? Looks like it’s in the cab area?
