Easy spray-on bedliner removal from plastic?
Discussion in '1st Gen. Tacomas (1995-2004)' started by betterbuckleup, Feb 6, 2024.
  1. Feb 6, 2024 at 9:28 PM
    betterbuckleup
    betterbuckleup [OP] Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Anyone have any good suggestions on how to easily remove shitty spray-on bedliner from a fender flare? Previously I did it with a paint scraper, but that took forever. Any good liquid stripping agents that won't attack the plastic?
  2. Feb 6, 2024 at 9:54 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Half a day in a steam cabinet.
    I have used wd-40 to break up paint......but this will dull the plastic finish over time.....but could reshine using Maguires....
  3. Feb 6, 2024 at 10:01 PM
    betterbuckleup
    Ian
    Concord, CA
    I plan to spray some SEM trim black on it once I strip the bedliner off. I've found that to last a while and look good.
  4. Feb 6, 2024 at 10:05 PM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    I've never tried it with that rubberized coating or a plastic before. But citristrip is pretty mild in terms of stripping agents and it works very well on other bonded paints. I might try it in a hard to see area first or maybe on your ruined flare to see if it melts the plastic. My guess is it probably won't because automotive plastics are usually solvent resistant but can never be too careful
  5. Feb 6, 2024 at 10:15 PM
    betterbuckleup
    Ian
    Concord, CA
    Hm ok ya I can try it on a small spot on the bottom first.
    The other one decided to go live in the desert somewhere.
    Some people say it only attacks soft plastic, but I feel like these are somewhere in between.
